Topic "File Renamed Detection"
jmyx
Sometimes to copy a file name I hit F2 (Rename), and then CTRL+A.
Every time I do this it displays an error when backing out about being unable to rename the file to itself.
Is it possible to add rename detection so that if I don't change the file name, it doesn't try to re-write it?
Best,
J
Local or remote or both panels?
jmyx
This happens in remote only.
Thanks for your post. This request has been added to tracker.
vanillasplice wrote:
What does it mean when this is happening in both panels? I'm a little bit lost. I am sorry for re-opening the thread, but I was unable to find the information I was looking for.
Can you describe what problem are you having in more details?
