Topic "Using WinSCP to upload from Windows XP to IBM mainframe."
smurphy8564
Just a general questions. Should I be able to use WinSCP to transfer files from my Windows XP box to an IBM Mainframe where the directory strings look something like this: TEST.ASU.AGENCY123.INPUT ??? I get an error that says no such directory found. (or something like that) Thanks.
smurphy8564
I read a posing somewhere that said that WinSCP does not support IBM mainframe directory strings. Is that true??
Yes. That is true.
TimThackerISF
I saw that the answer was from 2010 and was wondering if it was still an issue with the directory names from IBM mainframe. I can get connected but can't get the remote directory to change to the correct path. It works in Filezilla but I wanted to use the automated C# library. Is it possible to read IBM mainframe directory strings?
Tim
There's no update yet.
May I get a test account on your server?
orlando.colamatteo
I am trying to do the same thing with an IBM mainframe and am not able to download a file named as
'filename(0).blah'
I am assuming the name is resolved on the mainframe side but the ftp WinSCP component must have something to do with it because I can download it using the .NET WebCLient class.
pasha-hef3
Hi, I cannot display a directory listing when I connect to an IBM mainframe from Windows 7 with WinSCP using FTP protocol with TLS explicit encryption. Is it still true that WinSCP does not support IBM mainframe directory strings?
Thanks!
Yes.
