Topic "Autorun WinSCP on system's startup + logon + keepuptodate..."
joujoujou
Hello.
I'm trying to do all things automatically, but can't get through it.
What I want to do - run WinSCP on windows startup, logon using last (and the only one) saved session and keep remote folder up to date.
Using documentation made batch file:
@ECHO OFF
@ECHO Odpalamy FTP... :-)
@PING 1.1.1.1 -n 1 -w 10000 >NUL
@START C:"\Documents and Settings\joujoujou\Desktop\Pulpitt\winscp\WinSCP.exe" /command /script=test.txt
as well as script file (test.txt), located together with both winscp.exe and winscp.com in the same folder:
option batch on
open user@domain.com
keepuptodate C:\Program Files\Cumulus\web /var/www/domain.com/htdocs/weather
Already tried with quotation marks and without, with options "batch on" and "confirm off" and without them. Nothing happened.
Currently just run application manually, manually logging in and manually starting "keep up to date" option from application's menu. Also with "synchronize on start" "existing files only" and "including subfolders" options ticked.
What am I doing wrong?
Regards,
joujoujou.
To see what is going on, replace /command with /console. Even better run winscp.com from Windows console.
joujoujou
Thank you. Very Happy
Parameter /console showed me where (actually when) I made a mistake - when my script has been saved, character encoding was set to "unicode" - reedited entire file, saved as ANSI and all works now as I wanted.
Thank you again for your effort and help.
Now results can be seen online at www.joujoujou.com/weather (update is done every 10 minutes when my computer is on).
joujoujou
joujoujou wrote:
[...] all works now as I wanted.
Actually, I was wrong.
It worked, occasionally.
Usually instead of upload I'm getting message as below:
Obviously in GUI mode all is still correct.
Any ideas?
Isn't your session terminated by the server due to inactivity?
joujoujou
I'm not sure, log attached.
This is the log saved during scripting:
<removed by admin>
Real domain as well as username changed to keep some privacy. All the rest of the log untouched.
I cannot tell the from client log. Do you have an access to server log?
joujoujou
No, unfortunately. Sad
Anyway, GUI mode works O.K. - script not.
Will you, please, delete the log from post above?
Thanks. Smile
