Topic "Intermittant file transfer problem"
cwannall
I have a file that will not transfer using winscp. I can transfer it with windows text mode ftp (my emergency, non-secure backup). Other files will transfer file.
The file is one I get from another ftp site and rename before transferring. I also tried opening this text file and saving it to another name (using textpad 4.7). The error occurs whether or not the file is being overwritten.
The error is:
Unable to receive data from TCP/IP.
Data transfer ended.
Using WinSCP 4.2.8 with Commander interface on Windows XP SP3. Using ftp with ssl Port 990.
Chuck
cwannall@calarts.edu
cwannall
. 2010-09-01 07:41:22.453 --------------------------------------------------------------------------
. 2010-09-01 07:41:22.453 WinSCP Version 4.2.8 (Build 818) (OS 5.1.2600 Service Pack 3)
. 2010-09-01 07:41:22.453 Login time: Wednesday, September 01, 2010 7:41:22 AM
. 2010-09-01 07:41:22.453 Session name: bulreq
. 2010-09-01 07:41:22.453 Host name: aar.calarts.edu (Port: 990)
. 2010-09-01 07:41:22.469 User name: bulreq (Password: Yes, Key file: No)
. 2010-09-01 07:41:22.469 Tunnel: No
. 2010-09-01 07:41:22.469 Transfer Protocol: FTP
. 2010-09-01 07:41:22.469 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-09-01 07:41:22.469 Proxy: none
. 2010-09-01 07:41:22.469 FTP: FTPS: Implicit SSL/TLS; Passive: No [Force IP: No]
. 2010-09-01 07:41:22.469 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-09-01 07:41:22.469 Cache directory changes: Yes, Permanent: Yes
. 2010-09-01 07:41:22.469 DST mode: 1
. 2010-09-01 07:41:22.469 --------------------------------------------------------------------------
. 2010-09-01 07:41:22.546 Connecting to aar.calarts.edu:990 ...
. 2010-09-01 07:41:22.546 Connected with aar.calarts.edu:990, negotiating SSL connection...
. 2010-09-01 07:41:22.700 SSL connection established. Waiting for welcome message...
< 2010-09-01 07:41:22.885 220-QTCP at AAR.
< 2010-09-01 07:41:22.885 220 Connection will close if idle more than 5 minutes.
> 2010-09-01 07:41:22.885 USER bulreq
< 2010-09-01 07:41:22.885 331 Enter password.
> 2010-09-01 07:41:22.885 PASS ********
< 2010-09-01 07:41:23.162 230 BULREQ logged on.
> 2010-09-01 07:41:23.162 SYST
< 2010-09-01 07:41:23.162 215 OS/400 is the remote operating system. The TCP/IP version is "V5R4M0".
> 2010-09-01 07:41:23.162 FEAT
< 2010-09-01 07:41:23.162 211-Feature listing follows:
< 2010-09-01 07:41:23.286 AUTH TLS
< 2010-09-01 07:41:23.286 CCC
< 2010-09-01 07:41:23.286 PBSZ
< 2010-09-01 07:41:23.286 PROT
< 2010-09-01 07:41:23.286 211 End of feature listing.
> 2010-09-01 07:41:23.286 PBSZ 0
< 2010-09-01 07:41:23.286 200 PBSZ accepted.
> 2010-09-01 07:41:23.286 PROT P
< 2010-09-01 07:41:23.286 200 PROT accepted.
. 2010-09-01 07:41:23.286 Connected
. 2010-09-01 07:41:23.286 --------------------------------------------------------------------------
. 2010-09-01 07:41:23.286 Using FTP protocol.
. 2010-09-01 07:41:23.286 Doing startup conversation with host.
> 2010-09-01 07:41:23.286 PWD
< 2010-09-01 07:41:23.286 257 "/home/BULREQ" is current directory.
. 2010-09-01 07:41:23.286 Getting current directory name.
. 2010-09-01 07:41:23.286 Retrieving directory listing...
> 2010-09-01 07:41:23.286 TYPE A
< 2010-09-01 07:41:23.286 200 Representation type is ASCII nonprint.
> 2010-09-01 07:41:23.286 PORT 172,20,174,42,4,231
< 2010-09-01 07:41:23.286 200 PORT subcommand request successful.
> 2010-09-01 07:41:23.286 LIST -a
< 2010-09-01 07:41:23.578 125 List started.
. 2010-09-01 07:41:23.640 SSL connection established
< 2010-09-01 07:41:23.763 250 List completed.
. 2010-09-01 07:41:23.763 Directory listing successful
. 2010-09-01 07:41:23.763 Startup conversation with host finished.
. 2010-09-01 07:41:27.262 Cached directory change via "/home/bulreq" to "/home/bulreq".
. 2010-09-01 07:41:27.262 Getting current directory name.
. 2010-09-01 07:41:27.262 Retrieving directory listing...
> 2010-09-01 07:41:27.262 CWD /home/bulreq/
< 2010-09-01 07:41:27.278 250 "/home/bulreq" is current directory.
> 2010-09-01 07:41:27.278 PWD
< 2010-09-01 07:41:27.278 257 "/home/bulreq" is current directory.
> 2010-09-01 07:41:27.278 TYPE A
< 2010-09-01 07:41:27.278 200 Representation type is ASCII nonprint.
> 2010-09-01 07:41:27.278 PORT 172,20,174,42,4,232
< 2010-09-01 07:41:27.278 200 PORT subcommand request successful.
> 2010-09-01 07:41:27.278 LIST -a
< 2010-09-01 07:41:27.540 125 List started.
. 2010-09-01 07:41:27.586 SSL connection established
< 2010-09-01 07:41:27.802 250 List completed.
. 2010-09-01 07:41:27.802 Directory listing successful
. 2010-09-01 07:41:33.304 Copying 1 files/directories to remote directory "/home/bulreq/"
. 2010-09-01 07:41:33.304 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2010-09-01 07:41:33.304 TM: A; ClAr: No; CPS: 0; ExclM(No):
. 2010-09-01 07:41:33.304 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-09-01 07:41:33.304 File: "C:\s36\affordp.txt"
. 2010-09-01 07:41:33.304 Copying "C:\s36\affordp.txt" to remote directory started.
. 2010-09-01 07:41:33.304 Ascii transfer mode selected.
. 2010-09-01 07:41:33.304 Starting upload of C:\s36\affordp.txt
. 2010-09-01 07:41:33.304 Asking user:
. 2010-09-01 07:41:33.304 Remote file 'affordp.txt' already exists. Overwrite?
. 2010-09-01 07:41:33.304 New: 12259 bytes, 8/25/2010 8:35:26 AM
. 2010-09-01 07:41:33.304 Existing: 0 bytes, 9/1/2010 7:42 AM ()
> 2010-09-01 07:41:34.846 TYPE A
< 2010-09-01 07:41:34.846 200 Representation type is ASCII nonprint.
> 2010-09-01 07:41:34.846 PORT 172,20,174,42,4,233
< 2010-09-01 07:41:34.846 200 PORT subcommand request successful.
> 2010-09-01 07:41:34.846 STOR affordp.txt
< 2010-09-01 07:41:34.877 150 Sending file to /home/bulreq/affordp.txt
. 2010-09-01 07:41:34.907 SSL connection established
< 2010-09-01 07:41:34.984 426-Unable to receive data from TCP/IP.
< 2010-09-01 07:41:34.984 426 Data transfer ended.
. 2010-09-01 07:41:34.984 Copying files to remote side failed.
* 2010-09-01 07:41:34.984 (ExtException) Copying files to remote side failed.
* 2010-09-01 07:41:34.984 Unable to receive data from TCP/IP.
* 2010-09-01 07:41:34.984 Data transfer ended.
. 2010-09-01 07:41:34.984 Asking user:
. 2010-09-01 07:41:34.984 Error transferring file 'C:\s36\affordp.txt'. ("Copying files to remote side failed.","Unable to receive data from TCP/IP.","Data transfer ended.")
* 2010-09-01 07:41:36.587 (EScpSkipFile) Error transferring file 'C:\s36\affordp.txt'.
* 2010-09-01 07:41:36.587 Copying files to remote side failed.
* 2010-09-01 07:41:36.587 Unable to receive data from TCP/IP.
* 2010-09-01 07:41:36.587 Data transfer ended.
. 2010-09-01 07:41:36.587 Retrieving directory listing...
> 2010-09-01 07:41:36.587 TYPE A
< 2010-09-01 07:41:36.587 200 Representation type is ASCII nonprint.
> 2010-09-01 07:41:36.603 PORT 172,20,174,42,4,234
< 2010-09-01 07:41:36.603 200 PORT subcommand request successful.
> 2010-09-01 07:41:36.603 LIST -a
< 2010-09-01 07:41:36.849 125 List started.
. 2010-09-01 07:41:36.896 SSL connection established
< 2010-09-01 07:41:37.004 250 List completed.
. 2010-09-01 07:41:37.004 Directory listing successful
. 2010-09-01 07:41:39.871 Disconnected from server
Thanks. Do you have access to server-side log file?
cwannall
Sorry, no. I can transfer other files, but this specific file will not transfer. Opening it and saving it anew with a text editor doesn't solve the problem either.
