Topic "Invalid access to memory - when use scripting"
joujoujou
Hi again.
Already asked for help with scripting, got the answer, but unfortunately not solved totally.
WinSCP 4.2.8 (same problem when used 4.2.7), XP professional SP3 (EN).
My previous thread - http://winscp.net/forum/viewtopic.php?t=8815
Currently used command (batch file):
@ECHO OFF
@ECHO Odpalamy FTP... :-)
@PING 1.1.1.1 -n 1 -w 10000 >NUL
@START C:"\Documents and Settings\joujoujou\Desktop\Pulpitt\winscp\WinSCP.exe" /console /script=C:"\Documents and Settings\joujoujou\Desktop\Pulpitt\winscp\test.txt"
Script:
option batch on
option reconnecttime 1
open user@domain.com
synchronize remote
keepuptodate C:"\Program Files\Cumulus\web" /var/www/domain.com/htdocs/weather
Note: user and domain details changed to keep some privacy. Wink
Problem exists only when use scripts - in GUI mode all is working O.K.
I'd rather prefer not to publish log I've saved.
Would be glad to email it, or somehow like that.
Thank you.
Thanks for your post. This bug is being tracked already.
joujoujou
Thank you.
May I use email found here to send you a log? If you want it, of course. Smile
Thank. Though the bug is fixed already.
serendipity
Hi, i'm facing the same problem. Happy to know it's fixed, but when 4.2.9 will be released?
Thanks.
joujoujou wrote:
Hi again.
@ECHO OFF
Script:
option batch on
synchronize remote
Thank you.
peterj
Thanks.
I too am suffering from this problem, although it appears to be both in the interactive command line mode and running a script. Can you advise when the next release will be ou as this is affecting a production system now.
Regards,
P
In few weeks.
joujoujou
Exactly the same when running winscp 4.29.
