Topic "Find File command"
Where is the Find File command? says it's under the Commands group, but I don't see it. I see Compare Directories, Synchronize, etc, but not the Find File command. Am I going blind? Smile
Also, can you search for files via a date range?
Do you have the latest version of WinSCP?
You cannot search by date.
It was a fresh download, but it was 4.1.8. I don't recall the download site.
I just downloaded the latest. Works better. Smile
The search by date feature would be great. I've needed that several times (esp after a hack episode).
