Topic "Can't create LINK"
cosik
I have a problem. I can't create a link in the remote directory. This option is not available - gray. On another computer it works :(Please help
You are probably using different protocol on the machines. Creating links is not support with FTP protocol.
cosik
Hi, thanks for the information. On one computer I connect normally via ftp and it's ok. I don't know what's going on.
Can you post a log file from both machines? On the machine where it works, make sure the log shows creating of the link as well.
