Topic "XML Log + local RM"
dandre
I have noticed that when I sync from remote to local, that the XML log file does not report removed files, even though I can see them removed. It works the other way around however, when syncing local to remote.
The command I am using is:
synchronize local -delete "c:\folder" /folder
Is this a bug?
DGorthat
I have the same problem:
XML logging works for me as expected with the setting synchronize remote
File is deleted correctly, no further action was done and not required
synchronize remote -delete "D:\TxdRxD\Sync\" "/cygdrive/c/Inetpub/sftp/"
<session xmlns="http://winscp.net/schema/session/1.0" name="ftpuser@xxx" start="2010-09-09T06:01:02.677Z">
  <rm>
    <filename value="/cygdrive/c/Inetpub/sftp/50863_564_2010_08_12_13.55.45.zip" />
    <result success="true" />
  </rm>
</session>
XML logging does not show results with the setting local - delete when deleting files
synchronize local - delete "D:\TxdRxD\Sync\" "/cygdrive/c/Inetpub/sftp/
A File on the local directory is deleted correctly
<session xmlns="http://winscp.net/schema/session/1.0" name="ftpuser@xxx" start="2010-09-09T06:09:43.531Z">
</session>
greets
Dirk
WinSCP logs only operations on the server side. See XML logging documentation to see what it logs.
