Topic "WinSCP disappear after user authentication"
ycyu2000
WinSCP client disappear every time after user authentication. I can see the last message is "Reading remote directory" or somthing like this. But I can see the process is still running in the Windows Task Manager.
I can use Putty to SSH into remote server use same useId and password without problem. And I can use FileZilla (SFTP) with the same userid and password without problem.
Can someone help me with this?
Thanks!
Can you post a log file?
ycyu2000
Hi Martin,
Now it is getting a little more interesting... I can login to the remote server and upload download files successfully maybe 1 out of 5 times. For the remaining, it is still the same problem - WinSCP disappeard from the screen but can be found in Windows Task Manager's process list.
My version of WinSCP is 3.7.1 It is pretty old, but this is the only version the company alows me to download from company website. My windows is XP with SP3. Remote server is Ubuntu.
Where can I find the log file? It is not in the WinSCP directory.
Thanks!
Though log file from 3.7.1 is of no use for me.
sterremuur
I found out that WinSCP UI disappears when the local and remote directories are incorrect.
If you make the remote directory "\" and the local points to an existing directory, the UI stays on the screen.
Hope this helps.
Eric
