Topic "Batch Upload Overwriting Remote Files"
I use the 4.2.8 command line version to upload all the files in a folder to a remote location via SFTP, however it is overwriting the destination files even if I set the Confirm option to ON.
"c:\program files\winscp\" /script=uploadscript.txt /log=log.txt
option batch on
option confirm on
open sftp://user:password@ftp_server:22
put -nopreservetime "C:\Twl_Get\rcvdata\*.txt"
option batch off
I can get around this some by using the synchronize command, which will only upload files that are different, however our SFTP server does not support a client making changes to the timestamp, which is why I use the -nopreservetime flag in the PUT.
This flag does not exist for SYCNHRONIZE, and the -nopermissions doesn't stop an error from occuring, so I need to set BATCH CONTINUE.
There's no easy solution with WinSCP only for you then. You would have to make script/application that drive WinSCP and compares the files before transfer.
