Topic "Error showing / directory"
lord xeon
Here is a new topic with my problem as described in this thread
I can login to my server fine as root, user1, user2, user37... and I get sent to each user's directory. However whenever I try to navigate to / I get:
"Host is not communicating for more then 15 seconds. Still waiting..."
Here is the log file from root:
. 2010-09-13 11:03:59.721 --------------------------------------------------------------------------
. 2010-09-13 11:03:59.722 WinSCP Version 4.2.8 (Build 818) (OS 6.1.7600)
. 2010-09-13 11:03:59.722 Login time: Monday, September 13, 2010 11:03:59 AM
. 2010-09-13 11:03:59.722 --------------------------------------------------------------------------
. 2010-09-13 11:03:59.722 Session name: 192.168.15.99
. 2010-09-13 11:03:59.722 Host name: 192.168.15.99 (Port: 22)
. 2010-09-13 11:03:59.722 User name:  (Password: No, Key file: No)
. 2010-09-13 11:03:59.722 Tunnel: No
. 2010-09-13 11:03:59.722 Transfer Protocol: SFTP (SCP)
. 2010-09-13 11:03:59.722 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-09-13 11:03:59.723 Proxy: none
. 2010-09-13 11:03:59.723 SSH protocol version: 2; Compression: No
. 2010-09-13 11:03:59.723 Bypass authentication: No
. 2010-09-13 11:03:59.723 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-09-13 11:03:59.723 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-09-13 11:03:59.723 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-09-13 11:03:59.723 SFTP Bugs: -,-
. 2010-09-13 11:03:59.723 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-09-13 11:03:59.723 Shell: default
. 2010-09-13 11:03:59.723 EOL: 0, UTF: 2
. 2010-09-13 11:03:59.723 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-09-13 11:03:59.723 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-09-13 11:03:59.723 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-09-13 11:03:59.723 Cache directory changes: Yes, Permanent: Yes
. 2010-09-13 11:03:59.723 DST mode: 1
. 2010-09-13 11:03:59.723 --------------------------------------------------------------------------
. 2010-09-13 11:03:59.785 Looking up host "192.168.15.99"
. 2010-09-13 11:03:59.785 Connecting to 192.168.15.99 port 22
. 2010-09-13 11:03:59.802 Server version: SSH-2.0-OpenSSH_5.1p1 Debian-5
. 2010-09-13 11:03:59.802 We believe remote version has SSH-2 ignore bug
. 2010-09-13 11:03:59.802 Using SSH protocol version 2
. 2010-09-13 11:03:59.802 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-09-13 11:03:59.828 Doing Diffie-Hellman group exchange
. 2010-09-13 11:03:59.870 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-09-13 11:04:00.054 Host key fingerprint is:
. 2010-09-13 11:04:00.054 ssh-rsa 2048 86:20:fd:a6:16:51:d2:c0:be:b6:3e:f5:94:7d:a6:10
. 2010-09-13 11:04:00.054 Initialised AES-256 SDCTR client->server encryption
. 2010-09-13 11:04:00.054 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-09-13 11:04:00.054 Initialised AES-256 SDCTR server->client encryption
. 2010-09-13 11:04:00.054 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-09-13 11:04:00.092 Prompt (1, SSH login name, , login as: )
. 2010-09-13 11:04:01.491 Prompt (6, SSH password, , &Password: )
. 2010-09-13 11:04:05.213 Sent password
. 2010-09-13 11:04:05.216 Access granted
. 2010-09-13 11:04:05.218 Opened channel for session
. 2010-09-13 11:04:05.259 Started a shell/command
. 2010-09-13 11:04:05.261 --------------------------------------------------------------------------
. 2010-09-13 11:04:05.261 Using SFTP protocol.
. 2010-09-13 11:04:05.261 Doing startup conversation with host.
> 2010-09-13 11:04:05.267 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-09-13 11:04:05.275 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2010-09-13 11:04:05.275 SFTP version 3 negotiated.
. 2010-09-13 11:04:05.275 Unknown server extension posix-rename@openssh.com="1"
. 2010-09-13 11:04:05.275 Unknown server extension statvfs@openssh.com="2"
. 2010-09-13 11:04:05.275 Unknown server extension fstatvfs@openssh.com="2"
. 2010-09-13 11:04:05.275 We believe the server has signed timestamps bug
. 2010-09-13 11:04:05.275 We will use UTF-8 strings for status messages only
. 2010-09-13 11:04:05.275 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-09-13 11:04:05.282 Getting current directory name.
. 2010-09-13 11:04:05.282 Getting real path for '.'
> 2010-09-13 11:04:05.283 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-09-13 11:04:05.283 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2010-09-13 11:04:05.283 Real path is '/root'
. 2010-09-13 11:04:05.283 Listing directory "/root".
> 2010-09-13 11:04:05.283 Type: SSH_FXP_OPENDIR, Size: 14, Number: 267
< 2010-09-13 11:04:05.284 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2010-09-13 11:04:05.284 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2010-09-13 11:04:05.286 Type: SSH_FXP_NAME, Size: 1253, Number: 524
> 2010-09-13 11:04:05.286 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2010-09-13 11:04:05.287 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2010-09-13 11:04:05.287 Status code: 1
> 2010-09-13 11:04:05.287 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2010-09-13 11:04:05.287 Startup conversation with host finished.
. 2010-09-13 11:04:07.946 Cached directory change via ".." to "/".
. 2010-09-13 11:04:07.946 Getting current directory name.
. 2010-09-13 11:04:07.946 Listing directory "/".
> 2010-09-13 11:04:07.946 Type: SSH_FXP_OPENDIR, Size: 10, Number: 1291
< 2010-09-13 11:04:07.946 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2010-09-13 11:04:07.946 Discarding reserved response
< 2010-09-13 11:04:07.946 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2010-09-13 11:04:07.947 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
. 2010-09-13 11:04:22.948 Waiting for data timed out, asking user what to do.
. 2010-09-13 11:04:22.948 Asking user:
. 2010-09-13 11:04:22.948 Host is not communicating for 15 seconds.
. 2010-09-13 11:04:22.948 Wait for another 15 seconds? ()
. 2010-09-13 11:04:24.320 Attempt to close connection due to fatal exception:
* 2010-09-13 11:04:24.321 Terminated by user.
. 2010-09-13 11:04:24.321 Closing connection.
. 2010-09-13 11:04:24.321 Sending special code: 12
. 2010-09-13 11:04:24.321 Sent EOF message
* 2010-09-13 11:04:24.326 (ESshFatal) Terminated by user.
* 2010-09-13 11:04:24.326 Error listing directory '/'.
* 2010-09-13 11:04:24.326 Error changing directory to '..'.
I also have a regular user, but that log looks the same, except I change 2 more directories before I get to /
Thanks. Can you try it with another SFTP client?
lord xeon
it looks like it was a server issue, because I restarted it to fix something else, and now it seems to work alright.
I will let you know if it happens again though.
