Topic "winscp Session1 /hostkey=testing"
jonmknight
First off - great bit of software. Please go easy on me, I've tried to understand previous posts of a similar nature and they go above my head..
Just trying to understand how to pass through hostkey / finger print via command line whilst using a saved session. Will then look into sending both ppk file and fingerprint via command line, before moving onto more advanced scripting.
Everytime I try to access my 'session1' (which has IP and PPK saved in the GUI configuration) and pass through the /hostkey parameter I'm being prompted to enter each time.
Is this the expected result? What should I be doing if I wanted to
a) Store the IP in a session
b) Store the location of the PPK file in the session
c) pass fingerprint via command line?
Many thanks, in anticipation...
