Topic "4.29 Timestamp problem under Win XP"
noftpanymore
429 seems to solve the W7 problem, but leaves the same problem under XP. How to fix that? Under XP WinSCP always had a one hour offset to my website server. I could see that the times were off in TC, but else no problem. Now that this offset has been removed under W7 the same is needed for XP, or I will not be able to have my website synchronized, as I use a W7 and a XP computer, and also want to be able to just copy the files between those computers via the local network.
I have to go back to 4.27 again, as there everything just works.
noftpanymore
Ok, got it: Login Screen, Edit Session, Environment, Adjust Remote Timestamp with DST.
Had to change all files timestamps on the server so now everything everywhere is on the same time and synchronized, XP and Win 7.
