Topic "Using internal editor for root permisioned files"
mahmood
I have asked a question about saving edited files that need sudo password when we use internal editor (http://winscp.net/forum/viewtopic.php?t=8919)
It seems that current version does not support that. So I thought it may be a good idea to request such feature.
As you know, I can open the file (for example .bashrc) with the internal editor and after edit, save it directly.
But what about if I want to edit /etc/apt/sources.list or other text files that need root password?
Please consider that for next releases.
Please read FAQ:
http://winscp.net/eng/docs/faq_su
mahmood
I am confused. I use SFTP to connect to my remote host. I set the SFTP sever to /usr/lib/openssh/sftp-server
What is the next step?
after that I logged in to the remote host. Still I can not view the root folder (/root) or edit /etc/apt/sources.list
