Topic "mv and UNC Path"
ThM
for my SFTP-Filetransfer I need to move any files from remote Source to my local Destination. I try out these command:
mv *.* "\\server\share\directory 1\"
WinSCP try to rename my Sourcefiles but it doesn't move the files. When I use the following commands, with the same Syntax, does it work:
get *.* "\\server\share\directory 1\*.*"
rm *.*
Can anybody help me ?
Regards
Thomas
ThM
I forgot - I use WinSCP 4.2.8 Build 818
rm *.*
Regards
Thomas
Command mv moves from remote directory to another remote directory. Use "get -delete".
Thank you, for your answer.
I try to use these Command.
Regards Thomas
