Topic "SFTP error while setting permissions and/or timestamp"
pedroreys
I've used WinSCP for a while due to its great scripting support. This time I'm trying to connect to a new SFTP server that we just built using WS_FTP.
Every time I transfer a file to that server using WinSCP, using scripting or the UI, I got an error saying the upload of the file was successful, but [url]error occurred while setting permissions and/or timestamp[/url].
As suggested by the error message I turned on the 'Ignore permissions errors' but the problem persisted.
I was using the 4.1.9 version of WinSCP. I then upgraded to the latest version, 4.2.9, and still have the same problem.
The log can be viewed here: http://gist.github.com/605440
Just out of curiosity, I tried to transfer the file using Filezilla UI and it worked fine.
Best Regards
pedroreys
Hi Martin,
Thanks for the link. I have read it yesterday, but I tried the IgnorePermissionErrors flag and it did not work.
But, when I used the -nopreservetime -nopermissions switches, it worked like a charm.
Do you know what may be not allowing winscp to preserve the timestamp? As I said before, I'm using a WS_FTP server and if there is something I can change on the server to allow winscp to preserve timestamp will be even better.
Thanks again for the quick response.
Best Regards,
Pedro Reys
As you can see in the log file, your server seems not to support preserving the timestamp and/or setting permissions.
