Topic "Remote unzip"
lazlo
Hi
I am trying to unzip a remote file.
The syntax I use is unzip "!" which I found on this site.
Getting the message back that cannot find the selected zip file ( error code 9)
Can you give me some pointers what I should do ?
lazlo
Thanks, I have found the solution.
It works if I use SCP for file protocol
