Topic "Error while downloading the file.."
wahanand
I am facing below issue while downloading the file from remote location.Please help.
Copying files from remote side failed.Error message : Received incomplete data packet before end of file.
wahanand
Hi
Thanks a lot for the response.your help will be highly appreciating.One more thing i would like to highlight here is that i am able to upload a text file on the server from my local directory however I am having problem when i am trying to upload the file on to the server.below is the log.
. 2010-10-06 10:14:58.177 --------------------------------------------------------------------------
. 2010-10-06 10:14:58.177 WinSCP Version 4.2.8 (Build 818) (OS 5.2.3790 Service Pack 2)
. 2010-10-06 10:14:58.177 Login time: 06 October 2010 10:14:58 AM
. 2010-10-06 10:14:58.177 Session name: sensitive information removed
. 2010-10-06 10:14:58.177 Host name: sensitive information removed (Port: 22)
. 2010-10-06 10:14:58.177 User name: sensitive information removed (Password: No, Key file: Yes)
. 2010-10-06 10:14:58.177 Tunnel: No
. 2010-10-06 10:14:58.177 Transfer Protocol: SFTP
. 2010-10-06 10:14:58.177 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-10-06 10:14:58.177 Proxy: none
. 2010-10-06 10:14:58.177 SSH protocol version: 2; Compression: No
. 2010-10-06 10:14:58.177 Bypass authentication: No
. 2010-10-06 10:14:58.177 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-10-06 10:14:58.177 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-10-06 10:14:58.177 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-10-06 10:14:58.177 SFTP Bugs: -,-
. 2010-10-06 10:14:58.177 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-10-06 10:14:58.177 Shell: default
. 2010-10-06 10:14:58.177 EOL: 0, UTF: 2
. 2010-10-06 10:14:58.177 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-10-06 10:14:58.177 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-10-06 10:14:58.177 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-10-06 10:14:58.177 Cache directory changes: Yes, Permanent: Yes
. 2010-10-06 10:14:58.177 DST mode: 1
. 2010-10-06 10:14:58.192 Looking up host "sensitive information removed"
. 2010-10-06 10:14:58.192 Connecting to 192.168.21.35 port 22
. 2010-10-06 10:14:58.208 Server version: SSH-2.0-6.0.0.362 SSH Tectia Server
. 2010-10-06 10:14:58.208 We believe remote version has SSH-2 ignore bug
. 2010-10-06 10:14:58.208 Using SSH protocol version 2
. 2010-10-06 10:14:58.208 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-10-06 10:14:58.208 Using Diffie-Hellman with standard group "group1"
. 2010-10-06 10:14:58.208 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-10-06 10:14:58.474 Host key fingerprint is:
. 2010-10-06 10:14:58.474 ssh-rsa 1536 a9:20:49:09:83:70:19:1b:58:9a:35:83:19:f2:0a:fa
. 2010-10-06 10:14:58.474 Initialised AES-256 CBC client->server encryption
. 2010-10-06 10:14:58.474 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-10-06 10:14:58.474 Initialised AES-256 CBC server->client encryption
. 2010-10-06 10:14:58.474 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-10-06 10:14:58.599 Reading private key file "C:\PuttyKeyGenerator\PrivateKey_Alldevdb.ppk"
! 2010-10-06 10:14:58.599 Using username "sensitive information removed".
. 2010-10-06 10:14:58.646 Offered public key
. 2010-10-06 10:14:58.677 Offer of public key accepted
! 2010-10-06 10:14:58.677 Authenticating with public key "rsa-key-20100908"
. 2010-10-06 10:14:58.786 Access granted
. 2010-10-06 10:14:58.786 Opened channel for session
. 2010-10-06 10:14:58.817 Started a shell/command
. 2010-10-06 10:14:58.817 --------------------------------------------------------------------------
. 2010-10-06 10:14:58.817 Using SFTP protocol.
. 2010-10-06 10:14:58.817 Doing startup conversation with host.
> 2010-10-06 10:14:58.817 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-10-06 10:14:58.880 Type: SSH_FXP_VERSION, Size: 34, Number: -1
. 2010-10-06 10:14:58.880 SFTP version 3 negotiated.
. 2010-10-06 10:14:58.880 Unknown server extension newline@vandyke.com="\r\n"
. 2010-10-06 10:14:58.880 We believe the server has signed timestamps bug
. 2010-10-06 10:14:58.880 We will use UTF-8 strings for status messages only
. 2010-10-06 10:14:58.880 Getting current directory name.
. 2010-10-06 10:14:58.880 Getting real path for '.'
> 2010-10-06 10:14:58.880 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-10-06 10:14:58.880 Type: SSH_FXP_NAME, Size: 49, Number: 16
. 2010-10-06 10:14:58.880 Real path is '/C:\'
. 2010-10-06 10:14:58.880 Listing directory "/C:\".
> 2010-10-06 10:14:58.880 Type: SSH_FXP_OPENDIR, Size: 13, Number: 267
< 2010-10-06 10:14:58.896 Type: SSH_FXP_HANDLE, Size: 17, Number: 267
> 2010-10-06 10:14:58.896 Type: SSH_FXP_READDIR, Size: 17, Number: 524
< 2010-10-06 10:14:58.896 Type: SSH_FXP_NAME, Size: 1772, Number: 524
> 2010-10-06 10:14:58.896 Type: SSH_FXP_READDIR, Size: 17, Number: 780
< 2010-10-06 10:14:58.911 Type: SSH_FXP_STATUS, Size: 22, Number: 780
< 2010-10-06 10:14:58.911 Status code: 1
> 2010-10-06 10:14:58.911 Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
. 2010-10-06 10:14:58.911 Startup conversation with host finished.
. 2010-10-06 10:15:45.584 File: "/C:\/AnandTest2.txt"
. 2010-10-06 10:15:45.584 Copying "/C:\/AnandTest2.txt" to local directory started.
. 2010-10-06 10:15:45.584 Ascii transfer mode selected.
. 2010-10-06 10:15:45.584 Opening remote file.
> 2010-10-06 10:15:45.584 Type: SSH_FXP_OPEN, Size: 36, Number: 1283
< 2010-10-06 10:15:45.584 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
. 2010-10-06 10:15:45.584 Discarding reserved response
< 2010-10-06 10:15:45.600 Type: SSH_FXP_HANDLE, Size: 17, Number: 1283
> 2010-10-06 10:15:45.600 Type: SSH_FXP_FSTAT, Size: 17, Number: 1544
> 2010-10-06 10:15:45.600 Type: SSH_FXP_READ, Size: 29, Number: 1797
. 2010-10-06 10:15:45.615 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2010-10-06 10:15:45.615 Type: SSH_FXP_ATTRS, Size: 29, Number: 1544
. 2010-10-06 10:15:45.615 Storing reserved response
. 2010-10-06 10:15:45.678 Received incomplete data packet before end of file, offset: 16877, size: 545, requested: 4083
. 2010-10-06 10:15:45.693 16 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-10-06 10:15:45.693 Type: SSH_FXP_CLOSE, Size: 17, Number: 4356
* 2010-10-06 10:15:45.693 (ECommand) Copying files from remote side failed.
* 2010-10-06 10:15:45.693 Received incomplete data packet before end of file.
Does the size of the file change during upload?
wahanand
yes the size of the file changes.
Can you email me Debug 2-level log file?
wahanand
Hi Below is the Debug-2 Log File.
. 2010-10-11 12:00:11.812 --------------------------------------------------------------------------
. 2010-10-11 12:00:11.812 WinSCP Version 4.2.9 (Build 938) (OS 5.2.3790 Service Pack 2)
. 2010-10-11 12:00:11.812 Login time: 11 October 2010 12:00:11 PM
. 2010-10-11 12:00:11.812 Session name:
. 2010-10-11 12:00:11.812 Host name: (Port: 22)
. 2010-10-11 12:00:11.812 User name: islifaiam (Password: No, Key file: Yes)
. 2010-10-11 12:00:11.812 Tunnel: No
. 2010-10-11 12:00:11.812 Transfer Protocol: SFTP
. 2010-10-11 12:00:11.812 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-10-11 12:00:11.812 Proxy: none
. 2010-10-11 12:00:11.812 SSH protocol version: 2; Compression: No
. 2010-10-11 12:00:11.812 Bypass authentication: No
. 2010-10-11 12:00:11.812 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-10-11 12:00:11.812 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-10-11 12:00:11.812 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-10-11 12:00:11.812 SFTP Bugs: -,-
. 2010-10-11 12:00:11.812 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-10-11 12:00:11.812 Shell: default
. 2010-10-11 12:00:11.812 EOL: 0, UTF: 2
. 2010-10-11 12:00:11.812 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-10-11 12:00:11.812 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-10-11 12:00:11.812 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-10-11 12:00:11.812 Cache directory changes: Yes, Permanent: Yes
. 2010-10-11 12:00:11.812 DST mode: 1
. 2010-10-11 12:00:11.828 Looking up host
. 2010-10-11 12:00:11.828 Connecting to port 22
. 2010-10-11 12:00:11.844 Selecting events 63 for socket 484
. 2010-10-11 12:00:11.844 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:11.844 Looking for incoming data
. 2010-10-11 12:00:11.844 Looking for network events
. 2010-10-11 12:00:11.844 Detected network event
. 2010-10-11 12:00:11.844 Enumerating network events for socket 484
. 2010-10-11 12:00:11.844 Enumerated 18 network events making 18 cumulative events for socket 484
. 2010-10-11 12:00:11.844 Handling network write event on socket 484 with error 0
. 2010-10-11 12:00:11.844 Handling network connect event on socket 484 with error 0
. 2010-10-11 12:00:11.844 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:11.844 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:11.844 Server version: SSH-2.0-6.0.0.362 SSH Tectia Server
. 2010-10-11 12:00:11.844 We believe remote version has SSH-2 ignore bug
. 2010-10-11 12:00:11.844 Using SSH protocol version 2
. 2010-10-11 12:00:11.844 We claim version: SSH-2.0-WinSCP_release_4.2.9
. 2010-10-11 12:00:11.844 Using Diffie-Hellman with standard group "group1"
. 2010-10-11 12:00:11.844 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-10-11 12:00:11.875 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:11.875 Looking for incoming data
. 2010-10-11 12:00:11.875 Looking for network events
. 2010-10-11 12:00:12.109 Detected network event
. 2010-10-11 12:00:12.109 Enumerating network events for socket 484
. 2010-10-11 12:00:12.109 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.109 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.140 Selecting events 63 for socket 484
. 2010-10-11 12:00:12.140 Host key fingerprint is:
. 2010-10-11 12:00:12.140 ssh-rsa 1536 a9:20:49:09:83:70:19:1b:58:9a:35:83:19:f2:0a:fa
. 2010-10-11 12:00:12.140 Initialised AES-256 CBC client->server encryption
. 2010-10-11 12:00:12.140 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-10-11 12:00:12.140 Initialised AES-256 CBC server->client encryption
. 2010-10-11 12:00:12.140 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-10-11 12:00:12.140 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.140 Looking for incoming data
. 2010-10-11 12:00:12.140 Looking for network events
. 2010-10-11 12:00:12.265 Detected network event
. 2010-10-11 12:00:12.265 Enumerating network events for socket 484
. 2010-10-11 12:00:12.265 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.265 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.265 Reading private key file "C:\PuttyKeyGenerator\PrivateKey_Alldevdb.ppk"
! 2010-10-11 12:00:12.265 Using username "islifaiam".
. 2010-10-11 12:00:12.265 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.265 Looking for incoming data
. 2010-10-11 12:00:12.265 Looking for network events
. 2010-10-11 12:00:12.312 Detected network event
. 2010-10-11 12:00:12.312 Enumerating network events for socket 484
. 2010-10-11 12:00:12.312 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.312 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.312 Offered public key
. 2010-10-11 12:00:12.312 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.312 Looking for incoming data
. 2010-10-11 12:00:12.312 Looking for network events
. 2010-10-11 12:00:12.344 Detected network event
. 2010-10-11 12:00:12.344 Enumerating network events for socket 484
. 2010-10-11 12:00:12.344 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.344 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.344 Offer of public key accepted
! 2010-10-11 12:00:12.344 Authenticating with public key "rsa-key-20100908"
. 2010-10-11 12:00:12.437 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.437 Looking for incoming data
. 2010-10-11 12:00:12.437 Looking for network events
. 2010-10-11 12:00:12.453 Detected network event
. 2010-10-11 12:00:12.453 Enumerating network events for socket 484
. 2010-10-11 12:00:12.453 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.453 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.453 Access granted
. 2010-10-11 12:00:12.453 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.453 Looking for incoming data
. 2010-10-11 12:00:12.453 Looking for network events
. 2010-10-11 12:00:12.453 Opened channel for session
. 2010-10-11 12:00:12.453 Enumerated 0 network events making 0 cumulative events for socket 484
. 2010-10-11 12:00:12.594 Detected network event
. 2010-10-11 12:00:12.594 Enumerating network events for socket 484
. 2010-10-11 12:00:12.594 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.594 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.594 Started a shell/command
. 2010-10-11 12:00:12.594 --------------------------------------------------------------------------
. 2010-10-11 12:00:12.594 Using SFTP protocol.
. 2010-10-11 12:00:12.594 Doing startup conversation with host.
> 2010-10-11 12:00:12.594 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2010-10-11 12:00:12.594 01,00,00,00,05,
. 2010-10-11 12:00:12.594 Sent 9 bytes
. 2010-10-11 12:00:12.594 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.594 Looking for network events
. 2010-10-11 12:00:12.594 Timeout waiting for network events
. 2010-10-11 12:00:12.594 Waiting for another 4 bytes
. 2010-10-11 12:00:12.594 Looking for incoming data
. 2010-10-11 12:00:12.640 Detected network event
. 2010-10-11 12:00:12.640 Enumerating network events for socket 484
. 2010-10-11 12:00:12.640 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.640 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.640 Received 5 bytes (0)
. 2010-10-11 12:00:12.640 Received 33 bytes (0)
. 2010-10-11 12:00:12.640 Read 4 bytes (34 pending)
. 2010-10-11 12:00:12.640 Read 34 bytes (0 pending)
< 2010-10-11 12:00:12.640 Type: SSH_FXP_VERSION, Size: 34, Number: -1
< 2010-10-11 12:00:12.640 02,00,00,00,03,00,00,00,13,6E,65,77,6C,69,6E,65,40,76,61,6E,64,79,6B,65,2E,
< 2010-10-11 12:00:12.640 63,6F,6D,00,00,00,02,0D,0A,
. 2010-10-11 12:00:12.640 SFTP version 3 negotiated.
. 2010-10-11 12:00:12.640 Unknown server extension newline@vandyke.com="\r\n"
. 2010-10-11 12:00:12.640 We believe the server has signed timestamps bug
. 2010-10-11 12:00:12.640 We will use UTF-8 strings for status messages only
. 2010-10-11 12:00:12.640 Getting current directory name.
. 2010-10-11 12:00:12.640 Getting real path for '.'
> 2010-10-11 12:00:12.640 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2010-10-11 12:00:12.640 10,00,00,00,10,00,00,00,01,2E,
. 2010-10-11 12:00:12.640 Sent 14 bytes
. 2010-10-11 12:00:12.640 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.640 Looking for network events
. 2010-10-11 12:00:12.640 Timeout waiting for network events
. 2010-10-11 12:00:12.640 Waiting for another 4 bytes
. 2010-10-11 12:00:12.640 Looking for incoming data
. 2010-10-11 12:00:12.656 Received 5 bytes (0)
. 2010-10-11 12:00:12.656 Read 4 bytes (1 pending)
. 2010-10-11 12:00:12.656 Waiting for another 48 bytes
. 2010-10-11 12:00:12.656 Looking for incoming data
. 2010-10-11 12:00:12.656 Looking for network events
. 2010-10-11 12:00:12.656 Detected network event
. 2010-10-11 12:00:12.656 Enumerating network events for socket 484
. 2010-10-11 12:00:12.656 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.656 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.656 Received 48 bytes (0)
. 2010-10-11 12:00:12.656 Read 49 bytes (0 pending)
< 2010-10-11 12:00:12.656 Type: SSH_FXP_NAME, Size: 49, Number: 16
< 2010-10-11 12:00:12.656 68,00,00,00,10,00,00,00,01,00,00,00,04,2F,43,3A,5C,00,00,00,04,2F,43,3A,5C,
< 2010-10-11 12:00:12.656 00,00,00,0D,00,00,00,00,00,00,00,00,00,00,41,C0,4C,B2,DF,EC,4C,B2,BE,C2,
. 2010-10-11 12:00:12.656 Real path is '/C:\'
. 2010-10-11 12:00:12.656 Listing directory "/C:\".
> 2010-10-11 12:00:12.656 Type: SSH_FXP_OPENDIR, Size: 13, Number: 267
> 2010-10-11 12:00:12.656 0B,00,00,01,0B,00,00,00,04,2F,43,3A,5C,
. 2010-10-11 12:00:12.656 Sent 17 bytes
. 2010-10-11 12:00:12.656 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.656 Timeout waiting for network events
. 2010-10-11 12:00:12.656 Waiting for another 4 bytes
. 2010-10-11 12:00:12.672 Detected network event
. 2010-10-11 12:00:12.672 Enumerating network events for socket 484
. 2010-10-11 12:00:12.672 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.672 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.672 Received 5 bytes (0)
. 2010-10-11 12:00:12.672 Received 16 bytes (0)
. 2010-10-11 12:00:12.672 Read 4 bytes (17 pending)
. 2010-10-11 12:00:12.672 Read 17 bytes (0 pending)
< 2010-10-11 12:00:12.672 Type: SSH_FXP_HANDLE, Size: 17, Number: 267
< 2010-10-11 12:00:12.672 66,00,00,01,0B,00,00,00,08,00,7F,F9,48,00,7F,33,38,
> 2010-10-11 12:00:12.672 Type: SSH_FXP_READDIR, Size: 17, Number: 524
> 2010-10-11 12:00:12.672 0C,00,00,02,0C,00,00,00,08,00,7F,F9,48,00,7F,33,38,
. 2010-10-11 12:00:12.672 Sent 21 bytes
. 2010-10-11 12:00:12.672 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.672 Looking for network events
. 2010-10-11 12:00:12.672 Timeout waiting for network events
. 2010-10-11 12:00:12.672 Waiting for another 4 bytes
. 2010-10-11 12:00:12.672 Looking for incoming data
. 2010-10-11 12:00:12.672 Read 4 bytes (1 pending)
. 2010-10-11 12:00:12.672 Waiting for another 3126 bytes
. 2010-10-11 12:00:12.687 Detected network event
. 2010-10-11 12:00:12.687 Enumerating network events for socket 484
. 2010-10-11 12:00:12.687 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.687 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.687 Received 128 bytes (0)
. 2010-10-11 12:00:12.687 Received 256 bytes (0)
. 2010-10-11 12:00:12.687 Waiting for another 2742 bytes
. 2010-10-11 12:00:12.687 Looking for incoming data
. 2010-10-11 12:00:12.687 Looking for network events
. 2010-10-11 12:00:12.687 Received 512 bytes (0)
. 2010-10-11 12:00:12.687 Received 1024 bytes (0)
. 2010-10-11 12:00:12.687 Waiting for another 1206 bytes
. 2010-10-11 12:00:12.687 Received 1206 bytes (0)
. 2010-10-11 12:00:12.687 Read 3127 bytes (0 pending)
< 2010-10-11 12:00:12.687 Type: SSH_FXP_NAME, Size: 3127, Number: 524
< 2010-10-11 12:00:12.687 68,00,00,02,0C,00,00,00,16,00,00,00,01,2E,00,00,00,39,64,72,77,78,2D,2D,2D,
< 2010-10-11 12:00:12.687 2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,30,20,4F,63,74,20,31,31,20,20,39,3A,33,37,20,2E,2F,
< 2010-10-11 12:00:12.687 00,00,00,0D,00,00,00,00,00,00,00,00,00,00,41,C0,4C,B2,DF,EC,4C,B2,BE,C2,00,
< 2010-10-11 12:00:12.687 00,00,02,2E,2E,00,00,00,3A,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,30,
< 2010-10-11 12:00:12.687 20,53,65,70,20,32,38,20,31,35,3A,33,31,20,2E,2E,2F,00,00,00,0D,00,00,00,00,
< 2010-10-11 12:00:12.687 00,00,00,00,00,00,41,C0,4C,B2,DF,E9,4C,A1,EE,47,00,00,00,09,45,72,72,6F,72,
< 2010-10-11 12:00:12.687 2E,6C,6F,67,00,00,00,40,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,38,39,35,34,20,
< 2010-10-11 12:00:12.687 4F,63,74,20,20,38,20,31,30,3A,35,39,20,45,72,72,6F,72,2E,6C,6F,67,00,00,00,
< 2010-10-11 12:00:12.687 0D,00,00,00,00,00,00,22,FA,00,00,81,80,4C,AF,0D,61,4C,AE,DD,80,00,00,00,13,
< 2010-10-11 12:00:12.687 49,73,6C,49,66,61,49,61,6D,50,76,74,4B,65,79,2E,70,70,6B,00,00,00,4A,2D,72,
< 2010-10-11 12:00:12.687 77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,20,20,20,38,36,39,20,53,65,70,20,20,37,20,31,31,3A,
< 2010-10-11 12:00:12.687 35,31,20,49,73,6C,49,66,61,49,61,6D,50,76,74,4B,65,79,2E,70,70,6B,00,00,00,
< 2010-10-11 12:00:12.687 0D,00,00,00,00,00,00,03,65,00,00,81,80,4C,AF,0D,61,4C,86,0B,05,00,00,00,20,
< 2010-10-11 12:00:12.687 49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,30,39,32,39,5F,30,30,30,
< 2010-10-11 12:00:12.687 30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,
< 2010-10-11 12:00:12.687 20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,33,
< 2010-10-11 12:00:12.687 32,34,20,4F,63,74,20,20,38,20,31,37,3A,31,38,20,49,53,4C,5F,48,6F,6C,64,69,
< 2010-10-11 12:00:12.687 6E,67,73,5F,32,30,31,30,30,39,32,39,5F,30,30,30,30,30,30,2E,74,78,74,00,00,
< 2010-10-11 12:00:12.687 00,0D,00,00,00,00,00,00,01,44,00,00,81,80,4C,AF,36,35,4C,AF,36,35,00,00,00,
< 2010-10-11 12:00:12.687 20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,30,39,33,30,5F,30,30,
< 2010-10-11 12:00:12.687 30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,
< 2010-10-11 12:00:12.687 31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 33,32,33,20,4F,63,74,20,20,38,20,31,37,3A,31,39,20,49,53,4C,5F,48,6F,6C,64,
< 2010-10-11 12:00:12.687 69,6E,67,73,5F,32,30,31,30,30,39,33,30,5F,30,30,30,30,30,30,2E,74,78,74,00,
< 2010-10-11 12:00:12.687 00,00,0D,00,00,00,00,00,00,01,43,00,00,81,80,4C,AF,36,97,4C,AF,36,97,00,00,
< 2010-10-11 12:00:12.687 00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,31,5F,30,
< 2010-10-11 12:00:12.687 30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,
< 2010-10-11 12:00:12.687 20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,33,32,33,20,4F,63,74,20,20,38,20,31,37,3A,32,32,20,49,53,4C,5F,48,6F,6C,
< 2010-10-11 12:00:12.687 64,69,6E,67,73,5F,32,30,31,30,31,30,30,31,5F,30,30,30,30,30,30,2E,74,78,74,
< 2010-10-11 12:00:12.687 00,00,00,0D,00,00,00,00,00,00,01,43,00,00,81,80,4C,AF,37,24,4C,AF,37,24,00,
< 2010-10-11 12:00:12.687 00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,34,5F,
< 2010-10-11 12:00:12.687 30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,
< 2010-10-11 12:00:12.687 20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,33,32,34,20,4F,63,74,20,20,38,20,31,38,3A,30,37,20,49,53,4C,5F,48,6F,
< 2010-10-11 12:00:12.687 6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,34,5F,30,30,30,30,30,30,2E,74,78,
< 2010-10-11 12:00:12.687 74,00,00,00,0D,00,00,00,00,00,00,01,44,00,00,81,80,4C,AF,41,B4,4C,AF,41,B4,
< 2010-10-11 12:00:12.687 00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,35,
< 2010-10-11 12:00:12.687 5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,32,31,32,20,4F,63,74,20,20,38,20,31,38,3A,30,37,20,49,53,4C,5F,48,
< 2010-10-11 12:00:12.687 6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,35,5F,30,30,30,30,30,30,2E,74,
< 2010-10-11 12:00:12.687 78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,AF,41,D3,4C,AF,41,
< 2010-10-11 12:00:12.687 D3,00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,
< 2010-10-11 12:00:12.687 36,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,32,31,32,20,4F,63,74,20,20,38,20,31,37,3A,32,34,20,49,53,4C,5F,
< 2010-10-11 12:00:12.687 48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,36,5F,30,30,30,30,30,30,2E,
< 2010-10-11 12:00:12.687 74,78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,AF,37,96,4C,AF,
< 2010-10-11 12:00:12.687 37,97,00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,
< 2010-10-11 12:00:12.687 30,37,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,32,31,32,20,4F,63,74,20,20,38,20,31,37,3A,32,35,20,49,53,4C,
< 2010-10-11 12:00:12.687 5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,37,5F,30,30,30,30,30,30,
< 2010-10-11 12:00:12.687 2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,AF,37,D4,4C,
< 2010-10-11 12:00:12.687 AF,37,D4,00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,
< 2010-10-11 12:00:12.687 30,30,38,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,32,31,32,20,4F,63,74,20,31,31,20,20,39,3A,32,35,20,49,53,
< 2010-10-11 12:00:12.687 4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,30,30,
< 2010-10-11 12:00:12.687 30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,B2,BB,F1,
< 2010-10-11 12:00:12.687 4C,B2,BB,F1,00,00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,
< 2010-10-11 12:00:12.687 32,30,31,30,30,39,32,39,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,2D,72,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,20,20,20,36,30,33,20,4F,63,74,20,20,38,20,31,38,3A,
< 2010-10-11 12:00:12.687 30,38,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,30,
< 2010-10-11 12:00:12.687 39,32,39,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,02,
< 2010-10-11 12:00:12.687 5B,00,00,81,80,4C,AF,42,10,4C,AF,42,12,00,00,00,24,49,53,4C,5F,54,72,61,6E,
< 2010-10-11 12:00:12.687 73,61,63,74,69,6F,6E,73,5F,32,30,31,30,30,39,33,30,5F,30,30,30,30,30,30,2E,
< 2010-10-11 12:00:12.687 74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,32,32,33,20,4F,
< 2010-10-11 12:00:12.687 63,74,20,20,38,20,31,38,3A,31,30,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,
< 2010-10-11 12:00:12.687 6F,6E,73,5F,32,30,31,30,30,39,33,30,5F,30,30,30,30,30,30,2E,74,78,74,00,00,
< 2010-10-11 12:00:12.687 00,0D,00,00,00,00,00,00,00,DF,00,00,81,80,4C,AF,42,79,4C,AF,42,7A,00,00,00,
< 2010-10-11 12:00:12.687 24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,
< 2010-10-11 12:00:12.687 31,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,20,39,37,37,20,4F,63,74,20,20,38,20,31,38,3A,31,33,20,49,53,4C,5F,
< 2010-10-11 12:00:12.687 54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,31,5F,30,30,30,
< 2010-10-11 12:00:12.687 30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,03,D1,00,00,81,80,4C,AF,
< 2010-10-11 12:00:12.687 43,0F,4C,AF,43,10,00,00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,
< 2010-10-11 12:00:12.687 73,5F,32,30,31,30,31,30,30,34,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,
< 2010-10-11 12:00:12.687 2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,20,20,20,20,20,32,32,33,20,4F,63,74,20,20,38,20,31,
< 2010-10-11 12:00:12.687 38,3A,31,33,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,
< 2010-10-11 12:00:12.687 30,31,30,30,34,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,
< 2010-10-11 12:00:12.687 00,00,DF,00,00,81,80,4C,AF,43,3F,4C,AF,43,3F,00,00,00,24,49,53,4C,5F,54,72,
< 2010-10-11 12:00:12.687 61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,35,5F,30,30,30,30,30,
< 2010-10-11 12:00:12.687 30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,36,31,35,
< 2010-10-11 12:00:12.687 20,4F,63,74,20,20,38,20,31,38,3A,32,39,20,49,53,4C,5F,54,72,61,6E,73,61,63,
< 2010-10-11 12:00:12.687 74,69,6F,6E,73,5F,32,30,31,30,31,30,30,35,5F,30,30,30,30,30,30,2E,74,78,74,
< 2010-10-11 12:00:12.687 00,00,00,0D,00,00,00,00,00,00,02,67,00,00,81,80,4C,AF,46,E4,4C,AF,46,EA,00,
< 2010-10-11 12:00:12.687 00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,
< 2010-10-11 12:00:12.687 30,30,36,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,32,32,33,20,4F,63,74,20,20,38,20,31,38,3A,32,30,20,49,53,
< 2010-10-11 12:00:12.687 4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,36,5F,30,
< 2010-10-11 12:00:12.687 30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,00,DF,00,00,81,80,
< 2010-10-11 12:00:12.703 4C,B2,E0,16,4C,AF,44,B0,00,00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,
< 2010-10-11 12:00:12.703 6F,6E,73,5F,32,30,31,30,31,30,30,37,5F,30,30,30,30,30,30,2E,74,78,74,00,00,
< 2010-10-11 12:00:12.703 00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.703 20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,32,32,33,20,4F,63,74,20,20,38,
< 2010-10-11 12:00:12.703 20,31,38,3A,32,30,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,
< 2010-10-11 12:00:12.703 30,31,30,31,30,30,37,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,
< 2010-10-11 12:00:12.703 00,00,00,00,DF,00,00,81,80,4C,AF,44,E1,4C,AF,44,E1,00,00,00,24,49,53,4C,5F,
< 2010-10-11 12:00:12.703 54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,
< 2010-10-11 12:00:12.703 30,30,30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,
< 2010-10-11 12:00:12.703 20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,34,
< 2010-10-11 12:00:12.703 31,33,20,4F,63,74,20,31,31,20,20,39,3A,32,35,20,49,53,4C,5F,54,72,61,6E,73,
< 2010-10-11 12:00:12.703 61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,30,30,30,2E,74,
< 2010-10-11 12:00:12.703 78,74,00,00,00,0D,00,00,00,00,00,00,01,9D,00,00,81,80,4C,B2,BB,F0,4C,B2,BB,
< 2010-10-11 12:00:12.703 F0,00,00,00,0D,74,65,73,74,61,6E,61,6E,64,2E,74,78,74,00,00,00,44,2D,72,77,
< 2010-10-11 12:00:12.703 2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,
< 2010-10-11 12:00:12.703 20,20,20,20,20,20,20,20,20,20,20,32,31,20,4F,63,74,20,20,35,20,31,32,3A,33,
< 2010-10-11 12:00:12.703 33,20,74,65,73,74,61,6E,61,6E,64,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,
< 2010-10-11 12:00:12.703 00,15,00,00,81,80,4C,AF,0D,62,4C,AA,FF,03,00,00,00,0D,57,69,6E,53,63,70,4C,
< 2010-10-11 12:00:12.703 6F,67,2E,6C,6F,67,00,00,00,44,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,
< 2010-10-11 12:00:12.703 30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,32,33,31,39,
< 2010-10-11 12:00:12.703 34,20,4F,63,74,20,20,36,20,31,35,3A,33,38,20,57,69,6E,53,63,70,4C,6F,67,2E,
< 2010-10-11 12:00:12.703 6C,6F,67,00,00,00,0D,00,00,00,00,00,00,5A,9A,00,00,81,80,4C,B2,CE,1F,4C,AC,
< 2010-10-11 12:00:12.703 7B,C9,
> 2010-10-11 12:00:12.703 Type: SSH_FXP_READDIR, Size: 17, Number: 780
> 2010-10-11 12:00:12.703 0C,00,00,03,0C,00,00,00,08,00,7F,F9,48,00,7F,33,38,
. 2010-10-11 12:00:12.703 Sent 21 bytes
. 2010-10-11 12:00:12.703 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.703 Looking for network events
. 2010-10-11 12:00:12.703 Timeout waiting for network events
. 2010-10-11 12:00:12.703 Read file '.' from listing
. 2010-10-11 12:00:12.703 Read file '..' from listing
. 2010-10-11 12:00:12.703 Read file 'Error.log' from listing
. 2010-10-11 12:00:12.703 Read file 'IslIfaIamPvtKey.ppk' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20100929_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20100930_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101001_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101004_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101005_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101006_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101007_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101008_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20100929_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20100930_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101001_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101004_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101005_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101006_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101007_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101008_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'testanand.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'WinScpLog.log' from listing
. 2010-10-11 12:00:12.703 Waiting for another 4 bytes
. 2010-10-11 12:00:12.703 Looking for incoming data
. 2010-10-11 12:00:12.703 Detected network event
. 2010-10-11 12:00:12.703 Enumerating network events for socket 484
. 2010-10-11 12:00:12.703 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.703 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.703 Received 5 bytes (0)
. 2010-10-11 12:00:12.703 Received 21 bytes (0)
. 2010-10-11 12:00:12.703 Read 4 bytes (22 pending)
. 2010-10-11 12:00:12.703 Read 22 bytes (0 pending)
< 2010-10-11 12:00:12.703 Type: SSH_FXP_STATUS, Size: 22, Number: 780
< 2010-10-11 12:00:12.703 65,00,00,03,0C,00,00,00,01,00,00,00,03,45,4F,46,00,00,00,02,65,6E,
< 2010-10-11 12:00:12.703 Status code: 1
> 2010-10-11 12:00:12.703 Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
> 2010-10-11 12:00:12.703 04,00,00,04,04,00,00,00,08,00,7F,F9,48,00,7F,33,38,
. 2010-10-11 12:00:12.703 Startup conversation with host finished.
. 2010-10-11 12:00:13.531 Session upkeep
. 2010-10-11 12:00:13.531 Looking for network events
. 2010-10-11 12:00:13.531 Detected network event
. 2010-10-11 12:00:13.531 Enumerating network events for socket 484
. 2010-10-11 12:00:13.531 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:13.531 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:13.531 Received 5 bytes (0)
. 2010-10-11 12:00:13.531 Received 20 bytes (0)
. 2010-10-11 12:00:14.031 Session upkeep
. 2010-10-11 12:00:14.031 Looking for network events
. 2010-10-11 12:00:14.031 Timeout waiting for network events
. 2010-10-11 12:00:14.531 Session upkeep
. 2010-10-11 12:00:14.531 Looking for network events
. 2010-10-11 12:00:14.531 Timeout waiting for network events
. 2010-10-11 12:00:15.031 Session upkeep
. 2010-10-11 12:00:15.031 Looking for network events
. 2010-10-11 12:00:15.031 Timeout waiting for network events
. 2010-10-11 12:00:15.531 Session upkeep
. 2010-10-11 12:00:15.531 Looking for network events
. 2010-10-11 12:00:15.531 Timeout waiting for network events
. 2010-10-11 12:00:16.031 Session upkeep
. 2010-10-11 12:00:16.031 Looking for network events
. 2010-10-11 12:00:16.031 Timeout waiting for network events
. 2010-10-11 12:00:16.531 Session upkeep
. 2010-10-11 12:00:16.531 Looking for network events
. 2010-10-11 12:00:16.531 Timeout waiting for network events
. 2010-10-11 12:00:17.031 Session upkeep
. 2010-10-11 12:00:17.031 Looking for network events
. 2010-10-11 12:00:17.031 Timeout waiting for network events
. 2010-10-11 12:00:17.531 Session upkeep
. 2010-10-11 12:00:17.531 Looking for network events
. 2010-10-11 12:00:17.531 Timeout waiting for network events
. 2010-10-11 12:00:18.031 Session upkeep
. 2010-10-11 12:00:18.031 Looking for network events
. 2010-10-11 12:00:18.031 Timeout waiting for network events
. 2010-10-11 12:00:18.531 Session upkeep
. 2010-10-11 12:00:18.531 Looking for network events
. 2010-10-11 12:00:18.531 Timeout waiting for network events
. 2010-10-11 12:00:19.031 Session upkeep
. 2010-10-11 12:00:19.031 Looking for network events
. 2010-10-11 12:00:19.031 Timeout waiting for network events
. 2010-10-11 12:00:19.609 Session upkeep
. 2010-10-11 12:00:19.797 Looking for network events
. 2010-10-11 12:00:19.797 Timeout waiting for network events
. 2010-10-11 12:00:20.031 Session upkeep
. 2010-10-11 12:00:20.031 Looking for network events
. 2010-10-11 12:00:20.031 Timeout waiting for network events
. 2010-10-11 12:00:20.531 Session upkeep
. 2010-10-11 12:00:20.531 Looking for network events
. 2010-10-11 12:00:20.531 Timeout waiting for network events
. 2010-10-11 12:00:21.031 Session upkeep
. 2010-10-11 12:00:21.031 Looking for network events
. 2010-10-11 12:00:21.031 Timeout waiting for network events
. 2010-10-11 12:00:21.531 Session upkeep
. 2010-10-11 12:00:21.531 Looking for network events
. 2010-10-11 12:00:21.531 Timeout waiting for network events
. 2010-10-11 12:00:22.031 Session upkeep
. 2010-10-11 12:00:22.031 Looking for network events
. 2010-10-11 12:00:22.031 Timeout waiting for network events
. 2010-10-11 12:00:22.531 Session upkeep
. 2010-10-11 12:00:22.531 Looking for network events
. 2010-10-11 12:00:22.531 Timeout waiting for network events
. 2010-10-11 12:00:23.031 Session upkeep
. 2010-10-11 12:00:23.031 Looking for network events
. 2010-10-11 12:00:23.031 Timeout waiting for network events
. 2010-10-11 12:00:23.531 Session upkeep
. 2010-10-11 12:00:23.531 Looking for network events
. 2010-10-11 12:00:23.531 Timeout waiting for network events
. 2010-10-11 12:00:24.031 Session upkeep
. 2010-10-11 12:00:24.031 Looking for network events
. 2010-10-11 12:00:24.031 Timeout waiting for network events
. 2010-10-11 12:00:24.531 Session upkeep
. 2010-10-11 12:00:24.531 Looking for network events
. 2010-10-11 12:00:24.531 Timeout waiting for network events
. 2010-10-11 12:00:25.031 Session upkeep
. 2010-10-11 12:00:25.031 Looking for network events
. 2010-10-11 12:00:25.031 Timeout waiting for network events
. 2010-10-11 12:00:25.531 Session upkeep
. 2010-10-11 12:00:25.531 Looking for network events
. 2010-10-11 12:00:25.531 Timeout waiting for network events
. 2010-10-11 12:00:25.922 File: "/C:\/ISL_Transactions_20101008_000000.txt"
. 2010-10-11 12:00:25.922 Copying "/C:\/ISL_Transactions_20101008_000000.txt" to local directory started.
. 2010-10-11 12:00:25.922 Ascii transfer mode selected.
. 2010-10-11 12:00:25.922 Opening remote file.
> 2010-10-11 12:00:25.922 Type: SSH_FXP_OPEN, Size: 58, Number: 1283
> 2010-10-11 12:00:25.922 03,00,00,05,03,00,00,00,29,2F,43,3A,5C,2F,49,53,4C,5F,54,72,61,6E,73,61,63,
> 2010-10-11 12:00:25.922 74,69,6F,6E,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,30,30,30,2E,74,78,74,
> 2010-10-11 12:00:25.922 00,00,00,01,00,00,00,00,
. 2010-10-11 12:00:25.922 Sent 62 bytes
. 2010-10-11 12:00:25.922 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.922 Looking for network events
. 2010-10-11 12:00:25.922 Timeout waiting for network events
. 2010-10-11 12:00:25.922 Read 4 bytes (21 pending)
. 2010-10-11 12:00:25.922 Read 21 bytes (0 pending)
< 2010-10-11 12:00:25.922 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
< 2010-10-11 12:00:25.922 65,00,00,04,04,00,00,00,00,00,00,00,02,4F,4B,00,00,00,02,65,6E,
. 2010-10-11 12:00:25.922 Discarding reserved response
. 2010-10-11 12:00:25.922 Waiting for another 4 bytes
. 2010-10-11 12:00:25.922 Looking for incoming data
. 2010-10-11 12:00:25.938 Detected network event
. 2010-10-11 12:00:25.938 Enumerating network events for socket 484
. 2010-10-11 12:00:25.938 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:25.938 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:25.938 Received 5 bytes (0)
. 2010-10-11 12:00:25.938 Received 16 bytes (0)
. 2010-10-11 12:00:25.938 Read 4 bytes (17 pending)
. 2010-10-11 12:00:25.938 Read 17 bytes (0 pending)
< 2010-10-11 12:00:25.938 Type: SSH_FXP_HANDLE, Size: 17, Number: 1283
< 2010-10-11 12:00:25.938 66,00,00,05,03,00,00,00,08,00,7F,F9,48,00,80,2B,40,
> 2010-10-11 12:00:25.938 Type: SSH_FXP_FSTAT, Size: 17, Number: 1544
> 2010-10-11 12:00:25.938 08,00,00,06,08,00,00,00,08,00,7F,F9,48,00,80,2B,40,
. 2010-10-11 12:00:25.938 Sent 21 bytes
. 2010-10-11 12:00:25.938 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.938 Looking for network events
. 2010-10-11 12:00:25.938 Timeout waiting for network events
> 2010-10-11 12:00:25.938 Type: SSH_FXP_READ, Size: 29, Number: 1797
> 2010-10-11 12:00:25.938 05,00,00,07,05,00,00,00,08,00,7F,F9,48,00,80,2B,40,00,00,00,00,00,00,00,00,
> 2010-10-11 12:00:25.938 00,00,0F,F3,
. 2010-10-11 12:00:25.938 Sent 33 bytes
. 2010-10-11 12:00:25.938 Waiting for another 4 bytes
. 2010-10-11 12:00:25.938 Looking for incoming data
. 2010-10-11 12:00:25.938 Received 12 bytes (0)
. 2010-10-11 12:00:25.938 Read 4 bytes (29 pending)
. 2010-10-11 12:00:25.938 Read 29 bytes (0 pending)
< 2010-10-11 12:00:25.938 Type: SSH_FXP_ATTRS, Size: 29, Number: 1544
< 2010-10-11 12:00:25.938 69,00,00,06,08,00,00,00,0D,00,00,00,00,00,00,01,9D,00,00,81,80,4C,B2,BB,F0,
< 2010-10-11 12:00:25.938 4C,B2,BB,F0,
. 2010-10-11 12:00:25.938 Storing reserved response
. 2010-10-11 12:00:25.953 Detected network event
. 2010-10-11 12:00:25.953 Enumerating network events for socket 484
. 2010-10-11 12:00:25.953 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:25.953 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:25.953 Waiting for another 4 bytes
. 2010-10-11 12:00:25.953 Looking for incoming data
. 2010-10-11 12:00:25.953 Looking for network events
. 2010-10-11 12:00:25.953 Received 5 bytes (0)
. 2010-10-11 12:00:25.953 Received 8 bytes (0)
. 2010-10-11 12:00:25.953 Read 4 bytes (9 pending)
. 2010-10-11 12:00:25.953 Waiting for another 413 bytes
. 2010-10-11 12:00:25.953 Received 16 bytes (0)
. 2010-10-11 12:00:25.953 Received 32 bytes (0)
. 2010-10-11 12:00:25.953 Received 64 bytes (0)
. 2010-10-11 12:00:25.953 Waiting for another 301 bytes
. 2010-10-11 12:00:25.953 Received 128 bytes (0)
. 2010-10-11 12:00:25.953 Received 173 bytes (0)
. 2010-10-11 12:00:25.953 Read 422 bytes (0 pending)
< 2010-10-11 12:00:25.953 Type: SSH_FXP_DATA, Size: 422, Number: 1797
< 2010-10-11 12:00:25.953 67,00,00,07,05,00,00,01,9D,50,53,50,5F,41,63,63,6F,75,6E,74,5F,43,6F,64,65,
< 2010-10-11 12:00:25.953 7C,44,61,74,65,5F,41,63,74,69,6F,6E,7C,44,61,74,65,5F,54,72,61,6E,73,61,63,
< 2010-10-11 12:00:25.953 74,69,6F,6E,7C,44,65,73,63,72,69,70,74,69,6F,6E,7C,54,72,61,6E,73,61,63,74,
< 2010-10-11 12:00:25.953 69,6F,6E,5F,54,79,70,65,7C,43,47,54,5F,41,6D,6F,75,6E,74,7C,41,6D,6F,75,6E,
< 2010-10-11 12:00:25.953 74,7C,4E,61,72,72,61,74,69,76,65,7C,50,72,6F,76,69,64,65,72,7C,43,75,72,72,
< 2010-10-11 12:00:25.953 65,6E,63,79,7C,52,65,66,65,72,65,6E,63,65,7C,51,75,61,6E,74,69,74,79,7C,50,
< 2010-10-11 12:00:25.953 72,69,63,65,7C,42,72,6F,6B,65,72,5F,46,65,65,73,7C,54,72,61,64,65,5F,43,6F,
< 2010-10-11 12:00:25.953 73,74,73,7C,47,72,6F,73,73,5F,41,6D,6F,75,6E,74,7C,50,53,50,5F,49,6E,73,74,
< 2010-10-11 12:00:25.953 72,75,6D,65,6E,74,5F,43,6F,64,65,7C,50,53,50,5F,49,6E,73,74,72,75,6D,65,6E,
< 2010-10-11 12:00:25.953 74,5F,4E,61,6D,65,0A,31,33,33,33,37,36,34,7C,30,38,20,4F,63,74,20,32,30,31,
< 2010-10-11 12:00:25.953 30,7C,30,38,20,4F,63,74,20,32,30,31,30,7C,44,49,56,2E,20,31,30,30,20,43,49,
< 2010-10-11 12:00:25.953 50,4C,41,4D,45,44,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:25.953 20,20,20,20,7C,44,56,7C,7C,2D,35,2E,30,30,30,30,30,30,7C,44,49,56,2E,20,31,
< 2010-10-11 12:00:25.953 30,30,20,43,49,50,4C,41,4D,45,44,20,20,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:25.953 20,20,20,20,20,20,20,20,20,7C,37,34,33,31,35,7C,5A,41,52,7C,7C,2E,30,30,30,
< 2010-10-11 12:00:25.953 30,30,30,7C,31,2E,30,30,30,30,30,30,7C,2E,30,30,30,30,30,30,7C,2E,30,30,30,
< 2010-10-11 12:00:25.953 30,30,30,7C,2E,30,30,30,30,30,30,7C,43,61,73,68,7C,43,61,73,68,0A,
> 2010-10-11 12:00:25.953 Type: SSH_FXP_READ, Size: 29, Number: 2053
> 2010-10-11 12:00:25.953 05,00,00,08,05,00,00,00,08,00,7F,F9,48,00,80,2B,40,00,00,00,00,00,00,0F,F3,
> 2010-10-11 12:00:25.953 00,00,0F,F3,
. 2010-10-11 12:00:25.953 Sent 33 bytes
. 2010-10-11 12:00:25.953 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.953 Timeout waiting for network events
. 2010-10-11 12:00:25.953 Read 9 bytes (0 pending)
< 2010-10-11 12:00:25.953 Type: SSH_FXP_DATA, Size: 9, Number: 2053
< 2010-10-11 12:00:25.953 67,00,00,08,05,00,00,00,00,
> 2010-10-11 12:00:25.953 Type: SSH_FXP_READ, Size: 29, Number: 2309
> 2010-10-11 12:00:25.953 05,00,00,09,05,00,00,00,08,00,7F,F9,48,00,80,2B,40,00,00,00,00,00,00,1F,E6,
. 2010-10-11 12:00:25.953 Received incomplete data packet before end of file, offset: 413, size: 413, requested: 4083
. 2010-10-11 12:00:25.969 Waiting for another 4 bytes
. 2010-10-11 12:00:25.969 Looking for incoming data
. 2010-10-11 12:00:25.969 Looking for network events
. 2010-10-11 12:00:25.969 Detected network event
. 2010-10-11 12:00:25.969 Enumerating network events for socket 484
. 2010-10-11 12:00:25.969 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:25.969 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:25.969 Received 5 bytes (0)
. 2010-10-11 12:00:25.969 Read 4 bytes (1 pending)
. 2010-10-11 12:00:25.969 Waiting for another 8 bytes
. 2010-10-11 12:00:25.969 Received 8 bytes (0)
. 2010-10-11 12:00:25.969 Read 9 bytes (0 pending)
< 2010-10-11 12:00:25.969 Type: SSH_FXP_DATA, Size: 9, Number: 2309
< 2010-10-11 12:00:25.969 67,00,00,09,05,00,00,00,00,
> 2010-10-11 12:00:25.969 Type: SSH_FXP_CLOSE, Size: 17, Number: 2564
> 2010-10-11 12:00:25.969 04,00,00,0A,04,00,00,00,08,00,7F,F9,48,00,80,2B,40,
. 2010-10-11 12:00:25.969 Sent 21 bytes
. 2010-10-11 12:00:25.969 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.969 Timeout waiting for network events
* 2010-10-11 12:00:25.969 (ECommand) Copying files from remote side failed.
* 2010-10-11 12:00:25.969 Received incomplete data packet before end of file.
. 2010-10-11 12:00:26.031 Session upkeep
. 2010-10-11 12:00:26.031 Looking for network events
. 2010-10-11 12:00:26.031 Detected network event
. 2010-10-11 12:00:26.031 Enumerating network events for socket 484
. 2010-10-11 12:00:26.031 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:26.031 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:26.031 Received 5 bytes (0)
. 2010-10-11 12:00:26.031 Received 8 bytes (0)
. 2010-10-11 12:00:26.031 Received 12 bytes (0)
. 2010-10-11 12:00:26.531 Session upkeep
. 2010-10-11 12:00:26.531 Looking for network events
. 2010-10-11 12:00:26.531 Timeout waiting for network events
. 2010-10-11 12:00:27.031 Session upkeep
. 2010-10-11 12:00:27.031 Looking for network events
. 2010-10-11 12:00:27.031 Timeout waiting for network events
. 2010-10-11 12:00:27.531 Session upkeep
. 2010-10-11 12:00:27.531 Looking for network events
. 2010-10-11 12:00:27.531 Timeout waiting for network events
. 2010-10-11 12:00:28.031 Session upkeep
. 2010-10-11 12:00:28.031 Looking for network events
. 2010-10-11 12:00:28.031 Timeout waiting for network events
. 2010-10-11 12:00:28.531 Session upkeep
. 2010-10-11 12:00:28.531 Looking for network events
. 2010-10-11 12:00:28.531 Timeout waiting for network events
. 2010-10-11 12:00:29.031 Session upkeep
. 2010-10-11 12:00:29.031 Looking for network events
. 2010-10-11 12:00:29.031 Timeout waiting for network events
. 2010-10-11 12:00:29.531 Session upkeep
. 2010-10-11 12:00:29.531 Looking for network events
. 2010-10-11 12:00:29.531 Timeout waiting for network events
. 2010-10-11 12:00:30.031 Session upkeep
. 2010-10-11 12:00:30.031 Looking for network events
. 2010-10-11 12:00:30.031 Timeout waiting for network events
. 2010-10-11 12:00:30.531 Session upkeep
. 2010-10-11 12:00:30.531 Looking for network events
. 2010-10-11 12:00:30.531 Timeout waiting for network events
. 2010-10-11 12:00:31.047 Session upkeep
. 2010-10-11 12:00:31.047 Looking for network events
. 2010-10-11 12:00:31.047 Timeout waiting for network events
. 2010-10-11 12:00:31.531 Session upkeep
. 2010-10-11 12:00:31.531 Looking for network events
. 2010-10-11 12:00:31.531 Timeout waiting for network events
. 2010-10-11 12:00:32.031 Session upkeep
. 2010-10-11 12:00:32.031 Looking for network events
. 2010-10-11 12:00:32.031 Timeout waiting for network events
. 2010-10-11 12:00:32.531 Session upkeep
. 2010-10-11 12:00:32.531 Looking for network events
. 2010-10-11 12:00:32.531 Timeout waiting for network events
. 2010-10-11 12:00:33.031 Session upkeep
. 2010-10-11 12:00:33.031 Looking for network events
. 2010-10-11 12:00:33.031 Timeout waiting for network events
. 2010-10-11 12:00:33.531 Session upkeep
. 2010-10-11 12:00:33.531 Looking for network events
. 2010-10-11 12:00:33.531 Timeout waiting for network events
. 2010-10-11 12:00:34.031 Session upkeep
. 2010-10-11 12:00:34.031 Looking for network events
. 2010-10-11 12:00:34.031 Timeout waiting for network events
. 2010-10-11 12:00:34.531 Session upkeep
. 2010-10-11 12:00:34.531 Looking for network events
. 2010-10-11 12:00:34.531 Timeout waiting for network events
. 2010-10-11 12:00:36.203 Session upkeep
. 2010-10-11 12:00:36.203 Looking for network events
. 2010-10-11 12:00:36.203 Timeout waiting for network events
. 2010-10-11 12:00:36.532 Session upkeep
. 2010-10-11 12:00:36.532 Looking for network events
. 2010-10-11 12:00:36.532 Timeout waiting for network events
. 2010-10-11 12:00:37.032 Session upkeep
. 2010-10-11 12:00:37.032 Looking for network events
. 2010-10-11 12:00:37.032 Timeout waiting for network events
. 2010-10-11 12:00:37.532 Session upkeep
. 2010-10-11 12:00:37.532 Looking for network events
. 2010-10-11 12:00:37.532 Timeout waiting for network events
. 2010-10-11 12:00:38.032 Session upkeep
. 2010-10-11 12:00:38.032 Looking for network events
. 2010-10-11 12:00:38.032 Timeout waiting for network events
. 2010-10-11 12:00:38.532 Session upkeep
. 2010-10-11 12:00:38.532 Looking for network events
. 2010-10-11 12:00:38.532 Timeout waiting for network events
. 2010-10-11 12:00:39.032 Session upkeep
. 2010-10-11 12:00:39.032 Looking for network events
. 2010-10-11 12:00:39.032 Timeout waiting for network events
. 2010-10-11 12:00:39.532 Session upkeep
. 2010-10-11 12:00:39.532 Looking for network events
. 2010-10-11 12:00:39.532 Timeout waiting for network events
. 2010-10-11 12:00:40.032 Session upkeep
. 2010-10-11 12:00:40.032 Looking for network events
. 2010-10-11 12:00:40.032 Timeout waiting for network events
. 2010-10-11 12:00:40.532 Session upkeep
. 2010-10-11 12:00:40.532 Looking for network events
. 2010-10-11 12:00:40.532 Timeout waiting for network events
. 2010-10-11 12:00:41.032 Session upkeep
. 2010-10-11 12:00:41.032 Looking for network events
. 2010-10-11 12:00:41.032 Timeout waiting for network events
. 2010-10-11 12:00:41.532 Session upkeep
. 2010-10-11 12:00:41.532 Looking for network events
. 2010-10-11 12:00:41.532 Timeout waiting for network events
. 2010-10-11 12:00:42.032 Session upkeep
. 2010-10-11 12:00:42.032 Looking for network events
. 2010-10-11 12:00:42.032 Timeout waiting for network events
. 2010-10-11 12:00:42.532 Session upkeep
. 2010-10-11 12:00:42.797 Looking for network events
. 2010-10-11 12:00:42.797 Timeout waiting for network events
. 2010-10-11 12:00:43.032 Session upkeep
. 2010-10-11 12:00:43.032 Looking for network events
. 2010-10-11 12:00:43.032 Timeout waiting for network events
. 2010-10-11 12:00:43.532 Session upkeep
. 2010-10-11 12:00:43.532 Looking for network events
. 2010-10-11 12:00:43.532 Timeout waiting for network events
. 2010-10-11 12:00:44.032 Session upkeep
. 2010-10-11 12:00:44.032 Looking for network events
. 2010-10-11 12:00:44.032 Timeout waiting for network events
. 2010-10-11 12:00:44.532 Session upkeep
. 2010-10-11 12:00:44.532 Looking for network events
. 2010-10-11 12:00:44.532 Timeout waiting for network events
. 2010-10-11 12:00:45.032 Session upkeep
. 2010-10-11 12:00:45.032 Looking for network events
. 2010-10-11 12:00:45.032 Timeout waiting for network events
. 2010-10-11 12:00:45.532 Session upkeep
. 2010-10-11 12:00:45.532 Looking for network events
. 2010-10-11 12:00:45.532 Timeout waiting for network events
. 2010-10-11 12:00:46.032 Session upkeep
. 2010-10-11 12:00:46.032 Looking for network events
. 2010-10-11 12:00:46.032 Timeout waiting for network events
. 2010-10-11 12:00:46.532 Session upkeep
. 2010-10-11 12:00:46.532 Looking for network events
. 2010-10-11 12:00:46.532 Timeout waiting for network events
. 2010-10-11 12:00:47.032 Session upkeep
. 2010-10-11 12:00:47.032 Looking for network events
. 2010-10-11 12:00:47.032 Timeout waiting for network events
. 2010-10-11 12:00:47.532 Session upkeep
. 2010-10-11 12:00:47.532 Looking for network events
. 2010-10-11 12:00:47.532 Timeout waiting for network events
. 2010-10-11 12:00:48.032 Session upkeep
. 2010-10-11 12:00:48.032 Looking for network events
. 2010-10-11 12:00:48.032 Timeout waiting for network events
. 2010-10-11 12:00:48.532 Session upkeep
. 2010-10-11 12:00:48.532 Looking for network events
. 2010-10-11 12:00:48.532 Timeout waiting for network events
. 2010-10-11 12:00:49.032 Session upkeep
. 2010-10-11 12:00:49.032 Looking for network events
. 2010-10-11 12:00:49.032 Timeout waiting for network events
. 2010-10-11 12:00:49.532 Session upkeep
. 2010-10-11 12:00:49.532 Looking for network events
. 2010-10-11 12:00:49.532 Timeout waiting for network events
. 2010-10-11 12:00:50.032 Session upkeep
. 2010-10-11 12:00:50.032 Looking for network events
. 2010-10-11 12:00:50.032 Timeout waiting for network events
. 2010-10-11 12:00:50.532 Session upkeep
. 2010-10-11 12:00:50.532 Looking for network events
. 2010-10-11 12:00:50.532 Timeout waiting for network events
. 2010-10-11 12:00:51.032 Session upkeep
. 2010-10-11 12:00:51.032 Looking for network events
. 2010-10-11 12:00:51.032 Timeout waiting for network events
. 2010-10-11 12:00:51.532 Session upkeep
. 2010-10-11 12:00:51.532 Looking for network events
. 2010-10-11 12:00:51.532 Timeout waiting for network events
. 2010-10-11 12:00:52.032 Session upkeep
. 2010-10-11 12:00:52.032 Looking for network events
. 2010-10-11 12:00:52.032 Timeout waiting for network events
. 2010-10-11 12:00:52.532 Session upkeep
. 2010-10-11 12:00:52.532 Looking for network events
. 2010-10-11 12:00:52.532 Timeout waiting for network events
. 2010-10-11 12:00:53.032 Session upkeep
. 2010-10-11 12:00:53.032 Looking for network events
. 2010-10-11 12:00:53.032 Timeout waiting for network events
. 2010-10-11 12:00:53.532 Session upkeep
. 2010-10-11 12:00:53.532 Looking for network events
. 2010-10-11 12:00:53.532 Timeout waiting for network events
. 2010-10-11 12:00:54.032 Session upkeep
. 2010-10-11 12:00:54.032 Looking for network events
. 2010-10-11 12:00:54.032 Timeout waiting for network events
. 2010-10-11 12:00:54.532 Session upkeep
. 2010-10-11 12:00:54.532 Looking for network events
. 2010-10-11 12:00:54.532 Timeout waiting for network events
. 2010-10-11 12:00:55.032 Session upkeep
. 2010-10-11 12:00:55.032 Looking for network events
. 2010-10-11 12:00:55.032 Timeout waiting for network events
. 2010-10-11 12:00:55.532 Session upkeep
. 2010-10-11 12:00:55.532 Looking for network events
. 2010-10-11 12:00:55.532 Timeout waiting for network events
Thanks. This issue has been added to tracker.
