Topic "Ticking the never ask again box .. it asks again! 8>=<"
MrBiggz
Hello!
Ok! These dialog box that appears right after you click the keep remote up to date feature:
Even though I tick the box that says "Never Ask Again" it does over and over again! Grrrr!
Unless there is something I had set wrong here:
What are good options for keeping a remote up to date? I use it basically as a work around for MS FAILED (hahahaha) Webdisk. This little gem of a program lets me edit files locally and they it shoots it to my webhost. Beats the pants of editing/ftping over and over again, I can just edit then check. Less clicks and my finger isn't as sore! =)
Suggestions are welcome!
Thanks!
After you tick the Never ask me again and press Yes the Synchronize on start checkbox should turn from greyed state to ticket state. Does it?
