Topic "drag and drop for copy folders and files"
robs
with windows is possible, in the same screen, open more
directories and use drag and drop for copy or move files or dir;
for my experience think is one of the more sure and fast solutions;
all is under control;
a window where you take files and one or more windows where you
move;
is possible to have this with winscp;
I know that is possible to change interface but isn't the same flexible solutions;
Whart exactly do you want to achieve?
robs
generic folders and files;
when one have a sites and would like move
folder, files, images between folders of the same server, better solutions (that I know) is the flexibility of windows xp (or similar windows version)
one open a popup windows and moe in the side left of the screen
and that there will be the folder taht receive the files or folders;
in the right side is possible open one or more windows, where to take the files to move or duplicate;
so for example, if you would like to copy a files in more folders, is sufficient select files in the right side
and copy in the left side,
robs
not know if solution is simple:
between pc and server is possible to use drag and drop;
the same possibility between winscp when opened 2 time in the same screen
You can drop the remote files onto the remote directory tree.
