Topic "Open Cmd with Password"
Monday
So I have to connect like:
open ftps://myUserName:myUserPwd@ftps99.site.com:21 -explicittls -passive
I can NOT connect if I add :myUserPwd, however if I leave it out.. after connecting it ask for a pwd which I enter and then the connection authorizes and works.
Any ideas? I didnt see a -pwd cmd for the open cmd... is there something like that?
Would this article help?
https://winscp.net/eng/docs/session_url#special
devcja
The ascii caharacter %2A to replace * character in password is not working
open myuser:aaa%2AHP123@sftp.myserver.com
I still got the password denied message
. 2010-11-01 17:37:57.939 Prompt (6, SSH password, , &Password: )
. 2010-11-01 17:37:57.939 Using stored password.
. 2010-11-01 17:37:57.939 Sent password
! 2010-11-01 17:37:58.001 Access denied
You do not have to replace the *. I guess you have tried it without replacing first. So if it did not work, problem is elsewhere.
devcja
Thanks for your soon response.
I had replace with * and still not working.
I had already made two acclimatization for other FTPs server and its working with the open instruction.
The new server is SFTP-3 and looking in the log for WinSCP said : .
. 2010-11-12 09:20:49.931 We believe remote version has SSH-2 ignore bug
. 2010-11-12 09:20:49.931 Using SSH protocol version 2
. 2010-11-12 09:20:49.931 We claim version: SSH-2.0-WinSCP_release_4.2.9
When I use the GUI version works correctly.
What changes do I need to made in order for the script run correctly ?
Or even better what is your script recommendation or setting this up and make this work?
I'm sorry, I have no hint for you. Maybe log files from both GUI and script may help.
