Topic "upload *.*"
Haroon KHAN
When i use put -delete c:\upload\*.* /remote/in all the files from c:\upload\archive\*.* also get uploaded.. Is there a way to avoid sub folders upload?
thanks
You can use exclude mask:
https://winscp.net/eng/docs/scriptcommand_option
http://winscp.net/eng/docs/file_mask#directory_mask
Haroon KHan
Thanks for reply... But exclude option is ignored if i use -delete swtich?
Delete source local file(s) after transfer. Options exclude and include are ignored.
Sorry you are right.
-DB-Vryce
I have used the exclude command with *.* successfully. The trick is that you have to follow up the upload with separate delete command.
Exclude ....
put c:\upload\*.* /remote/in
cd \
cd upload
Delete *.*
I hope that this helps you out.
You can already use excluding with -delete
http://winscp.net/tracker/show_bug.cgi?id=536
