Topic "VB6 scripting example"
mrusu
Is it possible to include a "Full VB6 Example" together with existing "Full VB.NET Example" and "Full C# Example" in the scripting documentation?
I am having problems converting the VB.Net scripting code into classic VB (Visual Basic 6).
The reason I need VB6 code is that I would like to run WinSCP scripts from an MS Access database (that can only be coded using VB6).
Any help will be greatly appreciated.
Kind regards,
M. Rusu
I do not have any experience with VB, so I cannot. Maybe some other user may help.
Slinnako
Hi
I have tried the following code from VB6, first the one line command, inside the file sftptask.cmd : C:\WinSCP\winscp.com /script=c:\ftpscr.ftp /log=c:\log\201010_newftp.log
And the script file ftpscr.ftp includes :
option batch abort
open sftp://nnnnnn:yyyyyyy@newftp.zzzzzz.com -hostkey="ssh-rsa 1024 abcdef1234567890"
option transfer binary
cd /pub/data_transfer
put c:\log\2010-10-25-881435.txt
get /pub/to_incap/*.txt c:\
close
, but this is not working from VB6 shell, like retval = Shell(ftpcmd, vbNormalFocus)
It kicks me out in somewhere after login... BUT, when I run this same sftptask.cmd from the command prompt, it WORKS succesfully ! Pls., anyidea why it does not work from VB6 ?
thanks
seppo
mrusu
mrusu
Hi seppo,
I did some research on this, it seems that VB.Net functionality in the code samples section cannot be easily implemented in VB6.
Therefore I looked for an SFTP Activex client and did some testing with Chilkat SSH/SFTP ActiveX.
http://www.chilkatsoft.com/ssh-sftp-activex.asp
It seems to work very well in VB6.
Regards,
M. R.
mrusu
Also, consider the ideea to write a VB.Net DLL based on VB.Net code examples found on this site, expose the functions and call them from VB6 (you'll have to add a reference to this DLL).
Regards,
M. R.
