Topic "Using scriptfile will not log on. Keeps prompting for PW"
PoulJ
Even though password is specified in scripts open command I must enter password manually in order to log on. GUI works as expected.
Command:
winscp.exe /console /script="d:\Programmer\WinSCP\command.txt"
Script - command.txt:
option batch on
open sftp://USERNAME:Pasword@host:10022 -privatekey="C:\keystore\PuTTY\id_rsa.ppk" -hostkey="ssh-dss 2048 31:2a:18:3b:90:fe:20:a8:83:e9:3f:1f:90:78:e6:ef"
pwd
close
I should mention that private key has been converted by PuTTY from DSA to RSA.
Cheers,
/Poul
Why do you put in password, when you are authenticating using private key?
PoulJ
Sorry my bad.
Removing the PW from the open command does not change anything. Still being prompted for the password.
I now note that when using GUI I also need to enter Passphrase even though I have saved the Passphrase with the session.
So it maybe a general problem ?
/Poul
PoulJ
Problem solved.
Use puttygen.exe to save the private key withouth passphrase.
I know this is not the safest thing to do, but client wants it this way !
