Topic "WinSCP file transfer failure | speed limiting no effect"
ZHAOJ
WinSCP ver: 4.2.9 B938
Windows XP 32bit SP3
FTPS passive connection
failed file: 6410500021_003.tif
I'm currently having a strange issue where WinSCP will fail on transfering a random .tif image file. The file is partly transfered and retries will also only transfer portion of the file.
If I open the image file with an image editing program and resave with no changes, the file can be transfered.
I can not identify any specific error on both client and server side logs.
However, I have also tried to transfer with Filezilla client, although similar files also fail to trasnfer, they can be transfered successfully with a upload speed limit set to 20KB/s.
I then tried to use similar speed limit with WinSCP trying 32,16,8KB/s but the same file still fails. Is there an issue with the speed limit feature in WinSCP?
hope someone can share some light on possible cause of the issue for this. Below logs of connection
. 2010-10-21 12:23:43.177 --------------------------------------------------------------------------
. 2010-10-21 12:23:43.192 WinSCP Version 4.2.9 (Build 938) (OS 5.1.2600 Service Pack 3)
. 2010-10-21 12:23:43.208 Login time: Thursday, 21 October 2010 12:23:43 PM
. 2010-10-21 12:23:43.208 --------------------------------------------------------------------------
. 2010-10-21 12:23:43.224 Session name: NZ_ACC_IMG_QA
. 2010-10-21 12:23:43.224 Host name: xxx.xxx.xxx.xxx (Port: 990)
. 2010-10-21 12:23:43.255 User name: xxxxxx (Password: Yes, Key file: No)
. 2010-10-21 12:23:43.270 Tunnel: No
. 2010-10-21 12:23:43.286 Transfer Protocol: FTP
. 2010-10-21 12:23:43.302 Ping type: C, Ping interval: 30 sec; Timeout: 30 sec
. 2010-10-21 12:23:43.302 Proxy: none
. 2010-10-21 12:23:43.317 FTP: FTPS: Implicit SSL/TLS; Passive: Yes [Force IP: No]
. 2010-10-21 12:23:43.333 Local directory: C:\Stepplus\NZ\outbound_img\, Remote directory: /LOREAL-NEWZEALAND/IMAGES/, Update: No, Cache: No
. 2010-10-21 12:23:43.333 Cache directory changes: Yes, Permanent: Yes
. 2010-10-21 12:23:43.349 DST mode: 1
. 2010-10-21 12:23:43.364 --------------------------------------------------------------------------
. 2010-10-21 12:23:43.427 Connecting to xxx.xxx.xxx.xxx:990 ...
. 2010-10-21 12:23:43.442 m_pSslLayer changed state from 0 to 1
. 2010-10-21 12:23:43.458 m_pSslLayer changed state from 1 to 2
. 2010-10-21 12:23:43.677 m_pSslLayer changed state from 2 to 4
. 2010-10-21 12:23:43.708 Connected with xxx.xxx.xxx.xxx:990, negotiating SSL connection...
. 2010-10-21 12:23:44.067 SSL_connect: SSLv3 read server hello A
. 2010-10-21 12:23:44.083 SSL_connect: SSLv3 read server certificate A
. 2010-10-21 12:23:44.083 SSL_connect: SSLv3 read server done A
. 2010-10-21 12:23:44.099 SSL_connect: SSLv3 write client key exchange A
. 2010-10-21 12:23:44.099 SSL_connect: SSLv3 write change cipher spec A
. 2010-10-21 12:23:44.114 SSL_connect: SSLv3 write finished A
. 2010-10-21 12:23:44.114 SSL_connect: SSLv3 flush data
. 2010-10-21 12:23:44.364 SSL_connect: SSLv3 read finished A
. 2010-10-21 12:23:44.380 Using TLSv1, cipher TLSv1/SSLv3: RC4-MD5, 1024 bit RSA
. 2010-10-21 12:23:44.395 SSL connection established. Waiting for welcome message...
< 2010-10-21 12:23:44.849 220 VanDyke Software VShell FTPS Server version 3.6.2 (build 446).
> 2010-10-21 12:23:44.864 USER xxxxxx
< 2010-10-21 12:23:45.145 331 User accepted, password required.
> 2010-10-21 12:23:45.145 PASS **********
< 2010-10-21 12:23:45.520 230 Login successful.
> 2010-10-21 12:23:45.536 SYST
< 2010-10-21 12:23:45.849 215 WIN32 system type.
> 2010-10-21 12:23:45.864 FEAT
< 2010-10-21 12:23:46.146 211-Extensions supported:
< 2010-10-21 12:23:46.146  AUTH TLS
< 2010-10-21 12:23:46.161  AUTH SSL
< 2010-10-21 12:23:46.161  PBSZ
< 2010-10-21 12:23:46.161  PROT
< 2010-10-21 12:23:46.177  SIZE
< 2010-10-21 12:23:46.177  REST STREAM
< 2010-10-21 12:23:46.192  LANG EN
< 2010-10-21 12:23:46.208  MLST Type;Size;Modify;
< 2010-10-21 12:23:46.208  UTF8
< 2010-10-21 12:23:46.224 211 End
> 2010-10-21 12:23:46.224 OPTS UTF8 ON
< 2010-10-21 12:23:46.442 200 Command okay.
> 2010-10-21 12:23:46.442 PBSZ 0
< 2010-10-21 12:23:46.724 200 Protection buffer size set to 0.
> 2010-10-21 12:23:46.739 PROT P
< 2010-10-21 12:23:47.021 200 Protection level set to P
. 2010-10-21 12:23:47.021 Connected
. 2010-10-21 12:23:47.036 Got reply 1 to the command 1
. 2010-10-21 12:23:47.036 --------------------------------------------------------------------------
. 2010-10-21 12:23:47.036 Using FTP protocol.
. 2010-10-21 12:23:47.052 Doing startup conversation with host.
> 2010-10-21 12:23:47.067 PWD
< 2010-10-21 12:23:47.349 257 "/" is the current directory.
. 2010-10-21 12:23:47.364 Got reply 1 to the command 16
. 2010-10-21 12:23:47.364 Changing directory to "/LOREAL-NEWZEALAND/IMAGES/".
> 2010-10-21 12:23:47.380 CWD /LOREAL-NEWZEALAND/IMAGES/
< 2010-10-21 12:23:47.692 250 CWD successful. "/LOREAL-NEWZEALAND/IMAGES/" is the current directory.
. 2010-10-21 12:23:47.708 Got reply 1 to the command 16
. 2010-10-21 12:23:47.724 Getting current directory name.
> 2010-10-21 12:23:47.724 PWD
< 2010-10-21 12:23:48.021 257 "/LOREAL-NEWZEALAND/IMAGES/" is the current directory.
. 2010-10-21 12:23:48.021 Got reply 1 to the command 16
. 2010-10-21 12:23:48.036 Retrieving directory listing...
> 2010-10-21 12:23:48.036 TYPE A
< 2010-10-21 12:23:48.317 200 Type set to 'A'
> 2010-10-21 12:23:48.317 PASV
< 2010-10-21 12:23:48.614 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:23:48.614 LIST -a
. 2010-10-21 12:23:48.911 m_pSslLayer changed state from 0 to 4
< 2010-10-21 12:23:48.911 550 File unavailable: The system cannot find the file specified.
. 2010-10-21 12:23:48.927 Could not retrieve directory listing
. 2010-10-21 12:23:48.927 Got reply 4 to the command 2
. 2010-10-21 12:23:48.942 Retrieving directory listing...
> 2010-10-21 12:23:48.958 TYPE A
< 2010-10-21 12:23:49.239 200 Type set to 'A'
> 2010-10-21 12:23:49.255 PASV
< 2010-10-21 12:23:49.536 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:23:49.568 LIST
. 2010-10-21 12:23:49.864 m_pSslLayer changed state from 0 to 4
< 2010-10-21 12:23:49.974 150 Status okay; about to open data connection.
. 2010-10-21 12:23:50.458 SSL connection established
< 2010-10-21 12:23:50.489 226 Transfer complete.
. 2010-10-21 12:23:50.505 m_pSslLayer changed state from 4 to 5
. 2010-10-21 12:23:50.521 d---------    0 nobody   nobody          0 Oct 21 03:22 .
. 2010-10-21 12:23:50.536 d---------    0 nobody   nobody          0 Oct 21 03:22 ..
. 2010-10-21 12:23:50.552 d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651
. 2010-10-21 12:23:50.568 ----------    0 nobody   nobody      61440 Oct 21 03:23 6410500021_003.tif
. 2010-10-21 12:23:50.599 Directory listing successful
. 2010-10-21 12:23:50.599 Got reply 1 to the command 2
. 2010-10-21 12:23:50.614 Startup conversation with host finished.
. 2010-10-21 12:23:50.739 Session upkeep
. 2010-10-21 12:23:58.224 Deleting file "6410500021_003.tif".
> 2010-10-21 12:23:58.240 DELE /LOREAL-NEWZEALAND/IMAGES/6410500021_003.tif
< 2010-10-21 12:23:58.568 250 Requested file action okay, completed.
. 2010-10-21 12:23:58.583 Got reply 1 to the command 32
. 2010-10-21 12:23:58.599 Session upkeep
. 2010-10-21 12:23:58.615 Retrieving directory listing...
> 2010-10-21 12:23:58.630 TYPE A
< 2010-10-21 12:23:58.896 200 Type set to 'A'
> 2010-10-21 12:23:58.912 PASV
< 2010-10-21 12:23:59.193 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:23:59.208 LIST
. 2010-10-21 12:23:59.505 m_pSslLayer changed state from 0 to 4
< 2010-10-21 12:23:59.568 150 Status okay; about to open data connection.
. 2010-10-21 12:24:00.115 SSL connection established
< 2010-10-21 12:24:00.177 226 Transfer complete.
. 2010-10-21 12:24:00.318 m_pSslLayer changed state from 4 to 5
. 2010-10-21 12:24:00.333 d---------    0 nobody   nobody          0 Oct 21 03:23 .
. 2010-10-21 12:24:00.349 d---------    0 nobody   nobody          0 Oct 21 03:23 ..
. 2010-10-21 12:24:00.365 d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651
. 2010-10-21 12:24:00.396 Directory listing successful
. 2010-10-21 12:24:00.427 Got reply 1 to the command 2
. 2010-10-21 12:24:29.038 Session upkeep
. 2010-10-21 12:24:29.131 Copying 1 files/directories to remote directory "/LOREAL-NEWZEALAND/IMAGES/"
. 2010-10-21 12:24:29.163   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: No; Mask: *.*
. 2010-10-21 12:24:29.163   TM: M; ClAr: No; CPS: 16384; ExclM(No): <1B
. 2010-10-21 12:24:29.178   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-10-21 12:24:29.209 File: "C:\Stepplus\test\20101008-1650\6410500021_003.tif"
. 2010-10-21 12:24:29.256 Copying "C:\Stepplus\test\20101008-1650\6410500021_003.tif" to remote directory started.
. 2010-10-21 12:24:29.272 Binary transfer mode selected.
. 2010-10-21 12:24:29.288 Starting upload of C:\Stepplus\test\20101008-1650\6410500021_003.tif
> 2010-10-21 12:24:29.303 TYPE I
< 2010-10-21 12:24:29.584 200 Type set to 'I'
> 2010-10-21 12:24:29.600 PASV
< 2010-10-21 12:24:29.881 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:24:29.881 STOR 6410500021_003.tif
< 2010-10-21 12:24:30.209 150 Status okay; about to open data connection.
. 2010-10-21 12:24:30.225 Session upkeep
. 2010-10-21 12:24:30.241 m_pSslLayer changed state from 0 to 4
. 2010-10-21 12:24:30.459 Session upkeep
. 2010-10-21 12:24:30.803 SSL connection established
. 2010-10-21 12:24:31.022 Session upkeep
. 2010-10-21 12:24:32.006 Session upkeep
. 2010-10-21 12:24:33.100 Session upkeep
< 2010-10-21 12:24:33.944 526 Transfer failed.
. 2010-10-21 12:24:33.960 Copying files to remote side failed.
. 2010-10-21 12:24:33.960 Got reply 4 to the command 4
* 2010-10-21 12:24:33.975 (ExtException) Copying files to remote side failed.
* 2010-10-21 12:24:33.975 Transfer failed.
. 2010-10-21 12:24:33.975 Session upkeep
. 2010-10-21 12:24:33.991 Asking user:
. 2010-10-21 12:24:33.991 Error transferring file 'C:\Stepplus\test\20101008-1650\6410500021_003.tif'. ("Copying files to remote side failed.","Transfer failed.")
. 2010-10-21 12:24:34.460 Session upkeep
. 2010-10-21 12:24:34.960 Session upkeep
. 2010-10-21 12:24:35.460 Session upkeep
. 2010-10-21 12:24:35.960 Session upkeep
. 2010-10-21 12:24:36.460 Session upkeep
. 2010-10-21 12:24:36.663 Starting upload of C:\Stepplus\test\20101008-1650\6410500021_003.tif
> 2010-10-21 12:24:36.678 TYPE A
< 2010-10-21 12:24:36.960 200 Type set to 'A'
> 2010-10-21 12:24:36.960 PASV
< 2010-10-21 12:24:37.257 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:24:37.257 LIST
. 2010-10-21 12:24:37.553 m_pSslLayer changed state from 0 to 4
< 2010-10-21 12:24:37.600 150 Status okay; about to open data connection.
. 2010-10-21 12:24:38.194 SSL connection established
< 2010-10-21 12:24:38.210 226 Transfer complete.
. 2010-10-21 12:24:38.210 m_pSslLayer changed state from 4 to 5
. 2010-10-21 12:24:38.225 d---------    0 nobody   nobody          0 Oct 21 03:24 .
. 2010-10-21 12:24:38.225 d---------    0 nobody   nobody          0 Oct 21 03:24 ..
. 2010-10-21 12:24:38.241 d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651
. 2010-10-21 12:24:38.241 ----------    0 nobody   nobody      61440 Oct 21 03:24 6410500021_003.tif
. 2010-10-21 12:24:38.257 Session upkeep
> 2010-10-21 12:24:38.257 TYPE I
< 2010-10-21 12:24:38.553 200 Type set to 'I'
> 2010-10-21 12:24:38.569 PASV
< 2010-10-21 12:24:38.882 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:24:38.882 STOR 6410500021_003.tif
< 2010-10-21 12:24:39.194 150 Status okay; about to open data connection.
. 2010-10-21 12:24:39.210 Session upkeep
. 2010-10-21 12:24:39.210 m_pSslLayer changed state from 0 to 4
. 2010-10-21 12:24:39.460 Session upkeep
. 2010-10-21 12:24:39.819 SSL connection established
. 2010-10-21 12:24:40.038 Session upkeep
. 2010-10-21 12:24:41.022 Session upkeep
. 2010-10-21 12:24:42.007 Session upkeep
< 2010-10-21 12:24:42.788 526 Transfer failed.
. 2010-10-21 12:24:42.804 Copying files to remote side failed.
. 2010-10-21 12:24:42.804 Got reply 4 to the command 4
* 2010-10-21 12:24:42.804 (ExtException) d---------    0 nobody   nobody          0 Oct 21 03:24 .
* 2010-10-21 12:24:42.819 d---------    0 nobody   nobody          0 Oct 21 03:24 ..
* 2010-10-21 12:24:42.819 d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651
* 2010-10-21 12:24:42.835 ----------    0 nobody   nobody      61440 Oct 21 03:24 6410500021_003.tif
* 2010-10-21 12:24:42.835 Copying files to remote side failed.
* 2010-10-21 12:24:42.835 Transfer failed.
. 2010-10-21 12:24:42.850 Session upkeep
. 2010-10-21 12:24:42.850 Asking user:
. 2010-10-21 12:24:42.866 Error transferring file 'C:\Stepplus\test\20101008-1650\6410500021_003.tif'. ("d---------    0 nobody   nobody          0 Oct 21 03:24 .","d---------    0 nobody   nobody          0 Oct 21 03:24 ..","d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651","----------    0 nobody   nobody      61440 Oct 21 03:24 6410500021_003.tif","Copying files to remote side failed.","Transfer failed.")
. 2010-10-21 12:24:42.960 Session upkeep
. 2010-10-21 12:24:43.460 Session upkeep
. 2010-10-21 12:24:43.960 Session upkeep
. 2010-10-21 12:24:44.460 Session upkeep
. 2010-10-21 12:24:44.960 Session upkeep
. 2010-10-21 12:24:45.460 Session upkeep
* 2010-10-21 12:24:45.757 (EScpSkipFile) Error transferring file 'C:\Stepplus\test\20101008-1650\6410500021_003.tif'.
* 2010-10-21 12:24:45.772 d---------    0 nobody   nobody          0 Oct 21 03:24 .
* 2010-10-21 12:24:45.788 d---------    0 nobody   nobody          0 Oct 21 03:24 ..
* 2010-10-21 12:24:45.804 d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651
* 2010-10-21 12:24:45.819 ----------    0 nobody   nobody      61440 Oct 21 03:24 6410500021_003.tif
* 2010-10-21 12:24:45.819 Copying files to remote side failed.
* 2010-10-21 12:24:45.835 Transfer failed.
. 2010-10-21 12:24:45.835 Retrieving directory listing...
> 2010-10-21 12:24:45.851 TYPE A
< 2010-10-21 12:24:46.132 200 Type set to 'A'
> 2010-10-21 12:24:46.163 PASV
< 2010-10-21 12:24:46.429 227 Entering Passive Mode (xxxxxx).
> 2010-10-21 12:24:46.429 LIST
. 2010-10-21 12:24:46.726 m_pSslLayer changed state from 0 to 4
< 2010-10-21 12:24:46.772 150 Status okay; about to open data connection.
. 2010-10-21 12:24:47.319 SSL connection established
< 2010-10-21 12:24:47.335 226 Transfer complete.
. 2010-10-21 12:24:47.335 m_pSslLayer changed state from 4 to 5
. 2010-10-21 12:24:47.335 d---------    0 nobody   nobody          0 Oct 21 03:24 .
. 2010-10-21 12:24:47.351 d---------    0 nobody   nobody          0 Oct 21 03:24 ..
. 2010-10-21 12:24:47.351 d---------    0 nobody   nobody          0 Oct 21 03:20 20101008-1651
. 2010-10-21 12:24:47.366 ----------    0 nobody   nobody      61440 Oct 21 03:24 6410500021_003.tif
. 2010-10-21 12:24:47.366 Directory listing successful
. 2010-10-21 12:24:47.366 Got reply 1 to the command 2
. 2010-10-21 12:24:47.476 Session upkeep
. 2010-10-21 12:24:47.960 Session upkeep
. 2010-10-21 12:24:48.460 Session upkeep
. 2010-10-21 12:24:48.960 Session upkeep
. 2010-10-21 12:24:49.366 Got reply 1004 to the command 2
. 2010-10-21 12:24:49.366 Disconnected from server
Thank you.
John.
I'm not aware of any issue with the sped limit in WinSCP. What does the server log say anyway? Is the error in the server log the same for WinSCP and Filezilla?
ZHAOJ
Hi, yes the error is the same for both clients when they failed. below portion of the server side log.
11/10/2010   7:59:00   VShellFTPS   conn   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD PASV - 227 0 0 0 xxx.xxx.xxx.xxx 990 "227 Entering Passive Mode (XXX,XXX,85,70,23,112)."
11/10/2010   7:59:00   VShellFTPS   ftps   730 - - SVC-AFS-AU-FT-OL-PD STOR 6420500010_071.tif 150 0 0 0 - - "150 Status okay; about to open data connection."
11/10/2010   7:59:01   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - - 0 0 0 0 xxx.xxx.xxx.xxx 990 "Available server protocols: SSL3,TLS1"
11/10/2010   7:59:01   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - - 0 0 0 0 xxx.xxx.xxx.xxx 990 "Available server cipher algorithms: rc4,3des,rc2,des,md5,sha1,RSA,ESDH (strengths: 40 - 168)"
11/10/2010   7:59:01   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - - 0 0 0 0 xxx.xxx.xxx.xxx 990 "Negotiated server protocol: TLS1"
11/10/2010   7:59:01   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - - 0 0 0 0 xxx.xxx.xxx.xxx 990 "Negotiated server cipher algorithm: rc4 (strength: 128)"
11/10/2010   7:59:01   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - - 0 0 0 0 xxx.xxx.xxx.xxx 990 "Negotiated server hash algorithm: md5 (strength: 128)"
11/10/2010   7:59:01   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - - 0 0 0 0 xxx.xxx.xxx.xxx 990 "Negotiated server key exchange algorithm: RSA (strength: 1024)"
11/10/2010   7:59:04   VShellFTPS   ftps   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - \\frcdv2002\cifs_afs$\AFS\COMMUNICATION\DataExchange\Incoming\Client\XXXXXX\LOR\MDATA\AU\IMAGES\20101008-1651\6420500010_071.tif 0 131072 0 131072 xxx.xxx.xxx.xxx 990 "00730: EMEA\SVC-AFS-AU-FT-OL-PD has accessed '\\frcdv2002\cifs_afs$\AFS\COMMUNICATION\DataExchange\Incoming\Client\XXXXXX\LOR\MDATA\AU\IMAGES\20101008-1651\6420500010_071.tif': 131072 bytes uploaded"
11/10/2010   7:59:04   VShellFTPS   ftps   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD - \\frcdv2002\cifs_afs$\AFS\COMMUNICATION\DataExchange\Incoming\Client\XXXXXX\LOR\MDATA\AU\IMAGES\20101008-1651\6420500010_071.tif 0 131072 0 131072 xxx.xxx.xxx.xxx 990 "00730: Trigger executed command: C:\Scripts\UploadTrigger.bat \\frcdv2002\cifs_afs$\AFS\COMMUNICATION\DataExchange\Incoming\Client\XXXXXX\LOR\MDATA\AU\IMAGES\20101008-1651\6420500010_071.tif EMEA\SVC-AFS-AU-FT-OL-PD"
11/10/2010   7:59:04   VShellFTPS   dbg   730 81.255.154.129 44114 SVC-AFS-AU-FT-OL-PD STOR - 0 0 0 0 xxx.xxx.xxx.xxx 990 "The message or signature supplied for verification has been altered"
11/10/2010   7:59:04   VShellFTPS   conn   730 81.255.154.129 47382 SVC-AFS-AU-FT-OL-PD STOR - 526 131072 0 131072 xxx.xxx.xxx.xxx 6000 "526 Transfer failed."
For me it seems the file being transfered was changed on the destination server, I did question about the batch file that was triggered, i was told it looks for an EOF for a text file which contains a list of all .tif images that is in a batch.
Thanks.
John.
