Topic "WinSCP 429 / Win64: Drag&Drop shell extension remove"
helohe
The installer of WinSCP 429 installed the Drag&Drop shell extension but I specifically have chosen in the custom install NOT to install the shell extension because of security considerations. I then Uninstalled WinSCP again using the uninstaller. But apparently the shell extension is still installed. (When I check with the portable version of WinSCP, drag and drop is still available). Is there a way to remove this shell extension? I don't like having any services etc running without my consent.
best regards
helohe
OS: Windows 7 - Ultimate 64 bit
Have you restarted your machine after uninstalling WinSCP?
helohe
Yes, I restarted but Drag&Drop support is still selectable in preferences.
Ok, I've forgot that on 64 bit system WinSCP cannot detect if extension is installed, so the option is available always.
helohe
oh, ok. thank you Smile
Hilarion
Is there 64-bit shell extension or are we talking about 32-bit shell extension?
Yes, there is 64-bit extension.
