Topic "Bug : WinSCP cannot handle multiple open files in editor w7"
UserP
WinSCP cannont save a changed remote file while multiple remote files are open in assigned texteditor (tested with latest notepad++ and pspad).
Only the first open file can be saved again, but only after all other open files/tab in the editor are closed.
Reproduced on Windows 7 32&64 Bit, DE & EN Versions.
It was working correct unter XP.
Make sure you have editor preference option External editor opens each file in separate window (process) turned off.
http://winscp.net/eng/docs/ui_editor_preferences
