Topic "Invalid Access to memory error: 4.3 beta"
a7ndrew
Hi, Just to let you know I am getting an "Invalid access to memory" error in 4.3 beta, when pressing connect to server. I am running Win 7 Professional, 64 bit. I dropped back to 4.29 which works fine.
Cecco
Same your problem with 4.3 beta.
Sacrejaune
I have the same problem with the 4.3 beta. It doesn't matter where I try to connect I always get "Invalid access to memory" error message right after pressing Login.
My OS is Windows XP Home with Service Pack 3.
Cecco
Run as administrator
AJC
On a fully patched (to end of life) Windows 2000 Pro box 4.3 Beta produces the same "Invalid access to memory" as other report. This was an "update" from 4.2.6 Build 721.
pb
I'm getting the same error with 4.3. Existing connections in winscp.ini work fine, but I can't create any new connections or edit existing connections. I've tried running as administrator and a regular user -- both produce the error.
I neglected to add that 4.2.9 Build 938 works perfectly on 2000 Pro.
AJC
On Windows XP-Pro (32 bit) 4.3.Beta (Build 1029) fails "EPrivilege" attempting to connect. Reverting to 4.2.9 (938) its ok.
frymaster
"Invalid access to memory" on server 2008 SP2 using 4.3beta
Sarah German
Me too. 4.3 beta, Windows XP Pro, SP3. Error ("Invalid access to memory") comes up every time I hit Connect.
t33r0y
Same error here on Windows 7 64-bit Enterprise edition running WinSCP 4.3.0 (Build 1029). This appears to only happen when connecting to a site using the 'New' button and manually entering in connection information. My saved sessions appear to be working just fine.
Rakushun
Same for me. Win 7, 64 bit, Version 4.3.0 beta (Debug+Release Version), Build 1029.
If I click on a saved session and hit the "Login" button, WinSCP connects smoothly. If I click on a saved session, hit the "Edit" button, change the username and hit the "Login" button (without saving the session), either WinSCP crashes completely or there is an "Invalid access to memory" message box.
I have a debug log at hand if desired.
rojaro
Win XP SP3, 32 bit, Version 4.3.0, Build 1029.
I get the "EPrivilege" error message when i try to use FTP. Using tcpdump to monitor the FTP server, i also noticed that it doesnt receive a connection at all, so it looks to me that the problem occurs before WinSCP actually tries to open the connection.
However, SFTP/SCP work without problems Smile
Aguest2
Installed WinSCP 4.3 (build 1029) on WinXP Professional SP3, same error "Invalid access to memory"
One user mentioned the workaround of using a saved session. Confirmed, created a new saved session allowed me to connect.
Ps: having the registry update included is really annoying. I had a user install it despite me asking her to unclick it, and she had to reboot. It should NOT be the default option!
Thanks for your posts. This bug has been added to tracker.
ckg
Win7 64 bit, same error "Invalid access to memory". Also confirmed that you can save the session then open that saved session.
jokersace
workaround does work, til bug gets fix
JY_N
I'm having the same problem too. Windows 7, 32-bit. Is there any way to fix this?
You can downgrade to 4.2.9. Anyway 4.3.1 with a fix will be released within a week.
invalid access to memory
win vista, 32bit,
worked well with 4.2.9 version,too.
invalid access to memory wrote:
win vista, 32bit,
Have you tried the latest version? 4.3.2.
