Topic "bug in setup when trying to install Uniblue RegistryBooster"
ptepper
Running setup (winscp430setup.exe) for version 4.3.0 beta Build 1029, tries to ask if I want Uniblue RegistryBooster, but there's no info other than the 2 radio buttons.
Here's a screenshot.
This is definitely a bug. I assume the first radio button is yes and the second no.
Or better yet, remove the bloatware altogether.
sbarth
I too encountered this bug. Confirming @ptepper assumption was correct. The 2nd option did not appear to install the additional software.
Thanks!
DiggieOC
Hi ptepper, sbarth,
I work at OpenCandy and I'm researching this issue. If you can reproduce this issue, i.e. it wasn't a one in a million occurrence, and you're willing to help us track the problem down we'd love to thank you with a free OC T-shirt. You can get in touch with me at diggie [at] opencandy (dotcom) and I can send you some instructions that will probably take 5-10 minutes to follow. It would not involve you sending any private information.
Tip: In the meantime, don't accept the offer so you can continued to be offered it in future.
Thanks in advance, and sorry for these difficulties!
- Al
The issue got resolved by OpenCandy on server-side. Please report if the proplem repeats.
Also this software is going to be removed from recommendation list.
