Topic "Synchronize and Mask Command"
knockando
I'm trying to sync only *.tar.gz files to my local directory.
This works and syncs ALL files in /pce/data/test:
synchronize local -delete C:\apps\TransferHolding\pce\xmldata /pce/data/test/
This doesn't work, gives me Error listing directory '/pce/data/test/*.tar.gz'. No such file or directory:
synchronize local -delete C:\apps\TransferHolding\pce\xmldata /pce/data/test/*.tar.gz.
I've looked all over and the only thing I can find is 'Existing files only' but I'm not sure how to set that via scripting. I know my Mask is correct b/c 'ls /pce/data/test/*.tar.gz' returns my one file.
Thanks!
knockando
Put this in before executing the sync command but transferring all files, not just *.tar.gz
.WriteLine("option include *.tar.gz")
Please post your complete script file.
knockando
Dim winscp As Process = New Process()
winscp.FileName = "C:\Program Files\WinSCP\WinSCP.com"
winscp.Start()
.WriteLine("option batch abort")
.WriteLine("option confirm off")
.WriteLine("open sftp://" & username & ":" & password & "@" & remotehost)
.WriteLine("option include "*.tar.gz"")
.WriteLine("synchronize local -delete -criteria=time C:\apps\TransferHolding\pce\data\ /pce/data/AndyTest/")
I'm not getting errors back from
message As XPathNavigator In nav.Select("//w:message", ns)
Another note, I've tried this exact same script by manually typing the commands using WinSCP.com and it worked.
Thanks!
knockando
I changed
to
mask = "*.tar.gz"
.WriteLine("option include" & " """ & mask & """")
and it's working.
