Topic "passing variable filename into the script file"
buntux
Hi all,
I have simple web page which startup the batch file:
<html>
 <head>
     <script language="JavaScript" type="text/javascript">
         MyObject = new ActiveXObject( "WScript.Shell" )
         function RunExe()
            var filename = "test2.txt";
         var logfile = "wscplogfile.txt";
         var obj = "file:///d:/Download/winscp/wscp.bat "+filename+" "+logfile+"";
         alert(obj);
         MyObject.Run(obj);
    </script>
 </head>
 <body>
    <h1>Run a Program</h1>
    <button onclick="RunExe()">Run Exe File</button>
 </body>
</html>
in my wscp.bat there is:
d:\Download\winscp\winscp.exe ge /console /script=d:/Download/winscp/skrypt.txt %1 /log=d:/%2
pause
and unfortunately it doesn't work.
The log file is creating everytime but in this log file there is a section:
< 2010-11-12 22:08:43.490 Script: Active session: [1] ge
> 2010-11-12 22:08:43.490 Script: option confirm off
< 2010-11-12 22:08:43.490 Script: confirm         off
> 2010-11-12 22:08:43.491 Script: get %1 d:\
. 2010-11-12 22:08:43.492 Listing file "%1".
why this doesn't work for a filename?
how I can pass the variable filename from my webpage into the skrypt.txt file
the skrypt.txt file looks like this:
get %1 d:\
Should be put %1% ...
buntux
Thanks for the response.
I managed do do it by generating skrypt.txt file by webpage.
This is better sollution because only webpage knows what will be the file name.
Regards.
