Topic "Error Resolving Remote Directory - Code 12"
anirudh.chhabra
I am using WinScp version 4.2.7 to synchronise documents from my remote server to local machine. On my remote server, I have FreeSSHD set up as the FTP Server and have defined the SFTP home path as F:/
Now, I need to syncronise F:/apps/Docs from my Remote to F:/apps/Docs on my local. Apparently, when I provide the remote directory path, WinScp cannot resolve it. I have tried all options (apps, F:/apps, F:\\apps etc) but it doesn't seem to work.
Here is the my script:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect
open qhubProd
# Change remote directory
 cd /apps
# Force binary mode transfer
option transfer binary
synchronize docs f:/apps/docs
# Exit WinSCP
Here is the log file:
2010-11-15 13:52:21.640 --------------------------------------------------------------------------
. 2010-11-15 13:52:21.640 WinSCP Version 4.2.7 (Build 758) (OS 5.0.2195 Service Pack 4)
. 2010-11-15 13:52:21.640 Login time: Monday, November 15, 2010 1:52:21 PM
. 2010-11-15 13:52:21.640 --------------------------------------------------------------------------
. 2010-11-15 13:52:21.640 Session name: QhubProd
. 2010-11-15 13:52:21.640 Host name: xxx.xx.xxx.xx (Port: 22)
. 2010-11-15 13:52:21.640 User name: qhubftp (Password: No, Key file: Yes)
. 2010-11-15 13:52:21.640 Tunnel: No
. 2010-11-15 13:52:21.640 Transfer Protocol: SFTP (SCP)
. 2010-11-15 13:52:21.640 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-11-15 13:52:21.640 Proxy: none
. 2010-11-15 13:52:21.640 SSH protocol version: 2; Compression: No
. 2010-11-15 13:52:21.640 Bypass authentication: No
. 2010-11-15 13:52:21.640 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-11-15 13:52:21.640 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-11-15 13:52:21.640 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-11-15 13:52:21.640 SFTP Bugs: -,-
. 2010-11-15 13:52:21.640 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-11-15 13:52:21.640 Shell: default, EOL: 0
. 2010-11-15 13:52:21.640 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-11-15 13:52:21.640 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-11-15 13:52:21.640 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-11-15 13:52:21.640 Cache directory changes: Yes, Permanent: Yes
. 2010-11-15 13:52:21.640 DST mode: 1
. 2010-11-15 13:52:21.640 Looking up host "x.x.x.x"
. 2010-11-15 13:52:21.640 Connecting to x.x.x.x. port 22
. 2010-11-15 13:52:22.281 Server version: SSH-2.0-WeOnlyDo 2.1.3
. 2010-11-15 13:52:22.281 Using SSH protocol version 2
. 2010-11-15 13:52:22.281 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-11-15 13:52:22.578 Using Diffie-Hellman with standard group "group14"
. 2010-11-15 13:52:22.578 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-11-15 13:52:23.500 Host key fingerprint is:
. 2010-11-15 13:52:23.500 ssh-rsa 1024 x.x.x.x.x.x.x.x.x.x.x.x..x.x.x.x.x.x
. 2010-11-15 13:52:23.500 Initialised AES-256 CBC client->server encryption
. 2010-11-15 13:52:23.500 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-11-15 13:52:23.796 Initialised AES-256 CBC server->client encryption
. 2010-11-15 13:52:23.796 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-11-15 13:52:24.093 Reading private key file "C:\SIGMA\jobs\docSync\keys\qhubftp\privateKey-qhubftp.ppk"
! 2010-11-15 13:52:24.093 Using username "xxxxxx".
. 2010-11-15 13:52:24.406 Offered public key
. 2010-11-15 13:52:24.703 Offer of public key accepted
! 2010-11-15 13:52:24.703 Authenticating with public key "rsa-key-20101006"
. 2010-11-15 13:52:25.125 Access granted
. 2010-11-15 13:52:25.437 Opened channel for session
. 2010-11-15 13:52:26.171 Started a shell/command
. 2010-11-15 13:52:26.171 --------------------------------------------------------------------------
. 2010-11-15 13:52:26.171 Using SFTP protocol.
. 2010-11-15 13:52:26.171 Doing startup conversation with host.
> 2010-11-15 13:52:26.171 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-11-15 13:52:26.937 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-11-15 13:52:26.937 SFTP version 3 negotiated.
. 2010-11-15 13:52:26.937 We believe the server has signed timestamps bug
. 2010-11-15 13:52:26.937 We will use UTF-8 strings for status messages only
. 2010-11-15 13:52:26.937 Getting current directory name.
. 2010-11-15 13:52:26.937 Getting real path for '.'
> 2010-11-15 13:52:26.937 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-11-15 13:52:27.218 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2010-11-15 13:52:27.218 Real path is '/'
. 2010-11-15 13:52:27.218 Startup conversation with host finished.
. 2010-11-15 13:52:27.234 Cached directory change via "/apps" to "/apps".
. 2010-11-15 13:52:27.234 Getting current directory name.
. 2010-11-15 13:52:27.234 Closing connection.
. 2010-11-15 13:52:27.234 Sending special code: 12
. 2010-11-15 13:52:27.234 Sent EOF message
Will greatly appreciate your help in this.
Anirudh
anirudh.chhabra
Got it working. Was missing the local option - and need to give full paths.
So the correct command is :
synchronize local "F:\apps" docs
where F:\apps - my local directory
docs - my remote directory
