Topic "WINSCP "Waiting for data timed out" error"
srinidhi27
I am trying to upload a file to SFTP server using Winscp, the transfer is Ok, most of the times but sometimes i get the following error:
[i]2010-11-17 05:01:30.615 --------------------------------------------------------------------------
. 2010-11-17 05:01:30.615 WinSCP Version 4.2.9 (Build 938) (OS 5.2.3790 Service Pack 2)
. 2010-11-17 05:01:30.615 Login time: Wednesday, November 17, 2010 5:01:30 AM
. 2010-11-17 05:01:30.615 --------------------------------------------------------------------------
. 2010-11-17 05:01:30.615 Session name: xxx@xxxx
. 2010-11-17 05:01:30.615 Host name: xxxx (Port: 22)
. 2010-11-17 05:01:30.615 User name: xxxx (Password: Yes, Key file: No)
. 2010-11-17 05:01:30.615 Tunnel: No
. 2010-11-17 05:01:30.615 Transfer Protocol: SFTP (SCP)
. 2010-11-17 05:01:30.615 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-11-17 05:01:30.615 Proxy: none
. 2010-11-17 05:01:30.615 SSH protocol version: 2; Compression: No
. 2010-11-17 05:01:30.615 Bypass authentication: No
. 2010-11-17 05:01:30.615 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-11-17 05:01:30.615 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-11-17 05:01:30.615 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-11-17 05:01:30.615 SFTP Bugs: -,-
. 2010-11-17 05:01:30.615 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-11-17 05:01:30.615 Shell: default
. 2010-11-17 05:01:30.615 EOL: 0, UTF: 2
. 2010-11-17 05:01:30.615 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-11-17 05:01:30.615 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-11-17 05:01:30.615 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-11-17 05:01:30.615 Cache directory changes: Yes, Permanent: Yes
. 2010-11-17 05:01:30.615 DST mode: 1
. 2010-11-17 05:01:30.615 Looking up host "xxxx"
. 2010-11-17 05:01:30.615 Connecting to xxx port 22
. 2010-11-17 05:01:45.631 Waiting for data timed out, asking user what to do.
. 2010-11-17 05:01:45.631 Asking user:
. 2010-11-17 05:01:45.631 Host is not communicating for 15 seconds.
. 2010-11-17 05:01:45.631 Wait for another 15 seconds? ()
. 2010-11-17 05:01:45.631 Attempt to close connection due to fatal exception:
* 2010-11-17 05:01:45.631 Terminated by user.
. 2010-11-17 05:01:45.631 Closing connection.
. 2010-11-17 05:01:45.631 Sending special code: 12[/i]
What could have possibly gone wrong. The network on server side seems to be ok, as per the server logs. Is it the network issue from my side?[/i]
srinidhi27
anybody help
