Topic "Specal Character in File name"
sivakl2001
Hi if special Character in filename i got the Error Message
Error Code : 2
File or Folder doesn't exist
p.Arguments = "/console /command " & """" & "option batch on" & """ " & """" & "open " & My.Settings.FTPUsername & ":" & My.Settings.FTPPassword & "@" & My.Settings.FTPIp & """ " & """" & "put " & My.Settings.DestinationPath & "\" & vgrid.Item(1, i).Value '& """ " & """" & "exit" & """"
sivakl2001
Hi sorry if the Filename contains SPACE couldn't upload file
Error Code : 2
So have you resolved your problem or not?
sivakl2001
Not yet can uhelp me to solve this pbm
You need to enclose the file path to double-quotes
https://winscp.net/eng/docs/scripting#syntax
sivakl2001
I try to put the file name inside the double quoute but still i couldn't upload filename with space
p.Arguments = "/console /command " & """" & "option batch on" & """ " & """" & "open " & My.Settings.FTPUsername & ":" & My.Settings.FTPPassword & "@" & My.Settings.FTPIp & """ " & """" & "put "" " & My.Settings.DestinationPath & "\" & vgrid.Item(1, i).Value '& " "" "" " & """" & "exit" & """"
how to change the current active directory by vb.net code
But in your case you need to quadruple the double-quotes actually. See also here:
http://winscp.net/eng/docs/commandline#syntax
