Topic "Random "Waiting for data timed out, asking user what to do.'"
digitaldweller
Howdy,
Version: 4.2.8 build 818
Transfer method: SFTP via vbscript/automation
Windows Server 2003 SP 2
I know this particular error has been discussed quite a bit in the forums however I have been unable to find a
resolution from reading through pretty much any thread I can find on the subject so wanted to throw this out
there if anyone has any ideas.
Receiving "Waiting for data timed out, asking user what to do." randomly durring a script run, also bombing out
in the middle of the transefer after re-attempting the transfer automagically. However the file seems to end up
being received properly (Multiple Times).
Also to note, on the server side is a shared 'in' directory which a job monitors when a file completes and it
moves it out of the directory, not sure if this is related or not but the vendor ensures me that it will not move
a file until it has been completely uploaded and they have never run into this in the past (they are a large
vendor) so I don't think that's the issue, just suspecious that's all. But this is also an issue since when the
the WinSCP session tries to connect again it loads the file again and they receive multiple files (which is a
problem in my scenario).
If I can have it not talk back, not look to ensure the file was received, just send and forget it without
re-trying I'd be a happy man as the multiple files that end up being received are the major issue.
Here's the script command being executed and the log:
E:\WinSCP\winscp.exe /console /log=.\logs\ftplog.txt /command "option batch continue" "open
theusername:thepassword@theurl -timeout=30" "lcd thelocaldir" "put thefilename" "exit"
Client Log as follows & INI file attached, unable to provide server log as it's 3rd party vendor.
Thanks in advance for anyone who has any ideas on this one.
. 2010-11-22 17:05:01.184 --------------------------------------------------------------------------
. 2010-11-22 17:05:01.184 WinSCP Version 4.2.8 (Build 818) (OS 5.2.3790 Service Pack 2)
. 2010-11-22 17:05:01.184 Login time: Monday, November 22, 2010 5:05:01 PM
. 2010-11-22 17:05:01.184 Session name: xxxxx
. 2010-11-22 17:05:01.184 Host name: xxxx.com (Port: 22)
. 2010-11-22 17:05:01.184 User name: xxxx (Password: Yes, Key file: No)
. 2010-11-22 17:05:01.184 Tunnel: No
. 2010-11-22 17:05:01.184 Transfer Protocol: SFTP (SCP)
. 2010-11-22 17:05:01.184 Ping type: -, Ping interval: 30 sec; Timeout: 30 sec
. 2010-11-22 17:05:01.184 Proxy: none
. 2010-11-22 17:05:01.184 SSH protocol version: 2; Compression: No
. 2010-11-22 17:05:01.184 Bypass authentication: No
. 2010-11-22 17:05:01.184 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-11-22 17:05:01.184 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-11-22 17:05:01.184 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-11-22 17:05:01.184 SFTP Bugs: -,-
. 2010-11-22 17:05:01.184 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-11-22 17:05:01.184 Shell: default
. 2010-11-22 17:05:01.184 EOL: 0, UTF: 2
. 2010-11-22 17:05:01.184 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-11-22 17:05:01.184 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-11-22 17:05:01.184 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-11-22 17:05:01.184 Cache directory changes: Yes, Permanent: Yes
. 2010-11-22 17:05:01.184 DST mode: 1
. 2010-11-22 17:05:01.184 Looking up host "xxxxx"
. 2010-11-22 17:05:01.200 Connecting to xxxx port 22
. 2010-11-22 17:05:01.325 Server version: SSH-2.0-SSHD
. 2010-11-22 17:05:01.325 We believe remote version has SSH-2 ignore bug
. 2010-11-22 17:05:01.325 Using SSH protocol version 2
. 2010-11-22 17:05:01.325 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-11-22 17:05:01.372 Using Diffie-Hellman with standard group "group14"
. 2010-11-22 17:05:01.372 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-11-22 17:05:02.028 Host key fingerprint is:
. 2010-11-22 17:05:02.028 ssh-rsa 2048 xxxx
. 2010-11-22 17:05:02.028 Initialised AES-256 CBC client->server encryption
. 2010-11-22 17:05:02.028 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-11-22 17:05:02.090 Initialised AES-256 CBC server->client encryption
. 2010-11-22 17:05:02.090 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-11-22 17:05:02.137 Using username "xxxxx".
. 2010-11-22 17:05:02.434 Prompt (5, SSH server: Password Authentication, Using keyboard-interactive
authentication., Password: )
. 2010-11-22 17:05:02.434 Using stored password.
. 2010-11-22 17:05:02.637 Access granted
. 2010-11-22 17:05:02.684 Opened channel for session
. 2010-11-22 17:05:02.965 Started a shell/command
. 2010-11-22 17:05:02.965 --------------------------------------------------------------------------
. 2010-11-22 17:05:02.965 Using SFTP protocol.
. 2010-11-22 17:05:02.965 Doing startup conversation with host.
> 2010-11-22 17:05:02.965 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-11-22 17:05:03.200 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-11-22 17:05:03.200 SFTP version 3 negotiated.
. 2010-11-22 17:05:03.200 We believe the server has signed timestamps bug
. 2010-11-22 17:05:03.200 We will use UTF-8 strings for status messages only
. 2010-11-22 17:05:03.200 Getting current directory name.
. 2010-11-22 17:05:03.200 Getting real path for '.'
> 2010-11-22 17:05:03.200 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-11-22 17:05:03.309 Type: SSH_FXP_NAME, Size: 51, Number: 16
. 2010-11-22 17:05:03.309 Real path is '/'
. 2010-11-22 17:05:03.309 Startup conversation with host finished.
< 2010-11-22 17:05:03.325 Script: Active session: [1] xxxxx@xxxxx.com
> 2010-11-22 17:05:03.325 Script: cd in
. 2010-11-22 17:05:03.325 Cached directory change via "in" to "/in".
. 2010-11-22 17:05:03.325 Getting current directory name.
< 2010-11-22 17:05:03.325 Script: /in
> 2010-11-22 17:05:03.325 Script: lcd F:\ExternalTransfer\tmp\
< 2010-11-22 17:05:03.325 Script: F:\ExternalTransfer\tmp
> 2010-11-22 17:05:03.325 Script: put xxxxx.gpg
. 2010-11-22 17:05:03.325 Copying 1 files/directories to remote directory "/in"
. 2010-11-22 17:05:03.325 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S
(102400); CalcS: No; Mask:
. 2010-11-22 17:05:03.325 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-11-22 17:05:03.325 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas;
*.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-11-22 17:05:03.325 File: "xxxxx.gpg"
. 2010-11-22 17:05:03.325 Copying "xxxxx.gpg" to remote directory started.
. 2010-11-22 17:05:03.340 Binary transfer mode selected.
. 2010-11-22 17:05:03.340 Checking existence of file.
> 2010-11-22 17:05:03.340 Type: SSH_FXP_LSTAT, Size: 38, Number: 263
< 2010-11-22 17:05:03.434 Type: SSH_FXP_STATUS, Size: 71, Number: 263
< 2010-11-22 17:05:03.434 Status code: 2
. 2010-11-22 17:05:03.434 Checking existence of partially transfered file.
> 2010-11-22 17:05:03.434 Type: SSH_FXP_LSTAT, Size: 47, Number: 519
< 2010-11-22 17:05:03.512 Type: SSH_FXP_STATUS, Size: 80, Number: 519
< 2010-11-22 17:05:03.512 Status code: 2
. 2010-11-22 17:05:03.512 Opening remote file.
> 2010-11-22 17:05:03.512 Type: SSH_FXP_OPEN, Size: 63, Number: 771
< 2010-11-22 17:05:03.669 Type: SSH_FXP_HANDLE, Size: 10, Number: 771
> 2010-11-22 17:05:03.669 Type: SSH_FXP_WRITE, Size: 4118, Number: 1286
. 2010-11-22 17:05:05.044 27 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-11-22 17:05:05.044 Type: SSH_FXP_CLOSE, Size: 10, Number: 5124
< 2010-11-22 17:05:05.169 Type: SSH_FXP_STATUS, Size: 49, Number: 4614
< 2010-11-22 17:05:05.434 Type: SSH_FXP_STATUS, Size: 49, Number: 4870
< 2010-11-22 17:05:05.434 Type: SSH_FXP_STATUS, Size: 40, Number: 5124
< 2010-11-22 17:05:05.434 Status code: 0
> 2010-11-22 17:05:05.434 Type: SSH_FXP_RENAME, Size: 80, Number: 5394
. 2010-11-22 17:05:35.436 Waiting for data timed out, asking user what to do.
. 2010-11-22 17:05:35.436 Asking user:
. 2010-11-22 17:05:35.436 Host is not communicating for 30 seconds.
. 2010-11-22 17:05:35.436 Wait for another 30 seconds? ()
. 2010-11-22 17:05:35.451 Attempt to close connection due to fatal exception:
* 2010-11-22 17:05:35.451 Terminated by user.
. 2010-11-22 17:05:35.451 Closing connection.
. 2010-11-22 17:05:35.451 Sending special code: 12
. 2010-11-22 17:05:35.451 Sent EOF message
. 2010-11-22 17:05:35.467 Connection was lost, asking what to do.
. 2010-11-22 17:05:35.467 Asking user:
. 2010-11-22 17:05:35.467 Terminated by user. ()
< 2010-11-22 17:05:41.717 Script: Searching for host...
. 2010-11-22 17:05:41.717 Looking up host "xxxxx.com"
. 2010-11-22 17:05:41.717 Connecting to xxxxx port 22
< 2010-11-22 17:05:41.780 Script: Connecting to host...
. 2010-11-22 17:05:41.842 Server version: SSH-2.0-SSHD
. 2010-11-22 17:05:41.842 We believe remote version has SSH-2 ignore bug
. 2010-11-22 17:05:41.842 Using SSH protocol version 2
. 2010-11-22 17:05:41.842 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-11-22 17:05:41.889 Using Diffie-Hellman with standard group "group14"
. 2010-11-22 17:05:41.889 Doing Diffie-Hellman key exchange with hash SHA-1
< 2010-11-22 17:05:42.483 Script: Authenticating...
. 2010-11-22 17:05:42.483 Host key fingerprint is:
. 2010-11-22 17:05:42.483 ssh-rsa 2048 xxxxx
. 2010-11-22 17:05:42.483 Initialised AES-256 CBC client->server encryption
. 2010-11-22 17:05:42.483 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-11-22 17:05:42.545 Initialised AES-256 CBC server->client encryption
. 2010-11-22 17:05:42.545 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-11-22 17:05:42.608 Using username "xxxx".
< 2010-11-22 17:05:42.608 Script: Using username "xxxx".
. 2010-11-22 17:05:42.920 Prompt (5, SSH server: Password Authentication, Using keyboard-interactive
. 2010-11-22 17:05:42.920 Using stored password.
< 2010-11-22 17:05:42.920 Script: Authenticating with pre-entered password.
. 2010-11-22 17:05:43.108 Access granted
. 2010-11-22 17:05:43.170 Opened channel for session
. 2010-11-22 17:05:43.436 Started a shell/command
< 2010-11-22 17:05:43.436 Script: Authenticated.
. 2010-11-22 17:05:43.436 Doing startup conversation with host.
< 2010-11-22 17:05:43.436 Script: Starting the session...
> 2010-11-22 17:05:43.436 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-11-22 17:05:43.686 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-11-22 17:05:43.686 SFTP version 3 negotiated.
. 2010-11-22 17:05:43.686 We believe the server has signed timestamps bug
. 2010-11-22 17:05:43.686 We will use UTF-8 strings for status messages only
< 2010-11-22 17:05:43.686 Script: Reading remote directory...
. 2010-11-22 17:05:43.686 Changing directory to "/in".
. 2010-11-22 17:05:43.686 Getting real path for '/in'
> 2010-11-22 17:05:43.686 Type: SSH_FXP_REALPATH, Size: 12, Number: 5648
< 2010-11-22 17:05:43.795 Type: SSH_FXP_NAME, Size: 55, Number: 5648
. 2010-11-22 17:05:43.795 Real path is '/in'
. 2010-11-22 17:05:43.795 Trying to open directory "/in".
> 2010-11-22 17:05:43.795 Type: SSH_FXP_LSTAT, Size: 12, Number: 5895
< 2010-11-22 17:05:43.889 Type: SSH_FXP_ATTRS, Size: 37, Number: 5895
. 2010-11-22 17:05:43.889 Getting current directory name.
. 2010-11-22 17:05:43.889 Startup conversation with host finished.
< 2010-11-22 17:05:43.889 Script: Session started.
. 2010-11-22 17:05:43.889 File: "xxxxx.gpg"
. 2010-11-22 17:05:43.889 Copying "xxxxx.gpg" to remote directory started.
. 2010-11-22 17:05:43.889 Binary transfer mode selected.
. 2010-11-22 17:05:43.889 Checking existence of file.
> 2010-11-22 17:05:43.889 Type: SSH_FXP_LSTAT, Size: 38, Number: 6151
< 2010-11-22 17:05:43.999 Type: SSH_FXP_ATTRS, Size: 37, Number: 6151
. 2010-11-22 17:05:43.999 Checking existence of partially transfered file.
> 2010-11-22 17:05:43.999 Type: SSH_FXP_LSTAT, Size: 47, Number: 6407
< 2010-11-22 17:05:44.077 Type: SSH_FXP_STATUS, Size: 80, Number: 6407
< 2010-11-22 17:05:44.077 Status code: 2
. 2010-11-22 17:05:44.077 Opening remote file.
> 2010-11-22 17:05:44.077 Type: SSH_FXP_OPEN, Size: 63, Number: 6659
< 2010-11-22 17:05:44.202 Type: SSH_FXP_HANDLE, Size: 10, Number: 6659
> 2010-11-22 17:05:44.202 Type: SSH_FXP_WRITE, Size: 4118, Number: 7174
. 2010-11-22 17:05:45.577 27 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-11-22 17:05:45.577 Type: SSH_FXP_CLOSE, Size: 10, Number: 11012
< 2010-11-22 17:05:45.702 Type: SSH_FXP_STATUS, Size: 49, Number: 10502
< 2010-11-22 17:05:45.967 Type: SSH_FXP_STATUS, Size: 49, Number: 10758
< 2010-11-22 17:05:45.967 Type: SSH_FXP_STATUS, Size: 40, Number: 11012
< 2010-11-22 17:05:45.967 Status code: 0
> 2010-11-22 17:05:45.967 Type: SSH_FXP_REMOVE, Size: 38, Number: 11277
< 2010-11-22 17:05:46.061 Type: SSH_FXP_STATUS, Size: 37, Number: 11277
< 2010-11-22 17:05:46.061 Status code: 0
> 2010-11-22 17:05:46.061 Type: SSH_FXP_RENAME, Size: 80, Number: 11538
. 2010-11-22 17:06:16.062 Waiting for data timed out, asking user what to do.
. 2010-11-22 17:06:16.062 Asking user:
. 2010-11-22 17:06:16.062 Host is not communicating for 30 seconds.
. 2010-11-22 17:06:16.062 Wait for another 30 seconds? ()
. 2010-11-22 17:06:16.062 Attempt to close connection due to fatal exception:
* 2010-11-22 17:06:16.062 Terminated by user.
. 2010-11-22 17:06:16.062 Closing connection.
. 2010-11-22 17:06:16.062 Sending special code: 12
. 2010-11-22 17:06:16.062 Sent EOF message
. 2010-11-22 17:06:16.062 Connection was lost, asking what to do.
. 2010-11-22 17:06:16.062 Terminated by user. ()
< 2010-11-22 17:06:22.313 Script: Searching for host...
. 2010-11-22 17:06:22.313 Looking up host "xxxxx.com"
. 2010-11-22 17:06:22.313 Connecting to xxxx port 22
< 2010-11-22 17:06:22.360 Script: Connecting to host...
. 2010-11-22 17:06:22.422 Server version: SSH-2.0-SSHD
. 2010-11-22 17:06:22.422 We believe remote version has SSH-2 ignore bug
. 2010-11-22 17:06:22.422 Using SSH protocol version 2
. 2010-11-22 17:06:22.422 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-11-22 17:06:22.485 Using Diffie-Hellman with standard group "group14"
. 2010-11-22 17:06:22.485 Doing Diffie-Hellman key exchange with hash SHA-1
< 2010-11-22 17:06:23.078 Script: Authenticating...
. 2010-11-22 17:06:23.078 Host key fingerprint is:
. 2010-11-22 17:06:23.078 ssh-rsa 2048 xxxxx
. 2010-11-22 17:06:23.078 Initialised AES-256 CBC client->server encryption
. 2010-11-22 17:06:23.078 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-11-22 17:06:23.141 Initialised AES-256 CBC server->client encryption
. 2010-11-22 17:06:23.141 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-11-22 17:06:23.203 Using username "xxxxx".
< 2010-11-22 17:06:23.203 Script: Using username "xxxxx".
. 2010-11-22 17:06:23.500 Prompt (5, SSH server: Password Authentication, Using keyboard-interactive
. 2010-11-22 17:06:23.500 Using stored password.
< 2010-11-22 17:06:23.500 Script: Authenticating with pre-entered password.
. 2010-11-22 17:06:23.657 Access granted
. 2010-11-22 17:06:23.719 Opened channel for session
. 2010-11-22 17:06:24.000 Started a shell/command
< 2010-11-22 17:06:24.000 Script: Authenticated.
. 2010-11-22 17:06:24.000 Doing startup conversation with host.
< 2010-11-22 17:06:24.000 Script: Starting the session...
> 2010-11-22 17:06:24.000 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-11-22 17:06:24.266 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-11-22 17:06:24.266 SFTP version 3 negotiated.
. 2010-11-22 17:06:24.266 We believe the server has signed timestamps bug
. 2010-11-22 17:06:24.266 We will use UTF-8 strings for status messages only
< 2010-11-22 17:06:24.266 Script: Reading remote directory...
. 2010-11-22 17:06:24.266 Changing directory to "/in".
. 2010-11-22 17:06:24.266 Getting real path for '/in'
> 2010-11-22 17:06:24.266 Type: SSH_FXP_REALPATH, Size: 12, Number: 11792
< 2010-11-22 17:06:24.375 Type: SSH_FXP_NAME, Size: 55, Number: 11792
. 2010-11-22 17:06:24.375 Real path is '/in'
. 2010-11-22 17:06:24.375 Trying to open directory "/in".
> 2010-11-22 17:06:24.375 Type: SSH_FXP_LSTAT, Size: 12, Number: 12039
< 2010-11-22 17:06:24.469 Type: SSH_FXP_ATTRS, Size: 37, Number: 12039
. 2010-11-22 17:06:24.469 Getting current directory name.
. 2010-11-22 17:06:24.469 Startup conversation with host finished.
< 2010-11-22 17:06:24.469 Script: Session started.
. 2010-11-22 17:06:24.469 File: "xxxxx.gpg"
. 2010-11-22 17:06:24.469 Copying "xxxxx.gpg" to remote directory started.
. 2010-11-22 17:06:24.469 Binary transfer mode selected.
. 2010-11-22 17:06:24.469 Checking existence of file.
> 2010-11-22 17:06:24.469 Type: SSH_FXP_LSTAT, Size: 38, Number: 12295
< 2010-11-22 17:06:24.578 Type: SSH_FXP_ATTRS, Size: 37, Number: 12295
. 2010-11-22 17:06:24.578 Checking existence of partially transfered file.
> 2010-11-22 17:06:24.578 Type: SSH_FXP_LSTAT, Size: 47, Number: 12551
< 2010-11-22 17:06:24.641 Type: SSH_FXP_STATUS, Size: 80, Number: 12551
< 2010-11-22 17:06:24.641 Status code: 2
. 2010-11-22 17:06:24.641 Opening remote file.
> 2010-11-22 17:06:24.641 Type: SSH_FXP_OPEN, Size: 63, Number: 12803
< 2010-11-22 17:06:24.782 Type: SSH_FXP_HANDLE, Size: 10, Number: 12803
> 2010-11-22 17:06:24.782 Type: SSH_FXP_WRITE, Size: 4118, Number: 13318
. 2010-11-22 17:06:26.141 27 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-11-22 17:06:26.141 Type: SSH_FXP_CLOSE, Size: 10, Number: 17156
< 2010-11-22 17:06:26.266 Type: SSH_FXP_STATUS, Size: 49, Number: 16646
< 2010-11-22 17:06:26.610 Type: SSH_FXP_STATUS, Size: 49, Number: 16902
< 2010-11-22 17:06:26.610 Type: SSH_FXP_STATUS, Size: 40, Number: 17156
< 2010-11-22 17:06:26.610 Status code: 0
> 2010-11-22 17:06:26.610 Type: SSH_FXP_REMOVE, Size: 38, Number: 17421
< 2010-11-22 17:06:26.688 Type: SSH_FXP_STATUS, Size: 37, Number: 17421
< 2010-11-22 17:06:26.688 Status code: 0
> 2010-11-22 17:06:26.688 Type: SSH_FXP_RENAME, Size: 80, Number: 17682
< 2010-11-22 17:06:47.408 Type: SSH_FXP_STATUS, Size: 37, Number: 17682
< 2010-11-22 17:06:47.408 Status code: 0
> 2010-11-22 17:06:47.408 Type: SSH_FXP_SETSTAT, Size: 54, Number: 13065
< 2010-11-22 17:06:47.517 Type: SSH_FXP_STATUS, Size: 48, Number: 13065
< 2010-11-22 17:06:47.517 Status code: 2, Message: 13065, Server: Specified file path is invalid., Language:
* 2010-11-22 17:06:47.517 (ETerminal) No such file or directory.
* 2010-11-22 17:06:47.517 Error code: 2
* 2010-11-22 17:06:47.517 Error message from server: Specified file path is invalid.
* 2010-11-22 17:06:47.517 Request code: 9
. 2010-11-22 17:06:47.517 Asking user:
. 2010-11-22 17:06:47.517 Upload of file 'xxxxx.gpg' was successful, but error occurred while setting the
permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("No such file
or directory.
. 2010-11-22 17:06:47.517 Error code: 2
. 2010-11-22 17:06:47.517 Error message from server: Specified file path is invalid.
. 2010-11-22 17:06:47.517 Request code: 9")
* 2010-11-22 17:06:47.517 (EScpSkipFile) Upload of file 'xxxxx.gpg' was successful, but error occurred while
setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2010-11-22 17:06:47.517 No such file or directory.
. 2010-11-22 17:06:47.517 Script: Failed
> 2010-11-22 17:06:47.517 Script: exit
. 2010-11-22 17:06:47.517 Closing connection.
. 2010-11-22 17:06:47.517 Sending special code: 12
. 2010-11-22 17:06:47.517 Sent EOF message
INI FILE:
[Configuration\CDCache]
blahblahblah
[SshHostKeys]
rsa2@22:blahblahblah
[Configuration\Interface]
RandomSeedFile=%25APPDATA%25%5Cwinscp.rnd
PuttyRegistryStorageKey=Software%5CSimonTatham%5CPuTTY
ConfirmOverwriting=1
ConfirmResume=1
AutoReadDirectoryAfterOp=1
SessionReopenAuto=0
SessionReopenBackground=2000
SessionReopenTimeout=0
TunnelLocalPortNumberLow=50000
TunnelLocalPortNumberHigh=50099
CacheDirectoryChangesMaxSize=100
ShowFtpWelcomeMessage=0
ContinueOnError=0
ConfirmCommandSession=1
SynchronizeParams=66
SynchronizeOptions=5
SynchronizeModeAuto=-1
SynchronizeMode=0
MaxWatchDirectories=500
QueueTransfersLimit=2
QueueAutoPopup=1
QueueRememberPassword=0
PuttySession=WinSCP%20temporary%20session
PuttyPath=%25PROGRAMFILES%25%5CPuTTY%5Cputty.exe
PuttyPassword=0
TelnetForFtpInPutty=1
IgnoreCancelBeforeFinish=DFBC9A785634023F
BeepOnFinish=0
BeepOnFinishAfter=176CC1166CC1363F
SynchronizeBrowsing=0
KeepUpToDateChangeDelay=500
ChecksumAlg=md5
SessionReopenAutoIdle=0
Interface=0
ShowAdvancedLoginOptions=1
ConfirmExitOnCompletion=1
CopyOnDoubleClick=2
CopyOnDoubleClickConfirmation=0
DDAllowMove=0
DDAllowMoveInit=0
DDTransferConfirmation=1
DDTemporaryDirectory=E:%5CWinSCP
DDWarnLackOfTempSpace=1
DDWarnLackOfTempSpaceRatio=9A9999999999F13F
DeleteToRecycleBin=1
DimmHiddenFiles=1
RenameWholeName=0
SelectDirectories=0
SelectMask=%2A.%2A
ShowHiddenFiles=1
ShowInaccesibleDirectories=1
ConfirmTransferring=1
ConfirmDeleting=1
ConfirmRecycling=1
ConfirmClosingSession=1
AutoStartSession=
UseLocationProfiles=0
UseSharedBookmarks=0
LocaleSafe=1033
DDExtEnabled=1
DDExtTimeout=1000
DefaultDirIsHome=1
TemporaryDirectoryAppendSession=0
TemporaryDirectoryAppendPath=1
TemporaryDirectoryCleanup=1
ConfirmTemporaryDirectoryCleanup=1
PreservePanelState=1
Theme=OfficeXP
PathInCaption=0
MinimizeToTray=0
BalloonNotifications=1
NotificationsTimeout=10
NotificationsStickTime=2
CopyParamAutoSelectNotice=1
SessionToolbarAutoShown=0
LockToolbars=0
AutoOpenInPutty=0
LastMonitor=0
VersionHistory=40208818,stable
[Configuration\Logging]
Logging=0
LogFileName=
LogFileAppend=1
LogWindowLines=100
LogProtocol=0
LogActions=0
LogView=0
LogWindowOnStartup=1
LogWindowParams=-1;-1;500;400
[Configuration\Interface\CopyParam]
AddXToDirectories=1
Masks=%2A.%2Ahtml;%20%2A.htm;%20%2A.txt;%20%2A.php;%20%2A.php3;%20%2A.cgi;%20%2A.c;%20%2A.cpp;%20%2A.h;%20%2A.pas
;%20%2A.bas;%20%2A.tex;%20%2A.pl;%20.htaccess;%20%2A.xtml;%20%2A.css;%20%2A.cfg;%20%2A.ini;%20%2A.sh;%20%2A.xml
FileNameCase=0
PreserveReadOnly=0
PreserveTime=1
PreserveRights=0
IgnorePermErrors=1
Text=rw-r--r--
TransferMode=2
ResumeSupport=2
ResumeThreshold=102400
ReplaceInvalidChars=1
LocalInvalidChars=/%5C:%2A%3F"<>|
CalculateSize=1
ExcludeFileMask=
NegativeExclude=0
ClearArchive=0
CPSLimit=0
Queue=0
QueueNoConfirmation=1
QueueIndividually=0
NewerOnly=0
CopyParamList=-1
[Configuration\Interface\NewDirectory]
Valid=00
[Configuration\Interface\SynchronizeChecklist]
WindowParams=0;-1;-1;600;450;0
ListParams=1;1|150,1;100,1;80,1;130,1;25,1;100,1;80,1;130,1|0;1;2;3;4;5;6;7
[Configuration\Interface\FindFile]
WindowParams=646,481
ListParams=3;1|125,1;181,1;80,1;122,1|0;1;2;3
[Configuration\Interface\ConsoleWin]
WindowSize=570,430
[Configuration\History\SpeedLimit]
0=Unlimited
1=1024
2=512
3=256
4=128
5=64
6=32
7=16
8=8
[Configuration\Interface\Editor]
FontName=Courier%20New
FontHeight=-12
FontStyle=0
FontCharset=1
WordWrap=0
FindTextA=
ReplaceTextA=
FindMatchCase=0
FindWholeWord=0
FindDown=1
TabSize=7
MaxEditors=500
EarlyClose=2
SDIShellEditor=0
WindowParams=
[Configuration\Interface\QueueView]
Height=100
Layout=70,160,160,80,80,80
Show=1
LastHideShow=1
ToolBar=0
[Configuration\Interface\Updates]
Period=0
LastCheck=000000000000F03F
HaveResults=0
ShownResults=0
BetaVersions=2
ConnectionType=1
ProxyHost=
ProxyPort=8080
ForVersion=0
Version=0
Message=
Critical=0
Release=
Disabled=0
Url=
UrlButton=
[Configuration\Interface\Explorer]
ToolbarsLayout=Queue_Visible=1,Queue_LastDock=QueueDock,Queue_DockRow=0,Queue_DockPos=-1,Queue_FloatLeft=0,Queue_
FloatTop=0,Queue_FloatRightX=0,Menu_Visible=1,Menu_DockedTo=TopDock,Menu_LastDock=TopDock,Menu_DockRow=0,Menu_Doc
kPos=0,Menu_FloatLeft=0,Menu_FloatTop=0,Menu_FloatRightX=0,Buttons_Visible=1,Buttons_DockedTo=TopDock,Buttons_Las
tDock=TopDock,Buttons_DockRow=2,Buttons_DockPos=0,Buttons_FloatLeft=0,Buttons_FloatTop=0,Buttons_FloatRightX=0,Se
lection_Visible=0,Selection_DockedTo=TopDock,Selection_LastDock=TopDock,Selection_DockRow=3,Selection_DockPos=0,S
election_FloatLeft=227,Selection_FloatTop=445,Selection_FloatRightX=0,Session_Visible=0,Session_DockedTo=TopDock,
Session_LastDock=TopDock,Session_DockRow=6,Session_DockPos=0,Session_FloatLeft=39,Session_FloatTop=160,Session_Fl
oatRightX=0,Preferences_Visible=1,Preferences_DockedTo=TopDock,Preferences_LastDock=TopDock,Preferences_DockRow=4
,Preferences_DockPos=0,Preferences_FloatLeft=0,Preferences_FloatTop=0,Preferences_FloatRightX=0,Sort_Visible=0,So
rt_DockedTo=TopDock,Sort_LastDock=TopDock,Sort_DockRow=5,Sort_DockPos=0,Sort_FloatLeft=0,Sort_FloatTop=0,Sort_Flo
atRightX=0,Address_Visible=1,Address_DockedTo=TopDock,Address_LastDock=TopDock,Address_DockRow=1,Address_DockPos=
0,Address_FloatLeft=0,Address_FloatTop=0,Address_FloatRightX=0,Updates_Visible=1,Updates_DockedTo=TopDock,Updates
_LastDock=TopDock,Updates_DockRow=4,Updates_DockPos=302,Updates_FloatLeft=0,Updates_FloatTop=0,Updates_FloatRight
X=0,Transfer_Visible=1,Transfer_DockedTo=TopDock,Transfer_LastDock=TopDock,Transfer_DockRow=4,Transfer_DockPos=15
5,Transfer_FloatLeft=0,Transfer_FloatTop=0,Transfer_FloatRightX=0CustomCommands_Visible=0,CustomCommands_DockedTo
=TopDock,CustomCommands_LastDock=TopDock,CustomCommands_DockRow=7,CustomCommands_DockPos=0,CustomCommands_FloatLe
ft=0,CustomCommands_FloatTop=0,CustomCommands_FloatRightX=0
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,1;20,0;150,0;125,0|0;1;8;2;3;4;5;6;7
LastLocalTargetDirectory=C:%5CDocuments%20and%20Settings%5Cjm60188%5CMy%20Documents
StatusBar=1
WindowParams=-1;-1;600;400;0
ViewStyle=0
ShowFullAddress=1
DriveView=1
DriveViewWidth=180
[Configuration\Interface\Commander]
kPos=0,Menu_FloatLeft=0,Menu_FloatTop=0,Menu_FloatRightX=0,Selection_Visible=1,Selection_DockedTo=TopDock,Selecti
on_LastDock=TopDock,Selection_DockRow=1,Selection_DockPos=280,Selection_FloatLeft=0,Selection_FloatTop=0,Selectio
n_FloatRightX=0,Preferences_Visible=1,Preferences_DockedTo=TopDock,Preferences_LastDock=TopDock,Preferences_DockR
ow=1,Preferences_DockPos=0,Preferences_FloatLeft=0,Preferences_FloatTop=0,Preferences_FloatRightX=0,Session_Visib
le=0,Session_DockedTo=TopDock,Session_LastDock=TopDock,Session_DockRow=1,Session_DockPos=602,Session_FloatLeft=38
0,Session_FloatTop=197,Session_FloatRightX=0,Command_Visible=0,Command_DockedTo=TopDock,Command_LastDock=TopDock,
Command_DockRow=2,Command_DockPos=0,Command_FloatLeft=0,Command_FloatTop=0,Command_FloatRightX=0,Sort_Visible=0,S
ort_DockedTo=TopDock,Sort_LastDock=TopDock,Sort_DockRow=3,Sort_DockPos=0,Sort_FloatLeft=0,Sort_FloatTop=0,Sort_Fl
oatRightX=0,Commands_Visible=1,Commands_DockedTo=TopDock,Commands_LastDock=TopDock,Commands_DockRow=1,Commands_Do
ckPos=97,Commands_FloatLeft=0,Commands_FloatTop=0,Commands_FloatRightX=0,Updates_Visible=1,Updates_DockedTo=TopDo
ck,Updates_LastDock=TopDock,Updates_DockRow=1,Updates_DockPos=557,Updates_FloatLeft=0,Updates_FloatTop=0,Updates_
FloatRightX=0,Transfer_Visible=1,Transfer_DockedTo=TopDock,Transfer_LastDock=TopDock,Transfer_DockRow=1,Transfer_
DockPos=434,Transfer_FloatLeft=0,Transfer_FloatTop=0,Transfer_FloatRightX=0,UploadDownload_Visible=0,UploadDownlo
ad_DockedTo=TopDock,UploadDownload_LastDock=TopDock,UploadDownload_DockRow=4,UploadDownload_DockPos=0,UploadDownl
oad_FloatLeft=0,UploadDownload_FloatTop=0,UploadDownload_FloatRightX=0,CustomCommands_Visible=0,CustomCommands_Do
ckedTo=TopDock,CustomCommands_LastDock=TopDock,CustomCommands_DockRow=5,CustomCommands_DockPos=0,CustomCommands_F
loatLeft=0,CustomCommands_FloatTop=0,CustomCommands_FloatRightX=0,RemoteHistory_Visible=1,RemoteHistory_DockedTo=
RemoteTopDock,RemoteHistory_LastDock=RemoteTopDock,RemoteHistory_DockRow=0,RemoteHistory_DockPos=208,RemoteHistor
y_FloatLeft=0,RemoteHistory_FloatTop=0,RemoteHistory_FloatRightX=0,RemoteNavigation_Visible=1,RemoteNavigation_Do
ckedTo=RemoteTopDock,RemoteNavigation_LastDock=RemoteTopDock,RemoteNavigation_DockRow=0,RemoteNavigation_DockPos=
288,RemoteNavigation_FloatLeft=0,RemoteNavigation_FloatTop=0,RemoteNavigation_FloatRightX=0,RemotePath_Visible=1,
RemotePath_DockedTo=RemoteTopDock,RemotePath_LastDock=RemoteTopDock,RemotePath_DockRow=0,RemotePath_DockPos=0,Rem
otePath_FloatLeft=0,RemotePath_FloatTop=0,RemotePath_FloatRightX=0,LocalHistory_Visible=1,LocalHistory_DockedTo=L
ocalTopDock,LocalHistory_LastDock=LocalTopDock,LocalHistory_DockRow=0,LocalHistory_DockPos=207,LocalHistory_Float
Left=0,LocalHistory_FloatTop=0,LocalHistory_FloatRightX=0,LocalNavigation_Visible=1,LocalNavigation_DockedTo=Loca
lTopDock,LocalNavigation_LastDock=LocalTopDock,LocalNavigation_DockRow=0,LocalNavigation_DockPos=287,LocalNavigat
ion_FloatLeft=0,LocalNavigation_FloatTop=0,LocalNavigation_FloatRightX=0,LocalPath_Visible=1,LocalPath_DockedTo=L
ocalTopDock,LocalPath_LastDock=LocalTopDock,LocalPath_DockRow=0,LocalPath_DockPos=0,LocalPath_FloatLeft=0,LocalPa
th_FloatTop=0,LocalPath_FloatRightX=0,Toolbar_Visible=1,Toolbar_DockedTo=BottomDock,Toolbar_LastDock=BottomDock,T
oolbar_DockRow=1,Toolbar_DockPos=0,Toolbar_FloatLeft=0,Toolbar_FloatTop=0,Toolbar_FloatRightX=1,CommandLine_Visib
le=0,CommandLine_DockedTo=BottomDock,CommandLine_LastDock=BottomDock,CommandLine_DockRow=0,CommandLine_DockPos=0,
CommandLine_FloatLeft=0,CommandLine_FloatTop=0,CommandLine_FloatRightX=0
CurrentPanel=1
LocalPanelWidth=00000080D965D73F
SwappedPanels=0
StatusBar=1
WindowParams=170;7;1190;671;0
ExplorerStyleSelection=0
PreserveLocalDirectory=0
CompareByTime=1
CompareBySize=0
FullRowSelect=1
TreeOnLeft=0
[Configuration\Interface\Commander\LocalPanel]
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,0|0;1;2;3;4;5
StatusBar=1
DriveView=0
DriveViewHeight=100
DriveViewWidth=100
[Configuration\Interface\Commander\RemotePanel]
DirViewParams=0;1;0|337,1;70,1;101,1;79,1;62,1;55,0;20,0;150,0;125,0|0;1;8;2;3;4;5;6;7
StatusBar=1
DriveView=0
DriveViewHeight=100
DriveViewWidth=100
[Configuration\Security]
UseMasterPassword=0
MasterPasswordVerifier=
[Sessions\xxxx%20Production%20FTP]
HostName=xxxx.com
UserName=xxxx
Password=xxxx
[Configuration\History\Mask]
0=%2A.%2Ahtml;%20%2A.htm;%20%2A.txt;%20%2A.php;%20%2A.php3;%20%2A.cgi;%20%2A.c;%20%2A.cpp;%20%2A.h;%20%2A.pas;%20
[Configuration\Interface\Editor\0]
FileMask=%2A.%2A
Editor=0
ExternalEditor=
ExternalEditorText=1
SDIExternalEditor=0
DetectMDIExternalEditor=0
[Configuration\Interface\Editor\1]
FileMask=%2A.%2A
Editor=1
ExternalEditor=notepad.exe
SDIExternalEditor=0
[Configuration\Banners]
XXXXXX
Does the script abort itself on the error or does it stall forever?
