Topic "Timeout when transferring from VMWare ESXi 4.1 Host"
TheBerserker
When I try to download Large Files (.vmdk) off a SSH-enabled-VMWare ESXi 4.1 host,
connection times out ("Host is not communicating for bla seconds") after ~500Mb of transferred data.
Tried the current WinSCP 4.2.9 and 4.3 beta versions, behaviour is the same.
Is this a WinSCP-Bug or is it a VMWare-Limitation?
Help appreciated.
Do you have the same problem with other SFTP clients?
TheBerserker
Just tried large transfers with pscp.exe (commandline) from the putty-package: works!
maximsm
I'm experiencing this issue as well.
Is there any solution for this issue?
Thanks!
Gamebhai
Just select SCP instead of SFTP, you'll be fine. Smile
Tarchan
Any updates on this? I am having the same problem with version 4.3.2 connecting to ESXi. This is for SCP transfers using either GUI or console.
I want to be able to do a synchronize through a batch job, but cant get a normal transfer to work. I will try some older versions of WinSCP and see if this is something new.
Tarchan
Just thought that I should note that I am able to do this transfer using either putty (pscp.exe) and Veeam FastSCP.
I went back and tried version 4.2.6, but no luck.
gargameeel
...everything was working perfectly - then i installed 4.35.
every copy from esxi 4.1 to local hdd is stopping at 499.994.624 bytes.
i tried different settings - and also installed 5.04 beta (which is faster) but always the same problem...
here the same:
http://communities.vmware.com/thread/330312
the only solution for me was installing 4.18 which is working fluently Very Happy
