Topic "Network error: Permission denied"
kryman
Hello folks,
{Windows 7 Home Premium x64, WinSCP Version 4.3.0 (BUILD 1029)}
I've got "Network error: Permission denied" message box on any attempts to connect to Linux servers. At the same time I've no any problems to connect to the servers by PuTTY client or through another clients or hosts.
The bug was appeared some days ago. I didn't get similar problems on previous versions.
Look at winscp logs for more info:
. 2010-11-25 10:53:48.503 --------------------------------------------------------------------------
. 2010-11-25 10:53:48.503 WinSCP Version 4.3.0 (Build 1029) (OS 6.1.7600)
. 2010-11-25 10:53:48.504 Login time: Thursday, November 25, 2010 10:53:48 AM
. 2010-11-25 10:53:48.504 --------------------------------------------------------------------------
. 2010-11-25 10:53:48.504 Session name: kryman@XXX.XX.XX.210
. 2010-11-25 10:53:48.504 Host name: XXX.XX.XX.210 (Port: 22)
. 2010-11-25 10:53:48.504 User name: kryman (Password: No, Key file: No)
. 2010-11-25 10:53:48.504 Tunnel: No
. 2010-11-25 10:53:48.504 Transfer Protocol: SCP
. 2010-11-25 10:53:48.504 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-11-25 10:53:48.504 Proxy: none
. 2010-11-25 10:53:48.504 SSH protocol version: 2; Compression: No
. 2010-11-25 10:53:48.505 Bypass authentication: No
. 2010-11-25 10:53:48.505 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-11-25 10:53:48.505 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-11-25 10:53:48.505 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-11-25 10:53:48.505 SFTP Bugs: -,-
. 2010-11-25 10:53:48.505 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-11-25 10:53:48.505 Shell: default
. 2010-11-25 10:53:48.505 EOL: 0, UTF: 2
. 2010-11-25 10:53:48.505 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-11-25 10:53:48.505 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-11-25 10:53:48.505 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-11-25 10:53:48.505 Cache directory changes: Yes, Permanent: Yes
. 2010-11-25 10:53:48.505 DST mode: 1
. 2010-11-25 10:53:48.505 --------------------------------------------------------------------------
. 2010-11-25 10:53:48.542 Looking up host "XXX.XX.XX.210"
. 2010-11-25 10:53:48.542 Connecting to XXX.XX.XX.210 port 22
. 2010-11-25 10:53:48.917 Failed to connect to XXX.XX.XX.210: Network error: Permission denied
* 2010-11-25 10:53:48.924 (ESshFatal) Network error: Permission denied
Please read
http://winscp.net/eng/docs/faq_connection_refused
