Topic "Keepuptodate"
sluice
Is it correct that if I don't set the reconnecttime option with keepuptodate and there is a break in connection, the session finishes? Is the opposite true, that if I set the option reconnectime to 1 minute then WinSCP will automatically try to reconnect after 1 minute and continue the keepuptodate? Will it keep retrying every minute until a connection is re-established?
Reconnecttime is very limited atm. It affects only reconnection in a middle of file transfer.
