Topic "Treat the Find dialog like a regular panel"
dandvd
This is the first time I've used remote Find Files in WinSCP and I was frustrated that I couldn't do anything with the files that were found. I've been working with Midnight Commander and similar file managers for 15 years and to see a find panel where you can only focus on one file, was a maor disappointment.
Here's my use case:
I search for a file pattern on the remote server. WinSCP finds a few hundreds of small files. I want to transfer them all in one local directory. The only way to do that right now with WinSCP is extremely cumbersome: I have to focus on one file, copy it locally, re-do the search, and repeat.
It would be great if Find results were a regular panel, with multi-selection, sortable columns etc. so I could copy all those files locally at once.
I'd be very willing to pay for this feature to get implemented, for example via BidForFix.
Thanks for your post. This request has been added to tracker.
