Topic "Carriage Returns showing up as boxes at the end of each reco"
I am using the winscp tool to bring over .txt files from a server outside the destination network.
The source files have comma delimited, quote enclosed records like below.
This record looks correct. However, it actually has a little box at the end of each record which is causing my import tool to fail.
How do I transfer the files without this little box showing up? When I manually transfer the files without using the Winscp tool, there is no box at the end of each record.
I use notepad to view the files by the way.
I am baffled. Thanks for your help.
So how do you transfer the file when the problem occurs.
Also I suggest you to read
Thank you.
I believe the problem is that we are transferring in 'Automatic'.
I am going to change it to "binary".
Thanks for the assist.
