Topic "DES Encryption PPK"
cal
Dear Support,
Currenty, one of clients has a problem with connecting to WinSSHD (SFTP) on their Linux box.
They suggested that if we can do DES encryption on PPK in OpenSSH 2 format, that would solve the problem.
How should I go about it? how can I encrypt a pair-key with DES?
Any help would be much appreciated.
Regards,
Cal
Do you mean encryption of private key you are using in WinSCP to connect?
cal
Hi
Thanks for your response.
I meant that how to generate PPK in OpenSSH 2 with DES encryption.
Thanks again
Sorry, I do not see how encryption of private key can have any effect on connection.
