Topic "typed wrong machine id and login WinSCp"
I typed a wrong host id on WinSCp and gave OK to the popup saying the
The server's host key was not found in the cache and You have no guarantee that the
server is the computer you think it is.
The server's rsa2 key fingerprint is: ssh-rsa 1024 94:3c:9e:2b:23:df:bd:53:b4:ad:f1:5f:4e:2f:9d:ba
I gave OK for something as above.
After this I am not able to login to my original machine id..
How do i rectify this...?
Kindy consider this as urgent...
This cannot be related.
