Topic "File access in subdirectories"
(Please be patient with me and reply in simple English as this is my first time using WinSCP and I am not overly familiar with all of the language!)
Right, I am using WinSCP version 4.1.8 (build 415) on Windows XP, and using the Explorer interface. I am using FTP in order to upload files to a website hosted at winwebhost.daily.co.uk .
I have a main directory with various subdirectories, corresponding to subpages of the website (as I don't want to get into .htaccess just for the sake of removing the ".htm" at the end of each subpage's web address). I would like to be able each .htm file to be able to access a single background image in the home directory, as duplicating it for each directory will obviously take up memory and I can't help feeling there should be a relatively simple solution.
Am I right that I want to set the image's file permissions? Following the documentation, I have tried to play around with this via the Properties box, but every single time have ended up with an error message along the lines of
'SITE CHMOD 040 /wwwroot/bigstock1.JPG': command not understood
Why is it doing this? Is changing the file's permissions even what I want to be doing in the first place?
Thanks in advance!
Probably not.
You should just make sure the URL of the background image in your HTML pages point to correct directory.
Also you should better seek advice on HTML related forum.
OK, thanks for getting back to me.
Only thing is... surely the subdirectory would have to have permission to access the image in the home directory?
There is still an issue with the chmod command not being recognised by the program.
Well, permissions are always specific to OS on the server side. But I haven't heard of such OS. So generally, no, it won't.
How do you execute the command? Please post a full log file showing the problem.
I have been executing the command via the Explorer interface. I have sent a log file to your email address.
