Topic "Cannot log on to WinSCP"
Darlene White
I have installed Winscp 4.2.9 and when I try to log on I get the following error message.
Connection failed. Timeout detected. Connection failed. Please specify the password.
I am using Windows Vista and the transfer protocol is FTP.
Darlene
Please post a log file.
Darlene White
What is a log file and where is it located.
Darlene
