Topic "Command Line Support"
agf
Is there command line support for WinSCP? If so, how can I use the new directory sync from a batch file?
This is not possible, but I may add it.
richardw
I'd certainly vote for that as a feature as I have a slow sftp site that I need to hold locally as well, synchronise functionality helps me a lot but being able to setup a nightly job to do the same where I can specify the directory structures to pull down and the location to synch off would be amazing Smile
pesi
Yes please - that would be a great improvement to a good product.
richardw
I've just thought this through a bit more and it would need to have a text output or logging feature as well so that you can keep and eye on the status of the sync process and ensure it is working properly
Sure. I'm considering ability to process script file and output results to Windows console.
chargen
I'll third (or whatever it is by now) a request for /sync from command line ability. That'd be totally awesome. I want to copy an 8+gb file... pscp can't do it... it craps out just after 4gb. winscp can copy the whole thing, now I just need to automate it!
eman
I would also love to see some command line support Smile
one more vote for command line support.
btw thanks for a nice app. I'll definately donate if I keep using it.
