Topic "WinSCP keeps timing out despite my best efforts to fix..."
listerdl
Hi - WinSCP keeps timing out after about 5 minutes of idle time and asks me for my password again...
I did modify my saved connections in the WinSCP Login screen by selecting Connection in the left-hand treeview, and then changing the Keepalives radio button to Executing dummy protocol commands.
I also used the option for Sending of null SSH packets, but apparently not all servers support that option.
Seems to have not done the trick though...any other ideas?
THANKS!!!!
listerdl
OK I removed this post which has incorrect log data -
I need logs from WinSCP. See my previous post for details.
listerdl
Thanks v much for looking into this - this log is a typical error whereby winSCP logs me out after a few minutes....
. 2011-01-17 19:32:55.473 --------------------------------------------------------------------------
. 2011-01-17 19:32:55.473 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-01-17 19:32:55.474 Login time: 17 January 2011 19:32:55
. 2011-01-17 19:32:55.474 --------------------------------------------------------------------------
. 2011-01-17 19:32:55.474 Session name: My Site SSH Tunnel
. 2011-01-17 19:32:55.475 Host name: my-site.com (Port: 22)
. 2011-01-17 19:32:55.475 User name: c6586877 (Password: No, Key file: No)
. 2011-01-17 19:32:55.475 Tunnel: No
. 2011-01-17 19:32:55.476 Transfer Protocol: SFTP (SCP)
. 2011-01-17 19:32:55.476 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-01-17 19:32:55.476 Proxy: none
. 2011-01-17 19:32:55.476 SSH protocol version: 2; Compression: No
. 2011-01-17 19:32:55.477 Bypass authentication: No
. 2011-01-17 19:32:55.477 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-01-17 19:32:55.477 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-01-17 19:32:55.477 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-01-17 19:32:55.477 SFTP Bugs: -,-
. 2011-01-17 19:32:55.478 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-01-17 19:32:55.478 Shell: default
. 2011-01-17 19:32:55.478 EOL: 0, UTF: 2
. 2011-01-17 19:32:55.478 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-01-17 19:32:55.478 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-01-17 19:32:55.479 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-01-17 19:32:55.479 Cache directory changes: Yes, Permanent: Yes
. 2011-01-17 19:32:55.479 DST mode: 1
. 2011-01-17 19:32:55.479 --------------------------------------------------------------------------
. 2011-01-17 19:32:55.601 Looking up host "my-site.com"
. 2011-01-17 19:32:55.664 Connecting to 175.601.144.1 port 22
. 2011-01-17 19:32:55.938 Server version: SSH-2.0-OpenSSH_5.1
. 2011-01-17 19:32:55.938 We believe remote version has SSH-2 ignore bug
. 2011-01-17 19:32:55.938 Using SSH protocol version 2
. 2011-01-17 19:32:55.938 We claim version: SSH-2.0-WinSCP_release_4.2.9
. 2011-01-17 19:32:56.067 Doing Diffie-Hellman group exchange
. 2011-01-17 19:32:56.365 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-01-17 19:32:56.976 Asking user:
. 2011-01-17 19:32:56.976 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2011-01-17 19:32:56.976 The server's dss key fingerprint is:
. 2011-01-17 19:32:56.977 ssh-dss 1022 61:5r:b9:fd:3a:70:eb:37:99:e9:12:e3:d9:3f:4e:6c
. 2011-01-17 19:32:56.977 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. 2011-01-17 19:32:56.977 Continue connecting and add host key to the cache? ()
. 2011-01-17 19:33:02.788 Host key fingerprint is:
. 2011-01-17 19:33:02.789 ssh-dss 1022 72:5e:b9:fd:3a:70:gb:77:99:e9:12:e3:d9:3f:4e:6c
. 2011-01-17 19:33:02.791 Initialised AES-256 SDCTR client->server encryption
. 2011-01-17 19:33:02.791 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-01-17 19:33:02.791 Initialised AES-256 SDCTR server->client encryption
. 2011-01-17 19:33:02.791 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-01-17 19:33:03.145 Using username "c6983e77".
. 2011-01-17 19:33:03.707 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2011-01-17 19:33:08.692 Prompt (5, SSH server authentication, , <no prompt>)
. 2011-01-17 19:33:08.692 Ignoring empty SSH server authentication request
. 2011-01-17 19:33:08.818 Access granted
. 2011-01-17 19:33:08.944 Opened channel for session
. 2011-01-17 19:33:09.239 Started a shell/command
. 2011-01-17 19:33:09.242 --------------------------------------------------------------------------
. 2011-01-17 19:33:09.242 Using SFTP protocol.
. 2011-01-17 19:33:09.243 Doing startup conversation with host.
> 2011-01-17 19:33:09.246 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-01-17 19:33:09.371 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2011-01-17 19:33:11.282 SFTP version 3 negotiated.
. 2011-01-17 19:33:11.283 Unknown server extension posix-rename@openssh.com="1"
. 2011-01-17 19:33:11.283 Unknown server extension statvfs@openssh.com="2"
. 2011-01-17 19:33:11.283 Unknown server extension fstatvfs@openssh.com="2"
. 2011-01-17 19:33:11.284 We believe the server has signed timestamps bug
. 2011-01-17 19:33:11.284 We will use UTF-8 strings for status messages only
. 2011-01-17 19:33:11.284 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-01-17 19:33:11.291 Getting current directory name.
. 2011-01-17 19:33:11.292 Getting real path for '.'
> 2011-01-17 19:33:11.292 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-01-17 19:33:11.455 Type: SSH_FXP_NAME, Size: 69, Number: 16
. 2011-01-17 19:33:11.455 Real path is '/home/content/09/6067r09'
. 2011-01-17 19:33:11.456 Listing directory "/home/content/09/6867009".
> 2011-01-17 19:33:11.456 Type: SSH_FXP_OPENDIR, Size: 33, Number: 267
< 2011-01-17 19:33:11.584 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2011-01-17 19:33:11.585 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2011-01-17 19:33:11.759 Type: SSH_FXP_NAME, Size: 979, Number: 524
> 2011-01-17 19:33:11.759 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2011-01-17 19:33:11.884 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2011-01-17 19:33:11.885 Status code: 1
> 2011-01-17 19:33:11.885 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2011-01-17 19:33:11.886 Startup conversation with host finished.
. 2011-01-17 19:33:46.540 Changing directory to "html".
. 2011-01-17 19:33:46.541 Getting real path for '/home/content/09/6067009/html'
> 2011-01-17 19:33:46.541 Type: SSH_FXP_REALPATH, Size: 38, Number: 1296
< 2011-01-17 19:33:46.541 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2011-01-17 19:33:46.542 Discarding reserved response
< 2011-01-17 19:33:46.680 Type: SSH_FXP_NAME, Size: 79, Number: 1296
. 2011-01-17 19:33:46.684 Real path is '/home/content/09/6067009/html'
. 2011-01-17 19:33:46.684 Trying to open directory "/home/content/09/6067009/html".
> 2011-01-17 19:33:46.684 Type: SSH_FXP_LSTAT, Size: 38, Number: 1543
< 2011-01-17 19:33:46.811 Type: SSH_FXP_ATTRS, Size: 37, Number: 1543
. 2011-01-17 19:33:46.811 Getting current directory name.
. 2011-01-17 19:33:46.812 Listing directory "/home/content/09/6067009/html".
> 2011-01-17 19:33:46.812 Type: SSH_FXP_OPENDIR, Size: 38, Number: 1803
< 2011-01-17 19:33:46.943 Type: SSH_FXP_HANDLE, Size: 13, Number: 1803
> 2011-01-17 19:33:46.944 Type: SSH_FXP_READDIR, Size: 13, Number: 2060
< 2011-01-17 19:33:47.293 Type: SSH_FXP_NAME, Size: 3453, Number: 2060
> 2011-01-17 19:33:47.294 Type: SSH_FXP_READDIR, Size: 13, Number: 2316
. 2011-01-17 19:33:47.296 Reading symlink "webformmailer.php".
> 2011-01-17 19:33:47.296 Type: SSH_FXP_READLINK, Size: 56, Number: 2579
> 2011-01-17 19:33:47.297 Type: SSH_FXP_STAT, Size: 56, Number: 2833
< 2011-01-17 19:33:47.426 Type: SSH_FXP_STATUS, Size: 28, Number: 2316
. 2011-01-17 19:33:47.426 Storing reserved response
< 2011-01-17 19:33:47.556 Type: SSH_FXP_NAME, Size: 85, Number: 2579
< 2011-01-17 19:33:47.567 Type: SSH_FXP_STATUS, Size: 29, Number: 2833
< 2011-01-17 19:33:47.567 Status code: 2, Message: 2833, Server: No such file, Language:
* 2011-01-17 19:33:47.568 (ECommand) Error reading symlink 'webformmailer.php'.
* 2011-01-17 19:33:47.568 No such file or directory.
* 2011-01-17 19:33:47.568 Error code: 2
* 2011-01-17 19:33:47.568 Error message from server: No such file
* 2011-01-17 19:33:47.568 Request code: 17
< 2011-01-17 19:33:47.570 Status code: 1
> 2011-01-17 19:33:47.572 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
. 2011-01-17 19:33:53.968 Changing directory to "construction".
. 2011-01-17 19:33:53.968 Getting real path for '/home/content/09/6067009/html/construction'
> 2011-01-17 19:33:53.969 Type: SSH_FXP_REALPATH, Size: 51, Number: 3344
< 2011-01-17 19:33:53.970 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
. 2011-01-17 19:33:53.970 Discarding reserved response
< 2011-01-17 19:33:54.094 Type: SSH_FXP_NAME, Size: 105, Number: 3344
. 2011-01-17 19:33:54.094 Real path is '/home/content/09/6067009/html/construction'
. 2011-01-17 19:33:54.095 Trying to open directory "/home/content/09/6067009/html/construction".
> 2011-01-17 19:33:54.095 Type: SSH_FXP_LSTAT, Size: 51, Number: 3591
< 2011-01-17 19:33:54.220 Type: SSH_FXP_ATTRS, Size: 37, Number: 3591
. 2011-01-17 19:33:54.221 Getting current directory name.
. 2011-01-17 19:33:54.221 Listing directory "/home/content/09/6067009/html/construction".
> 2011-01-17 19:33:54.222 Type: SSH_FXP_OPENDIR, Size: 51, Number: 3851
< 2011-01-17 19:33:54.348 Type: SSH_FXP_HANDLE, Size: 13, Number: 3851
> 2011-01-17 19:33:54.349 Type: SSH_FXP_READDIR, Size: 13, Number: 4108
< 2011-01-17 19:33:54.502 Type: SSH_FXP_NAME, Size: 447, Number: 4108
> 2011-01-17 19:33:54.503 Type: SSH_FXP_READDIR, Size: 13, Number: 4364
< 2011-01-17 19:33:54.657 Type: SSH_FXP_STATUS, Size: 28, Number: 4364
< 2011-01-17 19:33:54.658 Status code: 1
> 2011-01-17 19:33:54.658 Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
. 2011-01-17 19:35:34.095 Copying 1 files/directories to remote directory "/home/content/09/6067009/html/construction/"
. 2011-01-17 19:35:34.096 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2011-01-17 19:35:34.096 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2011-01-17 19:35:34.096 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2011-01-17 19:35:34.097 File: "D:\My Dropbox\Websites\my-site.com\construction\events.html"
. 2011-01-17 19:35:34.104 Copying "D:\My Dropbox\Websites\my-site.com\construction\events.html" to remote directory started.
. 2011-01-17 19:35:34.105 Ascii transfer mode selected.
. 2011-01-17 19:35:34.107 Opening remote file.
> 2011-01-17 19:35:34.107 Type: SSH_FXP_OPEN, Size: 79, Number: 4867
< 2011-01-17 19:35:34.108 Type: SSH_FXP_STATUS, Size: 24, Number: 4612
. 2011-01-17 19:35:34.108 Discarding reserved response
< 2011-01-17 19:35:34.238 Type: SSH_FXP_STATUS, Size: 24, Number: 4867
< 2011-01-17 19:35:34.238 Status code: 4, Message: 4867, Server: Failure, Language:
> 2011-01-17 19:35:34.238 Type: SSH_FXP_LSTAT, Size: 63, Number: 5127
< 2011-01-17 19:35:34.364 Type: SSH_FXP_ATTRS, Size: 37, Number: 5127
. 2011-01-17 19:35:34.365 Asking user:
. 2011-01-17 19:35:34.365 Remote file 'events.html' already exists. Overwrite?
. 2011-01-17 19:35:34.366 New: 10125 bytes, 17/01/2011 19:32:46
. 2011-01-17 19:35:34.366 Existing: 9889 bytes, 17/01/2011 13:20:36 ()
> 2011-01-17 19:35:39.156 Type: SSH_FXP_OPEN, Size: 79, Number: 5379
< 2011-01-17 19:35:39.283 Type: SSH_FXP_HANDLE, Size: 13, Number: 5379
> 2011-01-17 19:35:39.288 Type: SSH_FXP_WRITE, Size: 4012, Number: 5894
. 2011-01-17 19:35:39.296 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-17 19:35:39.296 Type: SSH_FXP_CLOSE, Size: 13, Number: 6660
> 2011-01-17 19:35:39.297 Type: SSH_FXP_SETSTAT, Size: 75, Number: 5641
< 2011-01-17 19:35:39.426 Type: SSH_FXP_STATUS, Size: 24, Number: 5894
< 2011-01-17 19:35:39.548 Type: SSH_FXP_STATUS, Size: 24, Number: 6150
< 2011-01-17 19:35:39.555 Type: SSH_FXP_STATUS, Size: 24, Number: 6406
< 2011-01-17 19:35:39.556 Type: SSH_FXP_STATUS, Size: 24, Number: 6660
< 2011-01-17 19:35:39.556 Status code: 0
< 2011-01-17 19:35:39.689 Type: SSH_FXP_STATUS, Size: 24, Number: 5641
< 2011-01-17 19:35:39.689 Status code: 0
. 2011-01-17 19:35:39.694 Listing directory "/home/content/09/6067009/html/construction".
> 2011-01-17 19:35:39.694 Type: SSH_FXP_OPENDIR, Size: 51, Number: 6923
< 2011-01-17 19:35:39.821 Type: SSH_FXP_HANDLE, Size: 13, Number: 6923
> 2011-01-17 19:35:39.822 Type: SSH_FXP_READDIR, Size: 13, Number: 7180
< 2011-01-17 19:35:39.953 Type: SSH_FXP_NAME, Size: 447, Number: 7180
> 2011-01-17 19:35:39.954 Type: SSH_FXP_READDIR, Size: 13, Number: 7436
< 2011-01-17 19:35:40.080 Type: SSH_FXP_STATUS, Size: 28, Number: 7436
< 2011-01-17 19:35:40.081 Status code: 1
> 2011-01-17 19:35:40.082 Type: SSH_FXP_CLOSE, Size: 13, Number: 7684
. 2011-01-17 19:37:19.675 Closing connection.
. 2011-01-17 19:37:19.676 Sending special code: 12
. 2011-01-17 19:37:19.677 Sent EOF message
. 2011-01-18 00:15:54.308 --------------------------------------------------------------------------
. 2011-01-18 00:15:54.309 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-01-18 00:15:54.309 Login time: 18 January 2011 00:15:54
. 2011-01-18 00:15:54.309 --------------------------------------------------------------------------
. 2011-01-18 00:15:54.309 Session name: Conferences SSH Tunnel
. 2011-01-18 00:15:54.309 Host name: my-site.com (Port: 22)
. 2011-01-18 00:15:54.309 User name: c6985577 (Password: No, Key file: No)
. 2011-01-18 00:15:54.310 Tunnel: No
. 2011-01-18 00:15:54.310 Transfer Protocol: SFTP (SCP)
. 2011-01-18 00:15:54.310 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-01-18 00:15:54.310 Proxy: none
. 2011-01-18 00:15:54.310 SSH protocol version: 2; Compression: No
. 2011-01-18 00:15:54.310 Bypass authentication: No
. 2011-01-18 00:15:54.311 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-01-18 00:15:54.311 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-01-18 00:15:54.311 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-01-18 00:15:54.311 SFTP Bugs: -,-
. 2011-01-18 00:15:54.311 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-01-18 00:15:54.311 Shell: default
. 2011-01-18 00:15:54.312 EOL: 0, UTF: 2
. 2011-01-18 00:15:54.312 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-01-18 00:15:54.312 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-01-18 00:15:54.312 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-01-18 00:15:54.312 Cache directory changes: Yes, Permanent: Yes
. 2011-01-18 00:15:54.312 DST mode: 1
. 2011-01-18 00:15:54.313 --------------------------------------------------------------------------
. 2011-01-18 00:15:54.426 Looking up host "my-site.com"
. 2011-01-18 00:15:54.486 Connecting to 173.201.144.1 port 22
. 2011-01-18 00:15:54.930 Server version: SSH-2.0-OpenSSH_5.1
. 2011-01-18 00:15:54.930 We believe remote version has SSH-2 ignore bug
. 2011-01-18 00:15:54.931 Using SSH protocol version 2
. 2011-01-18 00:15:54.931 We claim version: SSH-2.0-WinSCP_release_4.2.9
. 2011-01-18 00:15:55.177 Doing Diffie-Hellman group exchange
. 2011-01-18 00:15:55.492 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-01-18 00:15:55.970 Host key fingerprint is:
. 2011-01-18 00:15:55.971 ssh-dss 1024 62:5e:b9:fd:3a:70:eb:37:99:e9:12:e3:d9:3f:4e:6c
. 2011-01-18 00:15:55.971 Initialised AES-256 SDCTR client->server encryption
. 2011-01-18 00:15:55.972 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-01-18 00:15:55.972 Initialised AES-256 SDCTR server->client encryption
. 2011-01-18 00:15:55.972 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-01-18 00:15:56.396 Using username "c6985577".
. 2011-01-18 00:15:57.160 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2011-01-18 00:16:01.819 Prompt (5, SSH server authentication, , <no prompt>)
. 2011-01-18 00:16:01.819 Ignoring empty SSH server authentication request
. 2011-01-18 00:16:01.946 Access granted
. 2011-01-18 00:16:02.076 Opened channel for session
. 2011-01-18 00:16:02.407 Started a shell/command
. 2011-01-18 00:16:02.411 --------------------------------------------------------------------------
. 2011-01-18 00:16:02.412 Using SFTP protocol.
. 2011-01-18 00:16:02.413 Doing startup conversation with host.
> 2011-01-18 00:16:02.419 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-01-18 00:16:02.560 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2011-01-18 00:16:02.561 SFTP version 3 negotiated.
. 2011-01-18 00:16:02.561 Unknown server extension posix-rename@openssh.com="1"
. 2011-01-18 00:16:02.562 Unknown server extension statvfs@openssh.com="2"
. 2011-01-18 00:16:02.562 Unknown server extension fstatvfs@openssh.com="2"
. 2011-01-18 00:16:02.562 We believe the server has signed timestamps bug
. 2011-01-18 00:16:02.563 We will use UTF-8 strings for status messages only
. 2011-01-18 00:16:02.563 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-01-18 00:16:02.569 Getting current directory name.
. 2011-01-18 00:16:02.570 Getting real path for '.'
> 2011-01-18 00:16:02.570 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-01-18 00:16:02.701 Type: SSH_FXP_NAME, Size: 69, Number: 16
. 2011-01-18 00:16:02.701 Real path is '/home/content/09/6067009'
. 2011-01-18 00:16:02.702 Listing directory "/home/content/09/6067009".
> 2011-01-18 00:16:02.702 Type: SSH_FXP_OPENDIR, Size: 33, Number: 267
< 2011-01-18 00:16:02.842 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2011-01-18 00:16:02.842 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2011-01-18 00:16:03.041 Type: SSH_FXP_NAME, Size: 979, Number: 524
> 2011-01-18 00:16:03.041 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2011-01-18 00:16:03.170 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2011-01-18 00:16:03.171 Status code: 1
> 2011-01-18 00:16:03.171 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2011-01-18 00:16:03.172 Startup conversation with host finished.
. 2011-01-18 00:16:09.471 Cached directory change via "html" to "/home/content/09/6067009/html".
. 2011-01-18 00:16:09.471 Getting current directory name.
. 2011-01-18 00:16:09.472 Listing directory "/home/content/09/6067009/html".
> 2011-01-18 00:16:09.472 Type: SSH_FXP_OPENDIR, Size: 38, Number: 1291
< 2011-01-18 00:16:09.473 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2011-01-18 00:16:09.473 Discarding reserved response
< 2011-01-18 00:16:09.756 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2011-01-18 00:16:09.757 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2011-01-18 00:16:10.242 Type: SSH_FXP_NAME, Size: 3453, Number: 1548
> 2011-01-18 00:16:10.243 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
. 2011-01-18 00:16:10.246 Reading symlink "webformmailer.php".
> 2011-01-18 00:16:10.247 Type: SSH_FXP_READLINK, Size: 56, Number: 2067
> 2011-01-18 00:16:10.251 Type: SSH_FXP_STAT, Size: 56, Number: 2321
< 2011-01-18 00:16:10.397 Type: SSH_FXP_STATUS, Size: 28, Number: 1804
. 2011-01-18 00:16:10.397 Storing reserved response
< 2011-01-18 00:16:10.509 Type: SSH_FXP_NAME, Size: 85, Number: 2067
< 2011-01-18 00:16:10.694 Type: SSH_FXP_STATUS, Size: 29, Number: 2321
< 2011-01-18 00:16:10.694 Status code: 2, Message: 2321, Server: No such file, Language:
* 2011-01-18 00:16:10.696 (ECommand) Error reading symlink 'webformmailer.php'.
* 2011-01-18 00:16:10.696 No such file or directory.
* 2011-01-18 00:16:10.696 Error code: 2
* 2011-01-18 00:16:10.697 Error message from server: No such file
* 2011-01-18 00:16:10.697 Request code: 17
< 2011-01-18 00:16:10.698 Status code: 1
> 2011-01-18 00:16:10.699 Type: SSH_FXP_CLOSE, Size: 13, Number: 2564
. 2011-01-18 00:16:36.670 Copying 1 files/directories to remote directory "/home/content/09/6067009/html/"
. 2011-01-18 00:16:36.670 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2011-01-18 00:16:36.670 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2011-01-18 00:16:36.670 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2011-01-18 00:16:36.671 File: "D:\My Dropbox\Websites\my-site.com\index.html"
. 2011-01-18 00:16:36.677 Copying "D:\My Dropbox\Websites\my-site.com\index.html" to remote directory started.
. 2011-01-18 00:16:36.678 Ascii transfer mode selected.
. 2011-01-18 00:16:36.680 Opening remote file.
> 2011-01-18 00:16:36.680 Type: SSH_FXP_OPEN, Size: 65, Number: 2819
< 2011-01-18 00:16:36.681 Type: SSH_FXP_STATUS, Size: 24, Number: 2564
. 2011-01-18 00:16:36.681 Discarding reserved response
< 2011-01-18 00:16:36.824 Type: SSH_FXP_HANDLE, Size: 13, Number: 2819
> 2011-01-18 00:16:36.826 Type: SSH_FXP_WRITE, Size: 4008, Number: 3334
. 2011-01-18 00:16:36.834 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 00:16:36.835 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2011-01-18 00:16:36.836 Type: SSH_FXP_SETSTAT, Size: 61, Number: 3081
< 2011-01-18 00:16:36.973 Type: SSH_FXP_STATUS, Size: 24, Number: 3334
< 2011-01-18 00:16:37.095 Type: SSH_FXP_STATUS, Size: 24, Number: 3590
< 2011-01-18 00:16:37.096 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
< 2011-01-18 00:16:37.096 Status code: 0
< 2011-01-18 00:16:37.222 Type: SSH_FXP_STATUS, Size: 24, Number: 3081
< 2011-01-18 00:16:37.223 Status code: 0
. 2011-01-18 00:16:37.224 Listing directory "/home/content/09/6067009/html".
> 2011-01-18 00:16:37.224 Type: SSH_FXP_OPENDIR, Size: 38, Number: 4107
< 2011-01-18 00:16:37.356 Type: SSH_FXP_HANDLE, Size: 13, Number: 4107
> 2011-01-18 00:16:41.583 Type: SSH_FXP_READDIR, Size: 13, Number: 4364
< 2011-01-18 00:16:41.733 Type: SSH_FXP_NAME, Size: 3453, Number: 4364
> 2011-01-18 00:16:41.734 Type: SSH_FXP_READDIR, Size: 13, Number: 4620
. 2011-01-18 00:16:41.737 Reading symlink "webformmailer.php".
> 2011-01-18 00:16:41.737 Type: SSH_FXP_READLINK, Size: 56, Number: 4883
> 2011-01-18 00:16:41.738 Type: SSH_FXP_STAT, Size: 56, Number: 5137
< 2011-01-18 00:16:41.868 Type: SSH_FXP_STATUS, Size: 28, Number: 4620
. 2011-01-18 00:16:41.868 Storing reserved response
< 2011-01-18 00:16:41.995 Type: SSH_FXP_NAME, Size: 85, Number: 4883
< 2011-01-18 00:16:41.996 Type: SSH_FXP_STATUS, Size: 29, Number: 5137
< 2011-01-18 00:16:41.996 Status code: 2, Message: 5137, Server: No such file, Language:
* 2011-01-18 00:16:41.996 (ECommand) Error reading symlink 'webformmailer.php'.
* 2011-01-18 00:16:41.997 No such file or directory.
* 2011-01-18 00:16:41.997 Error code: 2
* 2011-01-18 00:16:41.997 Error message from server: No such file
* 2011-01-18 00:16:41.998 Request code: 17
< 2011-01-18 00:16:41.998 Status code: 1
> 2011-01-18 00:16:41.999 Type: SSH_FXP_CLOSE, Size: 13, Number: 5380
. 2011-01-18 00:25:54.618 Closing connection.
. 2011-01-18 00:25:54.619 Sending special code: 12
. 2011-01-18 00:25:54.621 Sent EOF message
. 2011-01-18 14:54:05.918 --------------------------------------------------------------------------
. 2011-01-18 14:54:05.919 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-01-18 14:54:05.919 Login time: 18 January 2011 14:54:05
. 2011-01-18 14:54:05.919 --------------------------------------------------------------------------
. 2011-01-18 14:54:05.919 Session name: Conferences SSH Tunnel
. 2011-01-18 14:54:05.920 Host name: my-site.com (Port: 22)
. 2011-01-18 14:54:05.920 User name: c6985577 (Password: No, Key file: No)
. 2011-01-18 14:54:05.920 Tunnel: No
. 2011-01-18 14:54:05.920 Transfer Protocol: SFTP (SCP)
. 2011-01-18 14:54:05.920 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-01-18 14:54:05.921 Proxy: none
. 2011-01-18 14:54:05.921 SSH protocol version: 2; Compression: No
. 2011-01-18 14:54:05.921 Bypass authentication: No
. 2011-01-18 14:54:05.921 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-01-18 14:54:05.921 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-01-18 14:54:05.921 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-01-18 14:54:05.922 SFTP Bugs: -,-
. 2011-01-18 14:54:05.922 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-01-18 14:54:05.922 Shell: default
. 2011-01-18 14:54:05.922 EOL: 0, UTF: 2
. 2011-01-18 14:54:05.922 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-01-18 14:54:05.922 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-01-18 14:54:05.923 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-01-18 14:54:05.923 Cache directory changes: Yes, Permanent: Yes
. 2011-01-18 14:54:05.923 DST mode: 1
. 2011-01-18 14:54:05.923 --------------------------------------------------------------------------
. 2011-01-18 14:54:05.976 Looking up host "my-site.com"
. 2011-01-18 14:54:06.396 Connecting to 173.201.144.1 port 22
. 2011-01-18 14:54:06.685 Network error: Software caused connection abort
* 2011-01-18 14:54:06.703 (ESshFatal) Network error: Software caused connection abort
. 2011-01-18 14:54:11.587 --------------------------------------------------------------------------
. 2011-01-18 14:54:11.587 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-01-18 14:54:11.587 Login time: 18 January 2011 14:54:11
. 2011-01-18 14:54:11.588 Session name: Conferences SSH Tunnel
. 2011-01-18 14:54:11.588 Host name: my-site.com (Port: 22)
. 2011-01-18 14:54:11.588 User name: c6985577 (Password: No, Key file: No)
. 2011-01-18 14:54:11.588 Tunnel: No
. 2011-01-18 14:54:11.588 Transfer Protocol: SFTP (SCP)
. 2011-01-18 14:54:11.588 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-01-18 14:54:11.589 Proxy: none
. 2011-01-18 14:54:11.589 SSH protocol version: 2; Compression: No
. 2011-01-18 14:54:11.589 Bypass authentication: No
. 2011-01-18 14:54:11.589 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-01-18 14:54:11.589 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-01-18 14:54:11.589 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-01-18 14:54:11.590 SFTP Bugs: -,-
. 2011-01-18 14:54:11.590 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-01-18 14:54:11.590 Shell: default
. 2011-01-18 14:54:11.590 EOL: 0, UTF: 2
. 2011-01-18 14:54:11.590 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-01-18 14:54:11.590 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-01-18 14:54:11.591 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-01-18 14:54:11.591 Cache directory changes: Yes, Permanent: Yes
. 2011-01-18 14:54:11.591 DST mode: 1
. 2011-01-18 14:54:11.591 --------------------------------------------------------------------------
. 2011-01-18 14:54:11.638 Looking up host "my-site.com"
. 2011-01-18 14:54:11.640 Connecting to 173.201.144.1 port 22
. 2011-01-18 14:54:11.962 Server version: SSH-2.0-OpenSSH_5.1
. 2011-01-18 14:54:11.962 We believe remote version has SSH-2 ignore bug
. 2011-01-18 14:54:11.963 Using SSH protocol version 2
. 2011-01-18 14:54:11.963 We claim version: SSH-2.0-WinSCP_release_4.2.9
. 2011-01-18 14:54:12.106 Doing Diffie-Hellman group exchange
. 2011-01-18 14:54:12.434 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-01-18 14:54:12.883 Host key fingerprint is:
. 2011-01-18 14:54:12.883 ssh-dss 1024 62:5e:b9:fd:3a:70:eb:37:99:e9:12:e3:d9:3f:4e:6c
. 2011-01-18 14:54:12.884 Initialised AES-256 SDCTR client->server encryption
. 2011-01-18 14:54:12.884 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-01-18 14:54:12.885 Initialised AES-256 SDCTR server->client encryption
. 2011-01-18 14:54:12.885 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-01-18 14:54:13.531 Using username "c6985577".
. 2011-01-18 14:54:14.090 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2011-01-18 14:54:23.051 Prompt (5, SSH server authentication, , <no prompt>)
. 2011-01-18 14:54:23.051 Ignoring empty SSH server authentication request
. 2011-01-18 14:54:23.196 Access granted
. 2011-01-18 14:54:23.338 Opened channel for session
. 2011-01-18 14:54:23.663 Started a shell/command
. 2011-01-18 14:54:23.669 --------------------------------------------------------------------------
. 2011-01-18 14:54:23.670 Using SFTP protocol.
. 2011-01-18 14:54:23.670 Doing startup conversation with host.
> 2011-01-18 14:54:23.678 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-01-18 14:54:23.821 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2011-01-18 14:54:23.821 SFTP version 3 negotiated.
. 2011-01-18 14:54:23.821 Unknown server extension posix-rename@openssh.com="1"
. 2011-01-18 14:54:23.822 Unknown server extension statvfs@openssh.com="2"
. 2011-01-18 14:54:23.822 Unknown server extension fstatvfs@openssh.com="2"
. 2011-01-18 14:54:23.822 We believe the server has signed timestamps bug
. 2011-01-18 14:54:23.823 We will use UTF-8 strings for status messages only
. 2011-01-18 14:54:23.823 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-01-18 14:54:23.831 Getting current directory name.
. 2011-01-18 14:54:23.831 Getting real path for '.'
> 2011-01-18 14:54:23.831 Type: SSH_FXP_REALPATH, Size: 10, Number: 1296
< 2011-01-18 14:54:24.019 Type: SSH_FXP_NAME, Size: 69, Number: 1296
. 2011-01-18 14:54:24.019 Real path is '/home/content/09/6067009'
. 2011-01-18 14:54:24.020 Listing directory "/home/content/09/6067009".
> 2011-01-18 14:54:24.020 Type: SSH_FXP_OPENDIR, Size: 33, Number: 1547
< 2011-01-18 14:54:24.249 Type: SSH_FXP_HANDLE, Size: 13, Number: 1547
> 2011-01-18 14:54:24.249 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
< 2011-01-18 14:54:24.434 Type: SSH_FXP_NAME, Size: 979, Number: 1804
> 2011-01-18 14:54:24.434 Type: SSH_FXP_READDIR, Size: 13, Number: 2060
< 2011-01-18 14:54:24.669 Type: SSH_FXP_STATUS, Size: 28, Number: 2060
< 2011-01-18 14:54:24.670 Status code: 1
> 2011-01-18 14:54:24.670 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
. 2011-01-18 14:54:24.671 Startup conversation with host finished.
. 2011-01-18 14:55:06.869 Closing connection.
. 2011-01-18 14:55:06.869 Sending special code: 12
. 2011-01-18 14:55:06.870 Sent EOF message
. 2011-01-18 22:24:27.680 --------------------------------------------------------------------------
. 2011-01-18 22:24:27.681 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7600)
. 2011-01-18 22:24:27.683 Login time: 18 January 2011 22:24:27
. 2011-01-18 22:24:27.683 --------------------------------------------------------------------------
. 2011-01-18 22:24:27.683 Session name: Conferences SSH Tunnel
. 2011-01-18 22:24:27.684 Host name: my-site.com (Port: 22)
. 2011-01-18 22:24:27.684 User name: c6985577 (Password: No, Key file: No)
. 2011-01-18 22:24:27.684 Tunnel: No
. 2011-01-18 22:24:27.684 Transfer Protocol: SFTP (SCP)
. 2011-01-18 22:24:27.684 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-01-18 22:24:27.685 Proxy: none
. 2011-01-18 22:24:27.685 SSH protocol version: 2; Compression: No
. 2011-01-18 22:24:27.685 Bypass authentication: No
. 2011-01-18 22:24:27.685 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-01-18 22:24:27.685 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-01-18 22:24:27.685 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-01-18 22:24:27.686 SFTP Bugs: -,-
. 2011-01-18 22:24:27.686 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-01-18 22:24:27.686 Shell: default
. 2011-01-18 22:24:27.686 EOL: 0, UTF: 2
. 2011-01-18 22:24:27.686 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-01-18 22:24:27.686 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-01-18 22:24:27.687 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-01-18 22:24:27.687 Cache directory changes: Yes, Permanent: Yes
. 2011-01-18 22:24:27.687 DST mode: 1
. 2011-01-18 22:24:27.687 --------------------------------------------------------------------------
. 2011-01-18 22:24:27.788 Looking up host "my-site.com"
. 2011-01-18 22:24:29.066 Connecting to 173.201.144.1 port 22
. 2011-01-18 22:24:29.384 Server version: SSH-2.0-OpenSSH_5.1
. 2011-01-18 22:24:29.384 We believe remote version has SSH-2 ignore bug
. 2011-01-18 22:24:29.384 Using SSH protocol version 2
. 2011-01-18 22:24:29.385 We claim version: SSH-2.0-WinSCP_release_4.2.9
. 2011-01-18 22:24:29.589 Doing Diffie-Hellman group exchange
. 2011-01-18 22:24:29.998 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-01-18 22:24:30.559 Host key fingerprint is:
. 2011-01-18 22:24:30.560 ssh-dss 1024 62:5e:b9:fd:3a:70:eb:37:99:e9:12:e3:d9:3f:4e:6c
. 2011-01-18 22:24:30.560 Initialised AES-256 SDCTR client->server encryption
. 2011-01-18 22:24:30.561 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-01-18 22:24:30.561 Initialised AES-256 SDCTR server->client encryption
. 2011-01-18 22:24:30.561 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-01-18 22:24:30.862 Using username "c6985577".
. 2011-01-18 22:24:31.415 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2011-01-18 22:24:35.676 Prompt (5, SSH server authentication, , <no prompt>)
. 2011-01-18 22:24:35.676 Ignoring empty SSH server authentication request
. 2011-01-18 22:24:35.808 Access granted
. 2011-01-18 22:24:35.941 Opened channel for session
. 2011-01-18 22:24:36.249 Started a shell/command
. 2011-01-18 22:24:36.254 --------------------------------------------------------------------------
. 2011-01-18 22:24:36.255 Using SFTP protocol.
. 2011-01-18 22:24:36.256 Doing startup conversation with host.
> 2011-01-18 22:24:36.261 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-01-18 22:24:36.394 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2011-01-18 22:24:36.395 SFTP version 3 negotiated.
. 2011-01-18 22:24:36.395 Unknown server extension posix-rename@openssh.com="1"
. 2011-01-18 22:24:36.396 Unknown server extension statvfs@openssh.com="2"
. 2011-01-18 22:24:36.397 Unknown server extension fstatvfs@openssh.com="2"
. 2011-01-18 22:24:36.397 We believe the server has signed timestamps bug
. 2011-01-18 22:24:36.397 We will use UTF-8 strings for status messages only
. 2011-01-18 22:24:36.398 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2011-01-18 22:24:36.404 Getting current directory name.
. 2011-01-18 22:24:36.405 Getting real path for '.'
> 2011-01-18 22:24:36.405 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2011-01-18 22:24:36.543 Type: SSH_FXP_NAME, Size: 69, Number: 16
. 2011-01-18 22:24:36.543 Real path is '/home/content/09/6067009'
. 2011-01-18 22:24:36.544 Listing directory "/home/content/09/6067009".
> 2011-01-18 22:24:36.544 Type: SSH_FXP_OPENDIR, Size: 33, Number: 267
< 2011-01-18 22:24:36.676 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2011-01-18 22:24:36.676 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2011-01-18 22:24:36.890 Type: SSH_FXP_NAME, Size: 979, Number: 524
> 2011-01-18 22:24:36.890 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2011-01-18 22:24:37.024 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2011-01-18 22:24:37.025 Status code: 1
> 2011-01-18 22:24:37.025 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2011-01-18 22:24:37.026 Startup conversation with host finished.
. 2011-01-18 22:24:46.756 Cached directory change via "html" to "/home/content/09/6067009/html".
. 2011-01-18 22:24:46.756 Getting current directory name.
. 2011-01-18 22:24:46.756 Listing directory "/home/content/09/6067009/html".
> 2011-01-18 22:24:46.757 Type: SSH_FXP_OPENDIR, Size: 38, Number: 1291
< 2011-01-18 22:24:46.757 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2011-01-18 22:24:46.758 Discarding reserved response
< 2011-01-18 22:24:46.887 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2011-01-18 22:24:46.887 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2011-01-18 22:24:47.349 Type: SSH_FXP_NAME, Size: 3453, Number: 1548
> 2011-01-18 22:24:47.732 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
. 2011-01-18 22:24:47.736 Reading symlink "webformmailer.php".
> 2011-01-18 22:24:47.736 Type: SSH_FXP_READLINK, Size: 56, Number: 2067
> 2011-01-18 22:24:47.737 Type: SSH_FXP_STAT, Size: 56, Number: 2321
< 2011-01-18 22:24:47.864 Type: SSH_FXP_STATUS, Size: 28, Number: 1804
. 2011-01-18 22:24:47.864 Storing reserved response
< 2011-01-18 22:24:47.995 Type: SSH_FXP_NAME, Size: 85, Number: 2067
< 2011-01-18 22:24:47.996 Type: SSH_FXP_STATUS, Size: 29, Number: 2321
< 2011-01-18 22:24:47.996 Status code: 2, Message: 2321, Server: No such file, Language:
* 2011-01-18 22:24:47.997 (ECommand) Error reading symlink 'webformmailer.php'.
* 2011-01-18 22:24:47.997 No such file or directory.
* 2011-01-18 22:24:47.997 Error code: 2
* 2011-01-18 22:24:47.997 Error message from server: No such file
* 2011-01-18 22:24:47.998 Request code: 17
< 2011-01-18 22:24:47.998 Status code: 1
> 2011-01-18 22:24:47.998 Type: SSH_FXP_CLOSE, Size: 13, Number: 2564
. 2011-01-18 22:24:52.619 Cached directory change via "construction" to "/home/content/09/6067009/html/construction".
. 2011-01-18 22:24:52.619 Getting current directory name.
. 2011-01-18 22:24:52.619 Listing directory "/home/content/09/6067009/html/construction".
> 2011-01-18 22:24:52.620 Type: SSH_FXP_OPENDIR, Size: 51, Number: 2827
< 2011-01-18 22:24:52.621 Type: SSH_FXP_STATUS, Size: 24, Number: 2564
. 2011-01-18 22:24:52.621 Discarding reserved response
< 2011-01-18 22:24:52.751 Type: SSH_FXP_HANDLE, Size: 13, Number: 2827
> 2011-01-18 22:24:52.752 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
< 2011-01-18 22:24:52.977 Type: SSH_FXP_NAME, Size: 447, Number: 3084
> 2011-01-18 22:24:52.978 Type: SSH_FXP_READDIR, Size: 13, Number: 3340
< 2011-01-18 22:24:53.114 Type: SSH_FXP_STATUS, Size: 28, Number: 3340
< 2011-01-18 22:24:53.115 Status code: 1
> 2011-01-18 22:24:53.115 Type: SSH_FXP_CLOSE, Size: 13, Number: 3588
. 2011-01-18 22:24:56.537 Copying 1 files/directories to remote directory "/home/content/09/6067009/html/construction/"
. 2011-01-18 22:24:56.537 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2011-01-18 22:24:56.537 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2011-01-18 22:24:56.537 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2011-01-18 22:24:56.538 File: "D:\My Dropbox\Websites\my-site.com\construction\mock.html"
. 2011-01-18 22:24:56.543 Copying "D:\My Dropbox\Websites\my-site.com\construction\mock.html" to remote directory started.
. 2011-01-18 22:24:56.544 Ascii transfer mode selected.
. 2011-01-18 22:24:56.545 Opening remote file.
> 2011-01-18 22:24:56.546 Type: SSH_FXP_OPEN, Size: 77, Number: 3843
< 2011-01-18 22:24:56.546 Type: SSH_FXP_STATUS, Size: 24, Number: 3588
. 2011-01-18 22:24:56.547 Discarding reserved response
< 2011-01-18 22:24:56.698 Type: SSH_FXP_HANDLE, Size: 13, Number: 3843
> 2011-01-18 22:24:56.699 Type: SSH_FXP_WRITE, Size: 3994, Number: 4358
. 2011-01-18 22:24:56.706 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:24:56.706 Type: SSH_FXP_CLOSE, Size: 13, Number: 4868
> 2011-01-18 22:24:56.706 Type: SSH_FXP_SETSTAT, Size: 73, Number: 4105
< 2011-01-18 22:24:56.963 Type: SSH_FXP_STATUS, Size: 24, Number: 4358
< 2011-01-18 22:24:56.963 Type: SSH_FXP_STATUS, Size: 24, Number: 4614
< 2011-01-18 22:24:56.965 Type: SSH_FXP_STATUS, Size: 24, Number: 4868
< 2011-01-18 22:24:56.965 Status code: 0
< 2011-01-18 22:24:56.965 Type: SSH_FXP_STATUS, Size: 24, Number: 4105
< 2011-01-18 22:24:56.966 Status code: 0
. 2011-01-18 22:24:56.968 Listing directory "/home/content/09/6067009/html/construction".
> 2011-01-18 22:24:56.968 Type: SSH_FXP_OPENDIR, Size: 51, Number: 5131
< 2011-01-18 22:24:57.110 Type: SSH_FXP_HANDLE, Size: 13, Number: 5131
> 2011-01-18 22:24:57.111 Type: SSH_FXP_READDIR, Size: 13, Number: 5388
< 2011-01-18 22:24:57.246 Type: SSH_FXP_NAME, Size: 561, Number: 5388
> 2011-01-18 22:24:57.247 Type: SSH_FXP_READDIR, Size: 13, Number: 5644
< 2011-01-18 22:24:57.377 Type: SSH_FXP_STATUS, Size: 28, Number: 5644
< 2011-01-18 22:24:57.377 Status code: 1
> 2011-01-18 22:24:57.378 Type: SSH_FXP_CLOSE, Size: 13, Number: 5892
. 2011-01-18 22:25:03.968 Changing directory to "/home/content/09/6067009/html/imagesfunnels".
. 2011-01-18 22:25:03.968 Getting real path for '/home/content/09/6067009/html/imagesfunnels'
> 2011-01-18 22:25:03.969 Type: SSH_FXP_REALPATH, Size: 52, Number: 6160
< 2011-01-18 22:25:03.970 Type: SSH_FXP_STATUS, Size: 24, Number: 5892
. 2011-01-18 22:25:03.971 Discarding reserved response
< 2011-01-18 22:25:04.104 Type: SSH_FXP_NAME, Size: 107, Number: 6160
. 2011-01-18 22:25:04.105 Real path is '/home/content/09/6067009/html/imagesfunnels'
. 2011-01-18 22:25:04.106 Trying to open directory "/home/content/09/6067009/html/imagesfunnels".
> 2011-01-18 22:25:04.106 Type: SSH_FXP_LSTAT, Size: 52, Number: 6407
< 2011-01-18 22:25:04.239 Type: SSH_FXP_ATTRS, Size: 37, Number: 6407
. 2011-01-18 22:25:04.240 Getting current directory name.
. 2011-01-18 22:25:04.241 Listing directory "/home/content/09/6067009/html/imagesfunnels".
> 2011-01-18 22:25:04.241 Type: SSH_FXP_OPENDIR, Size: 52, Number: 6667
< 2011-01-18 22:25:04.378 Type: SSH_FXP_HANDLE, Size: 13, Number: 6667
> 2011-01-18 22:25:04.379 Type: SSH_FXP_READDIR, Size: 13, Number: 6924
< 2011-01-18 22:25:04.828 Type: SSH_FXP_NAME, Size: 9823, Number: 6924
> 2011-01-18 22:25:04.829 Type: SSH_FXP_READDIR, Size: 13, Number: 7180
< 2011-01-18 22:25:04.962 Type: SSH_FXP_STATUS, Size: 28, Number: 7180
< 2011-01-18 22:25:04.962 Status code: 1
> 2011-01-18 22:25:04.963 Type: SSH_FXP_CLOSE, Size: 13, Number: 7428
. 2011-01-18 22:25:28.264 Copying 82 files/directories to remote directory "/home/content/09/6067009/html/imagesfunnels/"
. 2011-01-18 22:25:28.264 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2011-01-18 22:25:28.264 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2011-01-18 22:25:28.264 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2011-01-18 22:25:28.265 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\20Discount.jpg"
. 2011-01-18 22:25:28.272 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\20Discount.jpg" to remote directory started.
. 2011-01-18 22:25:28.273 Binary transfer mode selected.
. 2011-01-18 22:25:28.274 Opening remote file.
> 2011-01-18 22:25:28.274 Type: SSH_FXP_OPEN, Size: 83, Number: 7683
< 2011-01-18 22:25:28.275 Type: SSH_FXP_STATUS, Size: 24, Number: 7428
. 2011-01-18 22:25:28.275 Discarding reserved response
< 2011-01-18 22:25:28.425 Type: SSH_FXP_HANDLE, Size: 13, Number: 7683
> 2011-01-18 22:25:28.425 Type: SSH_FXP_WRITE, Size: 4121, Number: 8198
. 2011-01-18 22:25:28.430 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:28.430 Type: SSH_FXP_CLOSE, Size: 13, Number: 8708
> 2011-01-18 22:25:28.431 Type: SSH_FXP_SETSTAT, Size: 79, Number: 7945
< 2011-01-18 22:25:28.563 Type: SSH_FXP_STATUS, Size: 24, Number: 8198
< 2011-01-18 22:25:28.691 Type: SSH_FXP_STATUS, Size: 24, Number: 8454
< 2011-01-18 22:25:28.696 Type: SSH_FXP_STATUS, Size: 24, Number: 8708
< 2011-01-18 22:25:28.696 Status code: 0
< 2011-01-18 22:25:28.822 Type: SSH_FXP_STATUS, Size: 24, Number: 7945
< 2011-01-18 22:25:28.822 Status code: 0
. 2011-01-18 22:25:28.901 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\20DiscountAd.jpg"
. 2011-01-18 22:25:28.903 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\20DiscountAd.jpg" to remote directory started.
. 2011-01-18 22:25:28.904 Binary transfer mode selected.
. 2011-01-18 22:25:28.904 Opening remote file.
> 2011-01-18 22:25:28.904 Type: SSH_FXP_OPEN, Size: 85, Number: 8963
< 2011-01-18 22:25:29.038 Type: SSH_FXP_HANDLE, Size: 13, Number: 8963
> 2011-01-18 22:25:29.039 Type: SSH_FXP_WRITE, Size: 4756, Number: 9478
. 2011-01-18 22:25:29.045 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:29.045 Type: SSH_FXP_CLOSE, Size: 13, Number: 9988
> 2011-01-18 22:25:29.045 Type: SSH_FXP_SETSTAT, Size: 81, Number: 9225
< 2011-01-18 22:25:29.176 Type: SSH_FXP_STATUS, Size: 24, Number: 9478
< 2011-01-18 22:25:29.485 Type: SSH_FXP_STATUS, Size: 24, Number: 9734
< 2011-01-18 22:25:29.487 Type: SSH_FXP_STATUS, Size: 24, Number: 9988
< 2011-01-18 22:25:29.488 Status code: 0
< 2011-01-18 22:25:29.488 Type: SSH_FXP_STATUS, Size: 24, Number: 9225
. 2011-01-18 22:25:29.505 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\20DiscountAd.png"
. 2011-01-18 22:25:29.508 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\20DiscountAd.png" to remote directory started.
. 2011-01-18 22:25:29.510 Binary transfer mode selected.
. 2011-01-18 22:25:29.510 Checking existence of file.
> 2011-01-18 22:25:29.510 Type: SSH_FXP_LSTAT, Size: 69, Number: 10247
< 2011-01-18 22:25:29.643 Type: SSH_FXP_ATTRS, Size: 37, Number: 10247
. 2011-01-18 22:25:29.644 Checking existence of partially transfered file.
> 2011-01-18 22:25:29.644 Type: SSH_FXP_LSTAT, Size: 78, Number: 10503
< 2011-01-18 22:25:29.775 Type: SSH_FXP_STATUS, Size: 29, Number: 10503
< 2011-01-18 22:25:29.776 Status code: 2
. 2011-01-18 22:25:29.777 Opening remote file.
> 2011-01-18 22:25:29.778 Type: SSH_FXP_OPEN, Size: 94, Number: 10755
< 2011-01-18 22:25:29.909 Type: SSH_FXP_HANDLE, Size: 13, Number: 10755
> 2011-01-18 22:25:29.909 Type: SSH_FXP_WRITE, Size: 13526, Number: 11270
. 2011-01-18 22:25:31.364 7 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:31.364 Type: SSH_FXP_CLOSE, Size: 13, Number: 12548
< 2011-01-18 22:25:31.912 Type: SSH_FXP_STATUS, Size: 24, Number: 12038
< 2011-01-18 22:25:32.042 Type: SSH_FXP_STATUS, Size: 24, Number: 12294
< 2011-01-18 22:25:32.045 Type: SSH_FXP_STATUS, Size: 24, Number: 12548
< 2011-01-18 22:25:32.045 Status code: 0
> 2011-01-18 22:25:32.045 Type: SSH_FXP_REMOVE, Size: 69, Number: 12813
< 2011-01-18 22:25:32.181 Type: SSH_FXP_STATUS, Size: 24, Number: 12813
< 2011-01-18 22:25:32.181 Status code: 0
> 2011-01-18 22:25:32.181 Type: SSH_FXP_RENAME, Size: 142, Number: 13074
< 2011-01-18 22:25:32.372 Type: SSH_FXP_STATUS, Size: 24, Number: 13074
< 2011-01-18 22:25:32.372 Status code: 0
> 2011-01-18 22:25:32.373 Type: SSH_FXP_SETSTAT, Size: 85, Number: 11017
< 2011-01-18 22:25:32.509 Type: SSH_FXP_STATUS, Size: 24, Number: 11017
< 2011-01-18 22:25:32.510 Status code: 0
. 2011-01-18 22:25:32.537 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\236.png"
. 2011-01-18 22:25:32.539 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\236.png" to remote directory started.
. 2011-01-18 22:25:32.540 Binary transfer mode selected.
. 2011-01-18 22:25:32.540 Opening remote file.
> 2011-01-18 22:25:32.541 Type: SSH_FXP_OPEN, Size: 76, Number: 13315
< 2011-01-18 22:25:32.675 Type: SSH_FXP_HANDLE, Size: 13, Number: 13315
> 2011-01-18 22:25:32.675 Type: SSH_FXP_WRITE, Size: 2087, Number: 13830
> 2011-01-18 22:25:32.677 Type: SSH_FXP_CLOSE, Size: 13, Number: 14084
> 2011-01-18 22:25:32.678 Type: SSH_FXP_SETSTAT, Size: 72, Number: 13577
< 2011-01-18 22:25:32.936 Type: SSH_FXP_STATUS, Size: 24, Number: 13830
< 2011-01-18 22:25:32.937 Type: SSH_FXP_STATUS, Size: 24, Number: 14084
< 2011-01-18 22:25:32.937 Status code: 0
< 2011-01-18 22:25:32.937 Type: SSH_FXP_STATUS, Size: 24, Number: 13577
< 2011-01-18 22:25:32.938 Status code: 0
. 2011-01-18 22:25:32.944 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\295.png"
. 2011-01-18 22:25:32.947 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\295.png" to remote directory started.
. 2011-01-18 22:25:32.947 Binary transfer mode selected.
. 2011-01-18 22:25:32.948 Opening remote file.
> 2011-01-18 22:25:32.948 Type: SSH_FXP_OPEN, Size: 76, Number: 14339
< 2011-01-18 22:25:33.082 Type: SSH_FXP_HANDLE, Size: 13, Number: 14339
> 2011-01-18 22:25:33.083 Type: SSH_FXP_WRITE, Size: 2045, Number: 14854
> 2011-01-18 22:25:33.085 Type: SSH_FXP_CLOSE, Size: 13, Number: 15108
> 2011-01-18 22:25:33.085 Type: SSH_FXP_SETSTAT, Size: 72, Number: 14601
< 2011-01-18 22:25:33.345 Type: SSH_FXP_STATUS, Size: 24, Number: 14854
< 2011-01-18 22:25:33.345 Type: SSH_FXP_STATUS, Size: 24, Number: 15108
< 2011-01-18 22:25:33.345 Status code: 0
< 2011-01-18 22:25:33.346 Type: SSH_FXP_STATUS, Size: 24, Number: 14601
< 2011-01-18 22:25:33.346 Status code: 0
. 2011-01-18 22:25:33.358 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\aat.jpg"
. 2011-01-18 22:25:33.360 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\aat.jpg" to remote directory started.
. 2011-01-18 22:25:33.361 Binary transfer mode selected.
. 2011-01-18 22:25:33.361 Opening remote file.
> 2011-01-18 22:25:33.361 Type: SSH_FXP_OPEN, Size: 76, Number: 15363
< 2011-01-18 22:25:33.492 Type: SSH_FXP_HANDLE, Size: 13, Number: 15363
> 2011-01-18 22:25:33.492 Type: SSH_FXP_WRITE, Size: 14861, Number: 15878
> 2011-01-18 22:25:33.499 Type: SSH_FXP_CLOSE, Size: 13, Number: 16132
> 2011-01-18 22:25:33.499 Type: SSH_FXP_SETSTAT, Size: 72, Number: 15625
< 2011-01-18 22:25:33.885 Type: SSH_FXP_STATUS, Size: 24, Number: 15878
< 2011-01-18 22:25:33.886 Type: SSH_FXP_STATUS, Size: 24, Number: 16132
< 2011-01-18 22:25:33.887 Status code: 0
< 2011-01-18 22:25:33.887 Type: SSH_FXP_STATUS, Size: 24, Number: 15625
. 2011-01-18 22:25:33.898 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\AIA.png"
. 2011-01-18 22:25:33.900 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\AIA.png" to remote directory started.
. 2011-01-18 22:25:33.900 Binary transfer mode selected.
. 2011-01-18 22:25:33.901 Opening remote file.
> 2011-01-18 22:25:33.901 Type: SSH_FXP_OPEN, Size: 76, Number: 16387
< 2011-01-18 22:25:34.032 Type: SSH_FXP_HANDLE, Size: 13, Number: 16387
> 2011-01-18 22:25:34.033 Type: SSH_FXP_WRITE, Size: 26089, Number: 16902
. 2011-01-18 22:25:34.621 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:34.621 Type: SSH_FXP_CLOSE, Size: 13, Number: 17668
> 2011-01-18 22:25:34.622 Type: SSH_FXP_SETSTAT, Size: 72, Number: 16649
< 2011-01-18 22:25:34.720 Type: SSH_FXP_STATUS, Size: 24, Number: 16902
< 2011-01-18 22:25:35.332 Type: SSH_FXP_STATUS, Size: 24, Number: 17158
< 2011-01-18 22:25:35.637 Type: SSH_FXP_STATUS, Size: 24, Number: 17414
< 2011-01-18 22:25:35.638 Type: SSH_FXP_STATUS, Size: 24, Number: 17668
< 2011-01-18 22:25:35.638 Status code: 0
< 2011-01-18 22:25:35.639 Type: SSH_FXP_STATUS, Size: 24, Number: 16649
< 2011-01-18 22:25:35.639 Status code: 0
. 2011-01-18 22:25:35.663 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrange.png"
. 2011-01-18 22:25:35.665 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrange.png" to remote directory started.
. 2011-01-18 22:25:35.666 Binary transfer mode selected.
. 2011-01-18 22:25:35.666 Opening remote file.
> 2011-01-18 22:25:35.667 Type: SSH_FXP_OPEN, Size: 84, Number: 17923
< 2011-01-18 22:25:35.841 Type: SSH_FXP_HANDLE, Size: 13, Number: 17923
> 2011-01-18 22:25:35.842 Type: SSH_FXP_WRITE, Size: 27941, Number: 18438
. 2011-01-18 22:25:37.299 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:37.299 Type: SSH_FXP_CLOSE, Size: 13, Number: 19204
> 2011-01-18 22:25:37.299 Type: SSH_FXP_SETSTAT, Size: 80, Number: 18185
< 2011-01-18 22:25:37.686 Type: SSH_FXP_STATUS, Size: 24, Number: 18694
< 2011-01-18 22:25:38.505 Type: SSH_FXP_STATUS, Size: 24, Number: 18950
< 2011-01-18 22:25:38.506 Type: SSH_FXP_STATUS, Size: 24, Number: 19204
< 2011-01-18 22:25:38.506 Status code: 0
< 2011-01-18 22:25:38.506 Type: SSH_FXP_STATUS, Size: 24, Number: 18185
. 2011-01-18 22:25:38.530 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrangeFlat.png"
. 2011-01-18 22:25:38.534 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrangeFlat.png" to remote directory started.
. 2011-01-18 22:25:38.535 Binary transfer mode selected.
. 2011-01-18 22:25:38.536 Opening remote file.
> 2011-01-18 22:25:38.536 Type: SSH_FXP_OPEN, Size: 88, Number: 19459
< 2011-01-18 22:25:38.670 Type: SSH_FXP_HANDLE, Size: 13, Number: 19459
> 2011-01-18 22:25:38.670 Type: SSH_FXP_WRITE, Size: 28344, Number: 19974
. 2011-01-18 22:25:39.747 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:39.747 Type: SSH_FXP_CLOSE, Size: 13, Number: 20740
> 2011-01-18 22:25:39.747 Type: SSH_FXP_SETSTAT, Size: 84, Number: 19721
< 2011-01-18 22:25:40.411 Type: SSH_FXP_STATUS, Size: 24, Number: 20230
< 2011-01-18 22:25:40.548 Type: SSH_FXP_STATUS, Size: 24, Number: 20486
< 2011-01-18 22:25:40.549 Type: SSH_FXP_STATUS, Size: 24, Number: 20740
< 2011-01-18 22:25:40.549 Status code: 0
< 2011-01-18 22:25:40.549 Type: SSH_FXP_STATUS, Size: 24, Number: 19721
< 2011-01-18 22:25:40.550 Status code: 0
. 2011-01-18 22:25:40.575 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrangeFlatBlack.png"
. 2011-01-18 22:25:40.577 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrangeFlatBlack.png" to remote directory started.
. 2011-01-18 22:25:40.582 Binary transfer mode selected.
. 2011-01-18 22:25:40.582 Opening remote file.
> 2011-01-18 22:25:40.582 Type: SSH_FXP_OPEN, Size: 93, Number: 20995
< 2011-01-18 22:25:40.720 Type: SSH_FXP_HANDLE, Size: 13, Number: 20995
> 2011-01-18 22:25:40.720 Type: SSH_FXP_WRITE, Size: 29301, Number: 21510
. 2011-01-18 22:25:40.994 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:40.995 Type: SSH_FXP_CLOSE, Size: 13, Number: 22020
> 2011-01-18 22:25:40.995 Type: SSH_FXP_SETSTAT, Size: 89, Number: 21257
< 2011-01-18 22:25:41.391 Type: SSH_FXP_STATUS, Size: 24, Number: 21510
< 2011-01-18 22:25:42.208 Type: SSH_FXP_STATUS, Size: 24, Number: 21766
< 2011-01-18 22:25:42.209 Type: SSH_FXP_STATUS, Size: 24, Number: 22020
< 2011-01-18 22:25:42.209 Status code: 0
< 2011-01-18 22:25:42.209 Type: SSH_FXP_STATUS, Size: 24, Number: 21257
< 2011-01-18 22:25:42.210 Status code: 0
. 2011-01-18 22:25:42.237 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrangeFlatSmall.png"
. 2011-01-18 22:25:42.239 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\arrowOrangeFlatSmall.png" to remote directory started.
. 2011-01-18 22:25:42.241 Binary transfer mode selected.
. 2011-01-18 22:25:42.241 Opening remote file.
> 2011-01-18 22:25:42.241 Type: SSH_FXP_OPEN, Size: 93, Number: 22275
< 2011-01-18 22:25:42.372 Type: SSH_FXP_HANDLE, Size: 13, Number: 22275
> 2011-01-18 22:25:42.373 Type: SSH_FXP_WRITE, Size: 29303, Number: 22790
. 2011-01-18 22:25:42.660 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:42.660 Type: SSH_FXP_CLOSE, Size: 13, Number: 23300
> 2011-01-18 22:25:42.661 Type: SSH_FXP_SETSTAT, Size: 89, Number: 22537
< 2011-01-18 22:25:43.047 Type: SSH_FXP_STATUS, Size: 24, Number: 22790
< 2011-01-18 22:25:43.436 Type: SSH_FXP_STATUS, Size: 24, Number: 23046
< 2011-01-18 22:25:43.438 Type: SSH_FXP_STATUS, Size: 24, Number: 23300
< 2011-01-18 22:25:43.438 Status code: 0
< 2011-01-18 22:25:43.444 Type: SSH_FXP_STATUS, Size: 24, Number: 22537
< 2011-01-18 22:25:43.444 Status code: 0
. 2011-01-18 22:25:43.457 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\bg.jpg"
. 2011-01-18 22:25:43.459 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\bg.jpg" to remote directory started.
. 2011-01-18 22:25:43.459 Binary transfer mode selected.
. 2011-01-18 22:25:43.460 Opening remote file.
> 2011-01-18 22:25:43.460 Type: SSH_FXP_OPEN, Size: 75, Number: 23555
< 2011-01-18 22:25:43.598 Type: SSH_FXP_HANDLE, Size: 13, Number: 23555
> 2011-01-18 22:25:43.598 Type: SSH_FXP_WRITE, Size: 15453, Number: 24070
> 2011-01-18 22:25:43.609 Type: SSH_FXP_CLOSE, Size: 13, Number: 24324
> 2011-01-18 22:25:43.610 Type: SSH_FXP_SETSTAT, Size: 71, Number: 23817
< 2011-01-18 22:25:43.996 Type: SSH_FXP_STATUS, Size: 24, Number: 24070
< 2011-01-18 22:25:43.997 Type: SSH_FXP_STATUS, Size: 24, Number: 24324
< 2011-01-18 22:25:43.998 Status code: 0
< 2011-01-18 22:25:43.998 Type: SSH_FXP_STATUS, Size: 24, Number: 23817
. 2011-01-18 22:25:44.010 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\botbody.jpg"
. 2011-01-18 22:25:44.013 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\botbody.jpg" to remote directory started.
. 2011-01-18 22:25:44.015 Binary transfer mode selected.
. 2011-01-18 22:25:44.015 Opening remote file.
> 2011-01-18 22:25:44.015 Type: SSH_FXP_OPEN, Size: 80, Number: 24579
< 2011-01-18 22:25:44.146 Type: SSH_FXP_HANDLE, Size: 13, Number: 24579
> 2011-01-18 22:25:44.147 Type: SSH_FXP_WRITE, Size: 20853, Number: 25094
> 2011-01-18 22:25:44.154 Type: SSH_FXP_CLOSE, Size: 13, Number: 25348
> 2011-01-18 22:25:44.154 Type: SSH_FXP_SETSTAT, Size: 76, Number: 24841
< 2011-01-18 22:25:44.676 Type: SSH_FXP_STATUS, Size: 24, Number: 25094
< 2011-01-18 22:25:44.678 Type: SSH_FXP_STATUS, Size: 24, Number: 25348
< 2011-01-18 22:25:44.679 Status code: 0
< 2011-01-18 22:25:44.681 Type: SSH_FXP_STATUS, Size: 24, Number: 24841
< 2011-01-18 22:25:44.681 Status code: 0
. 2011-01-18 22:25:44.701 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\botoptin.jpg"
. 2011-01-18 22:25:44.705 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\botoptin.jpg" to remote directory started.
. 2011-01-18 22:25:44.706 Binary transfer mode selected.
. 2011-01-18 22:25:44.706 Opening remote file.
> 2011-01-18 22:25:44.707 Type: SSH_FXP_OPEN, Size: 81, Number: 25603
< 2011-01-18 22:25:44.843 Type: SSH_FXP_HANDLE, Size: 13, Number: 25603
> 2011-01-18 22:25:44.844 Type: SSH_FXP_WRITE, Size: 19409, Number: 26118
> 2011-01-18 22:25:44.857 Type: SSH_FXP_CLOSE, Size: 13, Number: 26372
> 2011-01-18 22:25:44.857 Type: SSH_FXP_SETSTAT, Size: 77, Number: 25865
< 2011-01-18 22:25:45.372 Type: SSH_FXP_STATUS, Size: 24, Number: 26118
< 2011-01-18 22:25:45.373 Type: SSH_FXP_STATUS, Size: 24, Number: 26372
< 2011-01-18 22:25:45.373 Status code: 0
< 2011-01-18 22:25:45.373 Type: SSH_FXP_STATUS, Size: 24, Number: 25865
< 2011-01-18 22:25:45.374 Status code: 0
. 2011-01-18 22:25:45.388 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\bullet_blue.gif"
. 2011-01-18 22:25:45.390 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\bullet_blue.gif" to remote directory started.
. 2011-01-18 22:25:45.392 Binary transfer mode selected.
. 2011-01-18 22:25:45.392 Opening remote file.
> 2011-01-18 22:25:45.393 Type: SSH_FXP_OPEN, Size: 84, Number: 26627
< 2011-01-18 22:25:45.530 Type: SSH_FXP_HANDLE, Size: 13, Number: 26627
> 2011-01-18 22:25:45.531 Type: SSH_FXP_WRITE, Size: 328, Number: 27142
> 2011-01-18 22:25:45.531 Type: SSH_FXP_CLOSE, Size: 13, Number: 27396
> 2011-01-18 22:25:45.532 Type: SSH_FXP_SETSTAT, Size: 80, Number: 26889
< 2011-01-18 22:25:45.661 Type: SSH_FXP_STATUS, Size: 24, Number: 27142
< 2011-01-18 22:25:45.792 Type: SSH_FXP_STATUS, Size: 24, Number: 27396
< 2011-01-18 22:25:45.793 Status code: 0
< 2011-01-18 22:25:45.793 Type: SSH_FXP_STATUS, Size: 24, Number: 26889
< 2011-01-18 22:25:45.794 Status code: 0
. 2011-01-18 22:25:45.810 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\bullet_orange.png"
. 2011-01-18 22:25:45.816 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\bullet_orange.png" to remote directory started.
. 2011-01-18 22:25:45.818 Binary transfer mode selected.
. 2011-01-18 22:25:45.819 Opening remote file.
> 2011-01-18 22:25:45.819 Type: SSH_FXP_OPEN, Size: 86, Number: 27651
< 2011-01-18 22:25:45.953 Type: SSH_FXP_HANDLE, Size: 13, Number: 27651
> 2011-01-18 22:25:45.954 Type: SSH_FXP_WRITE, Size: 28989, Number: 28166
. 2011-01-18 22:25:46.231 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:46.231 Type: SSH_FXP_CLOSE, Size: 13, Number: 28676
> 2011-01-18 22:25:46.232 Type: SSH_FXP_SETSTAT, Size: 82, Number: 27913
< 2011-01-18 22:25:46.613 Type: SSH_FXP_STATUS, Size: 24, Number: 28166
< 2011-01-18 22:25:47.009 Type: SSH_FXP_STATUS, Size: 24, Number: 28422
< 2011-01-18 22:25:47.010 Type: SSH_FXP_STATUS, Size: 24, Number: 28676
< 2011-01-18 22:25:47.010 Status code: 0
< 2011-01-18 22:25:47.011 Type: SSH_FXP_STATUS, Size: 24, Number: 27913
< 2011-01-18 22:25:47.011 Status code: 0
. 2011-01-18 22:25:47.034 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\button.png"
. 2011-01-18 22:25:47.041 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\button.png" to remote directory started.
. 2011-01-18 22:25:47.042 Binary transfer mode selected.
. 2011-01-18 22:25:47.042 Opening remote file.
> 2011-01-18 22:25:47.043 Type: SSH_FXP_OPEN, Size: 79, Number: 28931
< 2011-01-18 22:25:47.183 Type: SSH_FXP_HANDLE, Size: 13, Number: 28931
> 2011-01-18 22:25:47.184 Type: SSH_FXP_WRITE, Size: 29829, Number: 29446
. 2011-01-18 22:25:47.741 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2011-01-18 22:25:47.742 Type: SSH_FXP_CLOSE, Size: 13, Number: 30212
> 2011-01-18 22:25:47.742 Type: SSH_FXP_SETSTAT, Size: 75, Number: 29193
< 2011-01-18 22:25:47.843 Type: SSH_FXP_STATUS, Size: 24, Number: 29446
< 2011-01-18 22:25:48.381 Type: SSH_FXP_STATUS, Size: 24, Number: 29702
< 2011-01-18 22:25:48.504 Type: SSH_FXP_STATUS, Size: 24, Number: 29958
< 2011-01-18 22:25:48.505 Type: SSH_FXP_STATUS, Size: 24, Number: 30212
< 2011-01-18 22:25:48.505 Status code: 0
< 2011-01-18 22:25:48.632 Type: SSH_FXP_STATUS, Size: 24, Number: 29193
< 2011-01-18 22:25:48.632 Status code: 0
. 2011-01-18 22:25:48.642 File: "D:\My Dropbox\Websites\my-site.com\imagesfunnels\button2.png"
. 2011-01-18 22:25:48.645 Copying "D:\My Dropbox\Websites\my-site.com\imagesfunnels\button2.png" to remote directory started.
. 2011-01-18 22:25:48.645 Binary transfer mode selected.
. 2011-01-18 22:25:48.646 Opening remote file.
> 2011-01-18 22:25:48.646 Type: SSH_FXP_OPEN, Size: 80, Number: 30467
< 2011-01-18 22:25:48.778 Type: SSH_FXP_HANDLE, Size: 13, Number: 30467
> 2011-01-18 22:25:48.778 Type: SSH_FXP_WRITE, Size: 30460, Number: 30982
. 2011-01-18 22:25:49.439 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SS
There are several sessions in your log. Those that are complete do not seem to be disconnected by the server side. Though the log is truncated. Maybe you can email it instead?
