Topic "after power-flash / re-power (re-boot)???"
vikingasia
QUESTION:
after a power-flash / re-boot, how to get WinSCP to automagically 'Start' the synchronization process (with the automagic full-directory-synch-now?)
As any other application. The symplest way is to add shortcut to startup folder.
vikingasia
a shortcut starts the Application SOFTWARE (such as WinSCP); it does NOT START the 'process' of directory synchronization.... I keep having to do this manually... - I'm 'guessing' that the WinSCP wants to do a 'full-directory-synch to 'get-started' and I don't know how to get that to happen (maybe within a script?)
I can (have) put the alias / shortcut in the start-up folder but that doesn't get me to where I need to be and that is with the actual synchronization PROCESS started?
Yes you can launch synchronization using command-line arguments/scripting.
Some links:
http://winscp.net/eng/docs/scripting
http://winscp.net/eng/docs/commandline
http://winscp.net/eng/docs/guide_automation
vikingasia
Thank you - I have reviewed the links - and this looks like I can do this. I looked before in the 'scripting' area of the web-site and was confused, but now I feel more 'educated' (than confused).
thank you very much
