Topic "Large files do not appear in explorer window"
Hi I have a problem when I login to a site via SSH I cannot see large files.
For instance I have a file that is 2.6 Gigs I can see the file if I login via command line telnet, but not in the explorer window of WinSCP, is this a known issue?
Are you using SFTP protocol? Some SFTP servers skip large files. Can you try another SFTP client to check that it is indeed a server-side issue?
