Topic "Error while downloading."
Ahsan
Hi.
I am trying to download a file to server. I passed username and key and connection is working perfectly. But when I download the file then it is not downloaded successfully and file name is also changed.I do not know why it happens.
Can anyone suggest what wrong is it? Here is below my code;
public bool GetSFTP()
            string filename = string.Empty, outfilename = null, output = null, errmsg = null;
            // Run hidden WinSCP process
            Process winscp = new Process();
            string logname = Path.ChangeExtension(Path.GetTempFileName(), "xml");
            var _with1 = winscp.StartInfo;
            // SFTPExecutable needs to be defined in app.config to point to winscp.com
            try
                _with1.FileName = ConfigurationSettings.AppSettings["SFTPExecutable"].ToString();
                if (_with1.FileName == null || _with1.FileName.Length == 0)
                    EventLog.WriteEntry(logSource, "from GetSFTP: SFTPExecutable not set in config file.", EventLogEntryType.Warning);
                    throw (new Exception("from GetSFTP: SFTPExecutable not set in config file."));
            catch (Exception ex)
                errmsg = ex.Message;
                EventLog.WriteEntry(logSource, errmsg, EventLogEntryType.Error);
                return false;
            _with1.Arguments = "/log=" + logname;
            _with1.UseShellExecute = false;
            _with1.RedirectStandardInput = true;
            _with1.RedirectStandardOutput = true;
            _with1.CreateNoWindow = true;
            try
                winscp.Start();
                EventLog.WriteEntry(logSource, "from GetSFTP: Could not run the WinSCP executable.", EventLogEntryType.FailureAudit);
                errmsg = "from GetSFTP:  Could not run the WinSCP executable " + winscp.StartInfo.FileName + Environment.NewLine + ex.Message;
                return false;
            // Feed in the scripting commands
            var _with2 = winscp.StandardInput;
            _with2.WriteLine("option batch abort");
            _with2.WriteLine("option confirm off");
            //_with2.WriteLine("open sftp://" + username + ":" + password + "@" + remotehost);
            _with2.WriteLine(" open " + Protocol + "://" + Username + "@" + Hostname + ":" + Port + " -privatekey=\"" + PublicKeyPath + "\"");
            _with2.WriteLine("cd /entitlement/ENT_7005");
            //_with2.WriteLine("put C:\\Ahsan_Test\\fwfi.log \"" + defaultRmDir + "\"");
            //_with2.WriteLine("exit");
            filename = "C:\\Ahsan_Test\\fwfi.log";
            if (outfilename == null)
                _with2.WriteLine("put " + filename);
            else
                _with2.WriteLine("put " + filename + " \"" + outfilename + "\"");
            _with2.WriteLine("ls");
            _with2.WriteLine("get \"fwis.xml\" \"" + defaultLocalDir + "\"");
            _with2.Close();
            //Get winscp output
            //if ((output != null))
                output = winscp.StandardOutput.ReadToEnd();
            MessageBox.Show(output);
            // Wait until WinSCP finishes
            winscp.WaitForExit();
            // Parse and interpret the XML log
            // (Note that in case of fatal failure the log file may not exist at all)
            if (!File.Exists(logname))
                errmsg = "from GetSFTP:  The WinSCP executable appears to have crashed.";
                EventLog.WriteEntry(logSource,errmsg, EventLogEntryType.FailureAudit);
                return false;
            XPathDocument log = new XPathDocument(logname);
            XmlNamespaceManager ns = new XmlNamespaceManager(new NameTable());
            ns.AddNamespace("w", "http://winscp.net/schema/session/1.0");
            XPathNavigator nav = log.CreateNavigator();
            // Success (0) or error?
            bool status = (winscp.ExitCode == 0);
            MessageBox.Show(status.ToString());
            if (!status)
                errmsg = "from GetSFTP:  There was an error transferring " + filename + ".";
                // See if there are any messages associated with the error
                foreach (XPathNavigator message in nav.Select("//w:message", ns))
                    errmsg += Environment.NewLine + message.Value;
            try
                File.Delete(logname);
            catch (IOException ex)
                MessageBox.Show(ex.Message, "SFTP", MessageBoxButtons.OK, MessageBoxIcon.Error);
                EventLog.WriteEntry(logSource, ex.Message, EventLogEntryType.FailureAudit);
                // at least we tried to clean up
            return !status;
[/code]
What does it mean "not successfully". How is the file changed?
Ahsan
According to log, The file is downloaded successfully but when I do checksome to validate the data using a hash algorithm(SHA512Managed). The validation is false. I do not know, why it happens? Can you please tell me what should I do ?
<session xmlns="http://winscp.net/schema/session/1.0" name="username@hostname" start="2011-01-13T11:29:30.341Z">
  <download>
    <filename value="/entitlement/fwis.xml" />
    <destination value="C:\Ahsan_Test\fwis.xml" />
    <result success="true" />
  </download>
  <download>
    <filename value="/entitlement/fwis.xml.sha512" />
    <destination value="C:\Ahsan_Test\fwis.xml.sha512" />
  </download>
</session>
Ahsan
I am using winscp.com. Basically, My application is winform based and language is C#.net. Please suggest what should i do?
Ahsan
Aren't you using ASCII transfer mode?
Ahsan
Yes. I was using ASCII mode. I have changed the mode from ACII to Binary. Now problem is i am not able to download the file. Here are my arguments which i pass to winscp.
            _with2.WriteLine("option confirm on");
            //Open the session.
            _with2.WriteLine(" open " + comboProtocol.Text.Trim() + "://" + txtUsername.Text.Trim() + "@" + txtHostname.Text.Trim() + ":" + int.Parse(txtPort.Text.Trim()) + " -privatekey=\"" + txtPulicKeyFile.Text.Trim() + "\"");
            _with2.WriteLine("cd " + txtRemoteDir.Text);
            //set Transfer mode ASCII to Binary
            _with2.Write("option transfer binary");
            //Download the file and hash data file
            _with2.WriteLine("get \"" + txtDownloadFile.Text + "\" \"" + txtLocalDir.Text + "\"");
            _with2.WriteLine("get \"" + txtDownloadFile.Text + ".sha512\" \"" + txtLocalDir.Text + "\"");
            _with2.Close();
please verify my setting either it is ok for download the file and its checksum file.
[quote="prikryl"]Aren't you using ASCII transfer mode?[/quote[/code]
WriteLine, not Write.
Ahsan
Thanks. It is working.. Cheers
Vivek
I am geeting following error message while downloading file through winscp. I am calling winscp through .Net code.
winscp> get LOANS\LOANS_082011_Data_163275__April_July11_35219.xls D:\PAYROLL\LOANS\LOANS_082011_Data_163275__April_July11_35219.xls
Can't get attributes of file 'LOANS\LOANS_082011_Data_163275__April_July11_35219.xls'.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 7
winscp> close
Error code: 2
Request code: 7
winscp> close
My first hint is to use forward slashes for remote path:
LOANS/LOANS_082011_Data_163275__April_July11_35219.xls
Aswini
I have automated the File downloading using C#.net 2005. I have created separate solution for downloading from different site. So, it creates multiple winscp.com process in Task manager. I have a button to Start and stop the downloading. I want to close the appropriate winscp from the list if i click on stop button for particular site. How can i do that.
There's no better way apart from killing the process.
Aswini
Thanks for your reply Mr.Prikryl
Now I got New error While Synchronizing the folder from remote. I have synchronized from 4 different site. So there is four different applications that are running separately. I have to run these processes simultaneously. While running 4 application, the files are sync in good way.
But it throws the error, like "The application failed to initialize properly.(0xc0000142). Click OK to terminate the application".
If i click, OK means it closes all downloads. Please help me to clear this issue...
I want to run the download function without stopping. It runs continuously, because any time a new file is added in remote folder, so it always keep on checking the remote that there is any new file or folder is created.i want to check the folder continuously. I won't stop the download processes, it always in running mode.
The only problem is that the above error is thrown always. If i click, the OK button it stops all sync processes.
code.txt (3.95 KB) [Download]
Description: I have used the following code
Sorry, I'm not sure I understand under what circumstances the error appears. Also error is for WinSCP or your application?
Aswini
Thanks for the reply.
I'm also not sure, but the title of the error message box, shows winSCP.com - application error.
But that error did not come, when i run in my local machine. But the error occurs only on server machine.
The server machine is windows 2008 server, 32 bit system - sp1
I have sent you an email.
Aswini
I have sent an email to you.
Aswini
Now the problem is solved me. It is the problem of server. Our Administrator had some changes on that machine, now its going fine.
Please, help me on other problem. I have sync the folder from 4 different FTP sites simultaneously. So there are 4 processes of winSCP.exe in task manager.
My problem is, I have 4 buttons for that above 4 different sites. Each have start and stop options. For example, I have Medlite, Alpha, QT and Direct buttons. If I clicked on Medlite, it starts the sync process from their site. If i clicked on Alpha, it start the sync process from their FTP site and so on.
If I stop the sync of Medlite, it should be stops the medlite sync process only not for other.
I have tried, by creating new winscp.com and give the input like,
Terminate session myusername@MyFTPSite.
But it returns, no session like this.
How can i differentiate from four different process of winscp.com.
As I wrote before, to stop syncing in a middle, you can only terminate the process. As you have for separate processes, I do not see a reason to distinguish the session. Just kill the respective process.
pattyengr
hi..I am using winscp to transfer file to server.When sending the file the name of the file which contains special characters are getting replaced with underscores (_).
Any specific reason for this ?
the file body also contains those characters but they are not getting replaced...
Duplicate post.
