Topic "Bug: "Skip" on timestamp sync error does not skip"
WinSCP 4.3.1, Running Windows Server 2008 R2 RC1 local
Remote is Windows Server 2008 R2 running CopSSH
Transfer protocol SFTP-3, using the gui (Commander)
I am attempting to sync local timestamps between a local copy and a remote copy. I have the adjust remote timestamp option on, and preview changes.
During the sync (after I accept the preview), with some files I get an error: Can't open file '(local file path)'.
System Error. Code: 5.
Access is denied.
[Abort][Retry][Skip][Skip all][help]
Either Skip or Skip All results in another error dialog:
Can't open file '(file path)'
System Error. Code 5.
Access is denied
[OK][Help]
Pressing OK brings me back to the commander interface, the same place I go if I press [Abort].
This is reproducable. The "access denied" is caused by the files in question having the read only attribute set (ntfs file system).
Recommendations:
- fix the skip so it goes to the next item in the list
- put a page behind the [Help] button that suggests permissions and read only attributes
- potentially identify the read-only state in the error dialog
Pertinent log entries follow.
< 2011-01-13 14:13:56.996 Status code: 1
> 2011-01-13 14:13:56.996 Type: SSH_FXP_CLOSE, Size: 13, Number: 4033796
. 2011-01-13 14:13:59.753 Synchronizing local directory 'E:\vol1 backup\games\kids games\Dr Seuss ABC\' with remote directory '/cygdrive/f/games/kids games/Dr Seuss ABC/', params = 326
* 2011-01-13 14:13:59.894 (EOSError) System Error. Code: 5.
* 2011-01-13 14:13:59.894 Access is denied
. 2011-01-13 14:13:59.894 Asking user:
. 2011-01-13 14:13:59.894 Can't open file 'E:\vol1 backup\games\kids games\Dr Seuss ABC\ABC.EXE'. ("System Error. Code: 5.
. 2011-01-13 14:13:59.894 Access is denied")
* 2011-01-13 14:14:01.379 (EScpSkipFile) Can't open file 'E:\vol1 backup\games\kids games\Dr Seuss ABC\ABC.EXE'.
* 2011-01-13 14:14:01.379 System Error. Code: 5.
* 2011-01-13 14:14:01.379 Access is denied
bytre
prikryl wrote:
Can you send me an email, so I can send you back a debug version of WinSCP to track the problem?
Email sent.
bytre
Reproduced with 4.3.0 build 1102 debug, log in email.
bytre
Latest 4.3.0 debug build (via email) appears to fix it.
This bug has been added to tracker.
